Collections: Exclude From ViewLayer toggle will leave the object in multiple modes (e.g. unable to set as active object) #77073
7 Participants
Reference: blender/blender#77073
Broken: version: 2.83 (sub 17), branch: master, commit date: 2020-05-25 17:35, hash:
39aa122a0e
Worked: Never
Setting a mesh to either texture paint or particle edit mode (when the mesh is an emitter) and then excluding and including the collection prevents the object from being set as active, and so further interaction with the object is not possible.
Workaround
Set the active object as you would normally do (e.g., click on the camera) then save and re-open the file.
Added subscriber: @Imaginer
This seems like a somewhat serious issue, so I'm tagging with 2.83. I hope this is alright.
This is also potentially related to #72490 and #77074
Added subscribers: @dfelinto, @brecht, @lichtwerk
Can confirm.
This one (same as #77074) has been around for some time though, and considering how late we are in the release cycle, I'll remove 2.83 as a tag.
Not exactly sure which module is responsible for collection-related bugs? (for the time being, I'll put this on the UI desk)
CC @brecht
CC @dfelinto
Unable to set mesh as active object after excluding collection in texture paint and particle edit modeto Collections: Exclude From ViewLayer toggle will leave the object in multiple modes (e.g. unable to set as active object)Switching to High prio (since getting into this mode-limbo is pretty hard to recover from -- not sure if there is any tbh)
Actually I just found a couple of ways to recover from this. You can reset the active object using the python console, save and reopen the blend file, or (the easiest way) you can just click the green mesh data icon for the object in the outliner which sends you to the object's edit mode and from there everything works again.
I noticed during my testing that grease pencil objects are also affected, but not as strongly. When toggling exclude collection with a grease pencil object not in object mode it causes the selection outline not to display and, when it was in vertex paint mode, it's drawn as if it's still in vertex paint even though it's now in object mode. The outliner recovery method from above fixes the drawing.
The workaround is simpler actually: you can set the active object as you would normally do (e.g., click on the camera) then saving and re-opening the file and things work. Which also means priority is a bit lower.
Added subscriber: @ideasman42
The issue is that the object is still stuck with mode 'TEXTURE_PAINT' even though it is no longer the active object. The same happens for 'EDIT', yet this one doesn't stop the object from being selected again to be active.
For the records, if using python to set the object as active it works.
bpy.context.view_layer.objects.active = bpy.data.objects['Cube']
.So the issue is with the outliner / viewport "set to active" code.
@ideasman42 just to refresh my mind, we are ok with objects lingering in modes that are not object mode, right? If I remember correctly at some point we gave up on their syncing, moving the sanity check elsewhere.
Added subscriber: @natecraddock
Campbell said that indeed we can't make strong assumptions about this, there is only the editing option not to change modes when selecting.
@Zachman can you look at this issue? It should be straightforward, but, but it has to be done well to work for both the outliner AND the viewport.
@dfelinto Sorry, my last post wasn't clear. There's an easier way to recover from this than saving and re-opening the blend file, just click the data icon that's beside the object in the outliner (the green triangle in the default blender theme). This takes you to edit mode and then you can switch back to object mode and everything will be fine.
Added subscriber: @xiwei
Hello, is this task unassigned? I would like to try it out since it's in #good_first_issue
Hey @xiwei, it's been assigned (to me) and there is a revision awaiting review already (D7886: Fix #77073: Objects cannot be activated after collection exclude), sorry about that! You can find the information about task assignment in the right column next to the task description, and the revisions are listed below the description.
@Zachman Don't worry still thx. imma just give a look to your commit :)
This issue was referenced by
30395a491f
@Zachman, @ideasman42, Thanks for the fix.
