Grab and Rotate in Front view mini bug #76629
Closed
opened 2020-05-11 06:47:39 +02:00 by Zubenelgennubi · 19 comments
Operating system: win 10 64bit
Graphics card: gtx 960
Broken: 2.82 release 2.83 beta and 2.90a 2020-05-10
Grab and Rotate object in Front view(Num 1) and Back view(Ctrl Num1) not actually flat on Y plane, in both Object mode and Edit mode.
1.Grab : in Object mode select object > Num 1 to Front view > G to grab and move object somewhere > Y plane get bump, not flat.
2.Rotate : in Object mode select object > Num 1 to Front view > R to Rotate and rotate object somewhere > Z plane get bump, not flat.
Same thing happen in Edit mode.
Other view plane not have this issues.
**System Information** Operating system: win 10 64bit Graphics card: gtx 960 **Blender Version** Broken: 2.82 release 2.83 beta and 2.90a 2020-05-10 Grab and Rotate object in Front view(Num 1) and Back view(Ctrl Num1) not actually flat on Y plane, in both Object mode and Edit mode. **Exact steps for others to reproduce the error** 1.Grab : in Object mode select object > Num 1 to Front view > G to grab and move object somewhere > Y plane get bump, not flat. ![e0.jpg](https://archive.blender.org/developer/F8527238/e0.jpg) ![e1.jpg](https://archive.blender.org/developer/F8527240/e1.jpg) 2.Rotate : in Object mode select object > Num 1 to Front view > R to Rotate and rotate object somewhere > Z plane get bump, not flat. ![e0.jpg](https://archive.blender.org/developer/F8527238/e0.jpg) ![Er1.png](https://archive.blender.org/developer/F8527249/Er1.png) Same thing happen in Edit mode. Other view plane not have this issues. ![en.png](https://archive.blender.org/developer/F8527260/en.png)
Author
Added subscriber: @zubenelgennubi
#91575 was marked as duplicate of this issue
#91170 was marked as duplicate of this issue
Member
Added subscriber: @Alaska
Member
I can also confirm this happens.
Added subscriber: @Pasang
For me in blender 2.90, while rotating in front and back ortho, X and Z values bump.
See #75596 and #75628. They were somewhat related.
For me in blender 2.90, while rotating in front and back ortho, X and Z values bump. See #75596 and #75628. They were somewhat related.
Member
Added subscriber: @ankitm
Added subscriber: @iss
The fact that this happens only in front view is quite strange, though this seems to happen in all previous versions, so I would believe this is technical limitation somehow.
Added subscriber: @mano-wii
This is a problem with the float precision.
The viewport itself is not exactly aligned.
Solving this is not a simple task, we would have to use doubles in many areas.
So marking as Known Issue
This is a problem with the float precision. The viewport itself is not exactly aligned. Solving this is not a simple task, we would have to use doubles in many areas. So marking as `Known Issue`
Added subscriber: @ideasman42
Campbell Barton self-assigned this 2020-06-17 05:22:59 +02:00
Closing since this isn't something we will address, therefor there is no use in keeping it open.
Added subscriber: @Rodrigo-Saure
@ideasman42, although a definitive solution is not feasible, we can alleviate the problem by making rv3d->viewmat more accurate.
A workaround that would solve these cases of aligned View could be:
diff --git a/source/blender/blenlib/intern/math_rotation.c b/source/blender/blenlib/intern/math_rotation.c
index 34baac6f2a4..1ef612eff17 100644
--- a/source/blender/blenlib/intern/math_rotation.c
+++ b/source/blender/blenlib/intern/math_rotation.c
@@ -284,10 +284,10 @@ void quat_to_mat4(float m[4][4], const float q[4])
 #endif
-  q0 = M_SQRT2 * (double)q[0];
-  q1 = M_SQRT2 * (double)q[1];
-  q2 = M_SQRT2 * (double)q[2];
-  q3 = M_SQRT2 * (double)q[3];
+  q0 = (double)((float)M_SQRT2 * q[0]);
+  q1 = (double)((float)M_SQRT2 * q[1]);
+  q2 = (double)((float)M_SQRT2 * q[2]);
+  q3 = (double)((float)M_SQRT2 * q[3]);
   qda = q0 * q1;
   qdb = q0 * q2;
IMHO, given the number of reports, it might be worth considering implementing these workarounds.
@ideasman42, although a definitive solution is not feasible, we can alleviate the problem by making `rv3d->viewmat` more accurate. A workaround that would solve these cases of aligned View could be: ``` diff --git a/source/blender/blenlib/intern/math_rotation.c b/source/blender/blenlib/intern/math_rotation.c index 34baac6f2a4..1ef612eff17 100644 --- a/source/blender/blenlib/intern/math_rotation.c +++ b/source/blender/blenlib/intern/math_rotation.c @@ -284,10 +284,10 @@ void quat_to_mat4(float m[4][4], const float q[4]) } #endif - q0 = M_SQRT2 * (double)q[0]; - q1 = M_SQRT2 * (double)q[1]; - q2 = M_SQRT2 * (double)q[2]; - q3 = M_SQRT2 * (double)q[3]; + q0 = (double)((float)M_SQRT2 * q[0]); + q1 = (double)((float)M_SQRT2 * q[1]); + q2 = (double)((float)M_SQRT2 * q[2]); + q3 = (double)((float)M_SQRT2 * q[3]); qda = q0 * q1; qdb = q0 * q2; ``` IMHO, given the number of reports, it might be worth considering implementing these workarounds.
Added subscribers: @mahdishalchian, @PratikPB2123
8 Participants
Reference: blender/blender#76629
