GPencil: Crash on Draw mode with custom startup file #77003
6 Participants
Reference: blender/blender#77003
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.90 (sub 3), branch: master, commit date: 2020-05-22 20:59, hash:
86fa8dc7f7
Worked: Blender 2.9 daily build from May 19th
crash on grease pencil draw mode
Open attached file, Create Grease Pencil object, go to draw mode.
startup.blend
Added subscriber: @heavypoly
Added subscriber: @dupoxy
I can redo the crash with the provided .blend
startup.crash.txt
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Sorry this is NOT resolved but I can not reopen it :(
So Sorry for the extra work here can someone reopen this report thanks.
Changed status from 'Resolved' to: 'Needs Triage'
Grease Pencil crash on Draw mode with custom startup fileto GPencil: Crash on Draw mode with custom startup fileChanged status from 'Needs Triage' to: 'Confirmed'
This issue was referenced by
22462fed00
Added subscriber: @antoniov
@heavypoly Not sure how you created this blend file, but it looks that it was created with some alpha version. I have fixed the problem, Also, I have fixed other issues with brushes in you file. Attached the fixed version.
startup_fixed.blend
It works! Thank you @antoniov !
Added subscriber: @Meru
The startup_fixed.blend crashes Templates. See this repository for a reference: https://github.com/notfood/Blender-Config-Heavypoly
I'm using the old startup.blend file that works, if you replace it with the startup_fixed.blend, Blender crashes with the included file.
blender.crash.txt
@Meru crashes what template? the templates in the github attached?
When you put it under the directory
And then, you launch the template as, new > Heavypoly
You'll crash.
A screenshot for reference:
Any issues reproducing it?
I'm under Linux. Does it reproduce on Windows?
@Meru I Cannot reproduce on Windows 10 using 2.83 official.
I reproduced it on Windows 7 and Windows 10, using
blender-2.90.0-c7b03fe9c07a-windows64.zip
(June 17, 00:17:09)Users followed this guide:
{Blender_install}\2.90\scripts\startup\bl_app_templates_system\Heavypoly
Heavypoly
folderHeavypoly
This is the crash file on Windows: blender.crash.txt
I was unable to reproduce it under Windows 2.83, it does reproduce under Linux 2.83.
Should I open a new issue with the template crash?
@Meru I opened a task (#78001) but we were unable to reproduce it. Try this file No_crash_opening.blend
Yes, this file loads fine with no crash. Thank you.
Are there any steps I have to follow to fix the broken file? Because I may have to do so again.
I have another file that has the same issue. It crashes with the same crashlog on Linux and Windows 2.90
Can you detail the steps to fix them please? Resaving it doesn't seem to fix it. It used to work fine before as I used it a lot.
startup.blend
@Meru I can open your startup file, add a GPencil and draw, sculpt, vertex paint, weight paint and edit.
I'm on Windows.and tested 2.83 and 2.90 (last master code). Try the attached file... I just open it and save.
startup_saved.blend
Same crash with the file you attached. blender.crash.txt
I can open the file just fine, it just fails as a startup.blender from a template, Windows or Linux.
https://docs.blender.org/manual/en/dev/advanced/app_templates.html
I gave it some more testing. Seems like adding and removing a GPencil object fixes the file.
This issue came back to haunt me once again.
This time, adding and removing a new grease pencil object doesn't fix it. Happens on Windows or Linux regardless.
Similar steps to reproduce:
Heavypoly.zip
Same crash:
blender.crash.txt
startup.blend
Another reproducible crash
blender.crash.txt
Fixed the issue by opening startup.blend, entering GP weight paint mode, clicking on reset brush and saving.
