Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-04 21:58, hash: rBd8133b3eb99a
unknown
Quick smoke render on frame > 1 of simulation does not render.
new file
create default plane
apply quick smoke
at this point the smoke shows in all views and in a render.
optionally: save blend file.
move to frame 2 - smoke shows in all views, but not on render. Expected: smoke renders as normal
move to frame 1 - again, smoke does not show in render.
This happens with Cycles and Eeevee
if you save the blend file it does not change this behavior. If you bake the simulation, it does not render. If you change the blackbody intensity in the shader, it does not render. If you promise your first born to Satan, it does not render.
I have not figured out how to get it to render at all after this.
UPDATE: smoke will render if you exit and re-open the file.
File:
