Cannot make face on spiral. #76782
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#76782
Graphics card: GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
blender/blender@77d23b0bd7
Addon Information
Name: Extra Objects (0, 1, 4)
Author: Multiple Authors
when i press F for make face to the spiral, I am answered, [ cannot make segment.]
Create a spiral only in the shape of a drill, then press F.
Added subscriber: @colossabot
Added subscriber: @Alaska
@colossabot Are you able to better describe the issue and the steps required to reproduce it? I'm unable to replicate the issue you're describing and it may be because I'm checking in the wrong area of Blender.
Are you also able to test with default settings? Select from the top of Blender "File>Defaults>Load factory settings" then enable the "Extra Objects" addon in the user preferences then attempt to reproduce the issue.
Are you also able to test with Blender 2.83 and 2.90 to see if they fix your issue? https://builder.blender.org/download/
Added subscriber: @Jewls
im guessing we talk about curves with the Add Extra addon enabled. normal curvesegments can be connected with F. Wich a spiral created with the addon cant.
@Jewls If I understand you correctly, then the steps to reproduce are as follows.
I have been unable to reproduce this on my system with Blender 2.82a with any of the curves in the "Curves Spirals" section.
@Alaska i think i have a clue. you re right. I have tested this with the latest master(2.90)
2020-05-16 19-48-54.mp4
@colossabot please provide more information for this issue and for the next time. according to tracker policy we should have set this to "Needs info from user" and wait till more information is provided.
This is a community afford wich we cant do for every bug.
Please follow the "How to Bug report" https://wiki.blender.org/wiki/Process/Bug_Reports
@Jewls In the last part of your video you show of trying to connect two points from the "middle" of the curve. If this is the issue that @colossabot is experiencing, then this is not a issue. You're not allowed to join points that are in the "middle" of a curve.
Will leave this report open as "Needs information from user" until @colossabot confirms if this is the issue or provides steps to reproduce a different issue they're facing.
Closing this report as invalid as there was no response for a week and I and @Jewls was only able to replicate the "issue" in a situation where it isn't a issue, but a design choice for Blender.
@colossabot If you continue to experience issues and you believe it is a bug, please open a new report. In that report, make sure you include exact steps to reproduce the issue so we can recreate the issue.
