Dopesheet "Show Only Errors" filter affects the timeline but cannot be changed there #76778
Reference: blender/blender#76778
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-02 11:33, hash:
1623fdb3bc
After modeling bone-animation and switching to dopesheet, the markers don't show up.
Added rotation-markers with the 'I'-key and tested it.
Switched to dopesheet to edit the markers: none visible, so nothing editable.Animation markers don't show up.blend
Added subscriber: @JWblender
Added subscribers: @WilliamReynish, @dr.sybren, @lichtwerk
This file has "Show Only Errors" option turned ON
https://docs.blender.org/manual/en/dev/editors/dope_sheet/introduction.html#filters
Once that is turned OFF, keyframes are visible again.
Assume this is not a real bug, it is weird though that this option spawns across all animation editors.
If it is intended to spawn across all animation editors, it should be visible in the timeline as well [as a minimum in the View menu -- maybe even in the header?]
CC @dr.sybren
CC @WilliamReynish
Markers don't show in the dope sheetto Dopesheet "Show Only Errors" filter affects the timeline but cannot be changed thereThere is also this "weirdness" that the
Only Selected
option seems to be enforced for the timeline?(this might be by design - havent checked - but with the unwanted side-effect that whenever you turn it off in the dopesheet, change editor to a timeline and back to the dopesheet -> option will be enabled again...)
4904eadc0f
is relevant here.Anyways, one possibility is to enforce "Show Only Errors" to OFF for the timeline? What about hidden then? Or really expose all filtering for the timeline (and go down the rabbit hole of the comment in
4904eadc0f
)This could be marked a Known Issue though or a TODO, it is not really a bug...
The
dopesheet.show_only_errors
setting is clearly only saved on the dopesheet, so if that's influencing the timeline editor I would consider that a bug for sure.There is more weirdness going on, because having a separate dopesheet has no impact on the timeline, regardless of its "Show Only Errors" setting.
Thanks @lichtwerk for doing that digging.
4904eadc0f
shows that there is some code smell here. The dopesheet stores its filter settings in the space data (where it IMO should be), but the timeline has two places where these are set, trying to keep them in sync but failing.This issue was referenced by
7049d2dc58
Changing anything in the filter has no effect;
I still don't see any key-info in the dope-sheet.
@JWblender : you should see keyframes if you disable that setting
How do I do that?
I enabled and disabled each and every choice in the filter-tab.
No markers visible in both Dopesheet and Timeline.
They are visible however in the Graph Editor.
Selecting and deselecting the bone doesn't help either.
Really stuck here.
@JWblender you turned off all the options in "Filter by Type", that's why it doesn't show anything.
