Particles - Hair - Children (simple) - Random Size doesn't do anything #76731
Reference: blender/blender#76731
Operating system: Windows
Graphics card: RTX Titan
Broken: 2.83 Beta, e71298a1da971, 2020-05-13
Under children there is a setting for random size, which seems to be broken (or it doesn't do anything)
Add a particle system
change to hair
reduce number to about 10 (in order to see the error clearly)
add children. set to simple
change the random size value
Added subscriber: @Prashan
Added subscribers: @Blendify, @lichtwerk
This doesnt have an effect on the hair path itself, but this comes into play if you use instances with your particles.
So for example you go to
Particle Properties
>Render
>Render As
: Object then children will use theSize
andRandom Size
Or if you use the
Particle Instance
modifier, that one also has an option to use the particle children size for its instances.So, for the original report, I'd say this is not a bug, but working as expected.
I'd say documentation is a bit misleading here:
https://docs.blender.org/manual/en/dev/physics/particles/emitter/children.html
This is not true, children are for Emitter particles as well (2.8 is a bit misleading here since it will not display emitter children with any visualization type other than rendering as objects/collections -- but you can have children on a emitter particles...)
This is not true, children can be on hair -- and size makes a difference here as well (see above)
@Blendify: maybe we should correct this?
Anyways, I think we have to close this, thx reporting anyways!
I made a few changes in rBM6659
Thx!
