GPencil: Fast clicks over Dopesheet left icons active layer renaming #76481
5 Participants
Reference: blender/blender#76481
Operating system: Windows 10 Famille 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
Graphics card: NVIDIA GeForce GTX 1050
Broken: 2.82
Double clicking on a grease pencil layer's options icons twice triggers the renaming of that layer.
Based on the default startup, with any grease pencil object with a layer. The problem occurs in the Dope Sheet editor panel, under the grease pencil drop down menu, in the left pannel where the layers are at. Double clicking on any of a layer's options icons (Mask, Onion Skin, Eye, Lock) twice triggers the renaming of that layer as if I was clicking on the name of the layer. This window resembles a lot the Object Data Properties, under the Layer dropout, but here I can quickly switch on and off any of the icons.
{F8516514, size=full}
Thanks !
Added subscriber: @Trukas
Added subscribers: @JulianEisel, @antoniov
@JulianEisel do you think is possible to reduce the sensitivity here to fast clicks?
Grease Pencil layer renamingto GPencil: Fast clicks over Dopesheet left icons active layer renamingAdded subscriber: @HooglyBoogly
IMO the proper solution is for clicks on buttons to swallow the first click of a double-click event. The double click timer shouldn't need to be adjusted per region.
Another solution would be to change
NLACHANNEL_NAMEWIDTH
inanimchannels_channel_get
to subtract the width of the buttons on the right from the size of the channel list region. That way the double-click event would only find a channel and execute if wasn't on a button.That second solution is pretty simple, it just loses some generality because the number of buttons changes in different contexts.
@HooglyBoogly Can you manage it? I don't know the UI code too much.
Added subscriber: @ideasman42
I looked into this issue for a while. I was trying to change is the fact that the first click event which toggles the button is also the first click of a double-click event.
P1387 My idea here was to mark "handled" events so they don't act as the first event of a double event. This works, but the problem is that handlers that aren't from buttons can return "handled == true," meaning that double-click doesn't work at all in the dope-sheet list.
Building the interface to get rid of the overlapping buttons is probably the right approach.
@ideasman42 Disregarding the implementation in the paste, do you agree that trying to not use handled events as the first of a double event is not the right approach?
The issues you're facing with that approach are just what I'd have expected, although I think it was worth playing with. The way this is done is pretty old, and I'd expect quite some cases to depend on the exact event system behavior. That's why changes in the event system are always tricky...
I'd propose fixing this by letting the toggle icons respect double-click events, so letting them swallow the double click before it get a chance to be passed to the renaming operator. This works well for me:
(The second change is needed to detect the hovered button correctly. Without it appeared to randomly work or not with a touchpad.)
Yeah, it would have been nice if it worked out. I learned a fair bit anyway. Although the two variables "evt" and "event" are a bit cruel :P
Oh, clever, I didn't think of that. I guess it's not the "right" way but I don't see anything wrong with it!
This issue was referenced by
099dd0690c
