Cycles Image Texture Alpha conversion inconsistency with EEVEE and Image Editor #76187
Reference: blender/blender#76187
Operating system: Windows 10 Pro 64-bit (10.0, Build 18363)
Graphics card: NVIDIA GeForce 920M (Laptop)
Broken: v2.83.13 Beta, 2020-04-21
If an image is packed, it will get displayed differently in Cycles and EEVEE. It changes in EEVEE when
Alpha Mode is changed from Straight to Premultiplied to match Cycles, but it does not change in Cycles
by changing that option. If the image is unpacked Cycles will look like EEVEE with Straight Alpha Mode
and again it will not be changed by the Alpha Mode option like EEVEE is.
packed_image_cycles_display_inconsistency.blend
Added subscriber: @manda.3d.projects
Added subscriber: @HDMaster84
Where is the bug? Yes Denoise can cause artifacts if used wrong. That's known.
Is it about the albedo and normal pass? They are pretty good and you can work around the technical limitations.
The node "Denoise" has no artifact at all, it's perfect, it's famous made by Intel. But the artifact is all about the Noisy Image, Albedo and Normal input to the "Denoise" node.
And it's not a technical limitation, if you pack the Image Texture, then the artifact is gone like magic which proves that it's a bug, but not a limitation.
Ok I kind of get your point now. So as far as I understand it, just packing a image will already solve the problem with the albedo pass. This is more likely to have something to do with the image data which is formatted in a different way when packed. If that is the case, then please simplify your report to the point where intel denoise is not even mentioned as denoise is not related to the problem at all. For a start you could try to compare the packed image and the unpacked image in the image editor with the sample tool (Ctrl+RMB) and see if there are differences in the critical areas.
@Henrik Dick (weasel),
Here is my quote in the step 3:
I had doubt if it has something to do with the image data format, that's why I used "BMP" which is the extreme in format simplicity, its binary format is a serie of RGB 8-bit and there is no compression.
The reason I used BMP is because it only has single setting (only RGB 8-bit, edit: also BW but no body use it), but PNG has multiple settings like BW, RGB or RGBA and 8-bit or 16-bit, and Compression Value, I just used BMP to remove the doubt on formatting.
Comparision between Packed and Unpacked
I had that doubt too, check the Step 5 to Step 8, we are about to Pack the image and Unpack it back which leads to the exact result as when it was not packed at all.
Here is Albedo of Step 5 vs Step 8: Pack it and Unpack it back.
Comparaison between Unpacked and Packed at the pixel (X:451,Y:22) with same value (R: 0.00392, G:0.00392, B:0.00392, A:1.0000). It's not completely black, but I intentionally leave the image like that because in real project most of the images are like that for an uncontrollable reason, Photoshop maybe.
Added subscriber: @ankitm
Here is what the report should be about: (roughly)
Notice there is nothing about denoise...
For your problem in your production, just use a Math Node to Subtract 0.01 from the image (with clamp enabled) and another Math Node to Multiply with 1.1 to make the white areas white (again clamp enabled)
@ankitm can you update the report?
@Henrik Dick (weasel), thanks, you are brilliant, the bug is not really about denoise, it's about something else.
And thanks, and I use clamp(clamp(image - 0.01) * 1.1) then the artifact I was talking about is gone.
Other method:
For developer, please fix the bug as Henrik explained before because not everyone will able to use the Map Range node, even genius like us were very confused what happening? Everyone can make mistake on their texture with pixel color value about 0.00392 instead of 0.
The texture was rendered with Blender that causes the non exact zero, it has precision and tileable with Blender, I always use Blender to make such detailed texture, it was not the first time.
Artifact of the Denoise Filter in compositor on almost 100% transparent areato Cycles Image Texture Alpha conversion inconsistency with EEVEE and Image EditorChanged status from 'Needs Triage' to: 'Confirmed'
