No options for screw-tool #76371
Reference: blender/blender#76371
I described here my issue: https://blender.stackexchange.com/questions/176869/screw-tool-blender-2-8-no-options-window?noredirect=1#comment296403_176869
So the problem is i need to search the scre tool via the operators-search and finally i can not set any axis, because the options do not pop up, like they do for example placing a cylinder.
I'm on a buntu 19.10 machine with newest Blender 2.82a.
Added subscriber: @N.EHRHARDT88
Added subscriber: @Pasang
Please provide exact steps to reproduce this issue.
Okay, download blender 2.82a for ubuntu 19.10 make a new general sheet and try to add the screw-modifier. There wont popup any options to set the axis.
I found out something more, there is a screw modifier in the object-properties. And when you add it, all possible options for axis etc are there, but when you click "edit" and have a operator-search, then ener screw and try to add the screw this way, no options will show up.
Added subscriber: @Alaska
I'm unable to reproduce the issue on my computer with an Ubuntu based branch of Linux. Have you tried loading factory default settings and retesting?
To load factory defaults, select from the top of Blender "File>Defaults>Load Factory Settings".
Are you also able to test with Blender 2.83 or 2.90 also with factory defaults? https://builder.blender.org/download/
You can also open the "Last operator" panel by press F9 after using the screw tool. If it doesn't appear, then there's a issue somewhere.
With F9 I can get the options visible. But by default they dont show up.
Its about 2.82a, I did not try other versions.
@N.EHRHARDT88 Did you also test with "Load factory defaults". The issue could have been caused by your user preferences being messed up due to loading old preferences from 2.79 or older versions of 2.8X.
Also, I asked you to test with Blender 2.83 and 2.90 because your issue may have been fixed in a patch for 2.83 or 2.90. Blender 2.82 will not be receiving a new bug fix update on the basis that 2.83 comes with many bug fixes and is releasing in roughly two weeks.
I'm sry, I had no time yet, due to my job, I often sit like 16 hours in front of pc and need some rest.
@N.EHRHARDT88 that's alright.
Added subscriber: @mano-wii
I also can't reproduce the problem.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
