GPencil: Flickering when use Background or Camera image #76886
6 Participants
Reference: blender/blender#76886
Operating system: MacOS Catalina 10.15.4
iMac Retina 5K, late 2017
Graphics card: Radeon Pro 580 8GB
Broken: (2.83 beta)
Worked: (2.82a)
A grease pencil object with a build modifier flickers in opacity in some strokes of a multi-stroke object.
It occurs in the Sequential mode with Grow or Shrink transition but not Fade transition.
Note: It seems to be related to the background image.
flickeringBuild.blend
Added subscriber: @JohnGrigni-4
Added subscriber: @mano-wii
Could you provide a simple file showing the problem?
Actually, I think the culprit is that I had a background image in the camera view. When I disabled it, the flicker disappeared. It also didn't show in the render. Not sure what's going on, but here is the file. The flicker occurs in frames 41, 50, 76, and 88. It also isn't specific strokes, it looks like there is an invisible rectangle that occurs only on the right hand side of the image. flickeringBuild.blend
Here is working normally with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
I notice you turned off the background image in the camera view. As I mentioned, when you disable the background image, the flicker disappears. I'll try the latest build just in case.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I just opened the file and slid the frames.
It appears to be a MacOS-specific bug.
Added subscriber: @antoniov
No problem here in Windows 10 with NVIDIA RTX2080 TI card.
I just realized i never packed the background image into the file, my apologies{F8553321}
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
In the new file I can reproduce the problem.
I updated the description.
Added subscriber: @fclem
I can reproduce too. It's clear is a problem with the background image.
IIRC there was already a bug like this open and set as know issue. Maybe @fclem has the answer.
I have tested, and using a plane with the image (just use Image as Plane add-on and scale image) works perfect.
Flickering_Image_as_Plane.blend
Build modifier on Grease Pencil causes opacity flickeringto GPencil: Flickering when use Background or Camera imageAdded subscriber: @Alastair
With all else the same, lowering the opacity of the Grease Pencil layer which contains the strokes ('Lines' in this case) to below 1.0 also stops the flickering.
This is due to the bounding box of the GPencil object being incorrect for the buggy frames.
The call to
BKE_object_boundbox_get
insidegpencil_object_cache_add
is returning a Unit boundbox incorrectly.I'll leave it up to @antoniov since it is not a drawing issue.
This issue was referenced by
22197d7f8a
Fixed, Thanks @fclem for finding the root cause.
