Empty HUD (Redo Panel) #76940
Closed
opened 2020-05-21 16:24:29 +02:00 by Germano Cavalcante · 12 comments
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006
Broken: version: 2.90 (sub 1), branch: master, commit date: 2020-05-12 22:14, hash: f9d0f59bed
Worked: version: 2.83 (sub 16), branch: master, commit date: 2020-05-12 22:10, hash: 50ef801a79
Sometimes the Redo Panel is empty:
  • Open attached file.
  • Press G to move the object and confirm
    redo_bug.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006 **Blender Version** Broken: version: 2.90 (sub 1), branch: master, commit date: 2020-05-12 22:14, hash: `f9d0f59bed` Worked: version: 2.83 (sub 16), branch: master, commit date: 2020-05-12 22:10, hash: `50ef801a79` **Short description of error** Sometimes the Redo Panel is empty: ![empty_hud.png](https://archive.blender.org/developer/F8546493/empty_hud.png) **Exact steps for others to reproduce the error** - Open attached file. - Press G to move the object and confirm [redo_bug.blend](https://archive.blender.org/developer/F8546501/redo_bug.blend)
Author
Member
Added subscriber: @mano-wii
Author
Member
Member
Member
Can't recreate this with master.
Tested with global undo off too, but that didn't change anything either.
Maybe try with softwaregl? (I don't actually know if you can still do that on Windows nowadays)
Can't recreate this with master. Tested with global undo off too, but that didn't change anything either. Maybe try with softwaregl? (I don't actually know if you can still do that on Windows nowadays)
Member
Member
I can reproduce this, that's odd.
The redo panel doesn't respond at all. Even clicking the expand arrow just places the 3D cursor below it.
Moving either of the two objects makes this happen, but moving either of them a second time doesn't.
I can reproduce this, that's odd. The redo panel doesn't respond at all. Even clicking the expand arrow just places the 3D cursor below it. Moving either of the two objects makes this happen, but moving either of them a second time doesn't.
Author
Member
I can still replicate.
Nothing changes with softwaregl and Factory Settings.
Maybe it's a windows specific problem?
> In #76940#936218, @JulianEisel wrote: > Maybe try with softwaregl? I can still replicate. Nothing changes with softwaregl and Factory Settings. Maybe it's a windows specific problem?
Member
I'm on Linux. I can look into it in a bit.
Member
Was able to reproduce it on Linux too (previously tried on macOS).
This is probably caused by bad initialization of area/region coordinates. There are some subtle differences between how OSes send screen size events, that may kick in here.
And indeed, forcing a re-init of coordinates by dragging an area edge or changing the window size brings back the label.
Was able to reproduce it on Linux too (previously tried on macOS). This is probably caused by bad initialization of area/region coordinates. There are some subtle differences between how OSes send screen size events, that may kick in here. And indeed, forcing a re-init of coordinates by dragging an area edge or changing the window size brings back the label.
This issue was referenced by 3bc15c097c
This issue was referenced by 3bc15c097c6492559d416a4eafecb7e6936a80b8
Member
Julian Eisel self-assigned this 2020-05-22 18:43:20 +02:00
Member
The region coordinates were only updated if the newly calculated dimensions differed from what was stored in the region. So if the file was re-opened on a different effective DPI (like I did first) the region coordinates would be set properly.
Now they are always updated when visibility changes.
The region coordinates were only updated if the newly calculated dimensions differed from what was stored in the region. So if the file was re-opened on a different effective DPI (like I did first) the region coordinates would be set properly. Now they are always updated when visibility changes.
Reference: blender/blender#76940
