Interrupt action with RMB doesn't work in tablet mode, when "Release Confirms" is checked in preferences #77112
Reference: blender/blender#77112
renderer: 'GeForce GTX 1080 Ti/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.5.0 NVIDIA 442.59'
pen tablet hardware: Intuos 5 by Wacom
version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash:
375c7dc4ca
, type: Releasebuild date: 2020-03-12, 15:41:08
platform: Windows
While editing an object in Blender it is possible to interrupt an action by pressing the right mouse button.
Example: Move an object with left mouse button, hold the left mouse button and press the right one addionally.
But all this isn't working when you try this with a tablet pen and use the "Tweak" tool in combination using a wacom tablet for example.
The workaround for tablet users is to uncheck the "Release Confirms" function in the input section of Blenders preferences.
But then you have the problem of confirming all actions by using the pen tip, because it reperents the left mouse button.
Only effects when using a tablet device, like a wacom tablet!
Expected action: Interrupting the cube movement.
Added subscriber: @ChristophWerner
Interrupt action with RMB doesn't work in tablet mode, when "Release conform" in prefs is checkedto Interrupt action with RMB doesn't work in tablet mode, when "Release confirm" in prefs is checkedInterrupt action with RMB doesn't work in tablet mode, when "Release confirm" in prefs is checkedto Interrupt action with RMB doesn't work in tablet mode, when "Release Confirms" is checked in preferencesAdded subscriber: @ideasman42
Tested with a wacom intuos 3 on Linux and can't redo this, with/without release to confirm, right mouse always cancels and never opens the context menu.
Can you double check this happens from factory settings?
I'm using a intuos 4 Wacom Tablet in windows 10.
It's still happen with factory settings. Have reloaded the factory settings in the prefs and made another test.
See this video recording: https://youtu.be/EouX02N3_VM
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
This could be spesific to windows or your configuration, if it was a common problem I'd assume we'd get many more reports about this though.
Hi Campbell.
I've asked a friend to test it on his computer with Blender 2.83 and a wacom intuos 5.
He gets the same issue. When he tries to drag an object and press the right mousebutton by using his wacom pen, then the object menu appear, instead of the expected action interruption.
I guess the most wacom users works different and are using control gizmos for editing. My friend for example is using his wacom tablet to control all apps. He never used the the right mouse button to interrupt an action in Blender.
Instead he use the regular undo. Maybe it's just he, but I think tablet users think different overall.
So to answer your question:
Yes. The same happen on a different windows 10 installation and a wacom intuos tablet.
So we tested it here with two different windows 10 systems and a wacom intuos version 4 and 5.
Added subscriber: @lichtwerk
Also cannot reproduce with a Intuos 4 Wacom Tablet on Linux.
Will tag as Windows-only issue for now.
Added subscriber: @PrototypeNM1
Could not reproduce on a Surface device (Windows Ink) or a Wacom Bamboo (Wintab or Windows Ink).
@lichtwerk (sorry, tagged the wrong person)
could you recreate the issue with [this build ]] and copy the system console [ https:*developer.blender.org/paste/edit/form/default/ | here ?Update:
I've added some more details to my bug post. It happens only if you use the "Tweak" Tool.
All is fine pressing "g".
@ChristophWerner could you recreate the issue with [this build ]] and copy the system console [ https:*developer.blender.org/paste/edit/form/default/ | here ?
Edit: I retested with the updated instructions and was able to recreate the issue at least on one Windows Ink device. Will investigate.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Still no issue on Linux.
Thank you.
@ChristophWerner
Changed status from 'Confirmed' to: 'Needs User Info'
It's "Automatic".
I've tested it and the issue happens in all Tablet API modes.
Same issue with the build you asked for:
My Log file: P1734
The behavior you're seeing is because the Automatic Tablet API is falling back to Windows Ink. The behavior you see is a known limitation for that API. It shouldn't be falling back like that.
I've uploaded a build with some changes, could you test [this build ]], and if it doesn't fix the issue upload the log [ https:*developer.blender.org/paste/edit/form/default/ | here (so the report doesn't become a wall of logs).
Thank you. I can't execute your build and get some system errors here:
My fault, uploaded a debug build. :B
Please test the updated the build, same link as before.
Feedback:
In your latest build the left mouse button drag function doesn't work with the wacom pen.
I can click with the pen tip, but when I hold then nothing happen. Even options in pull down menus can't be chosen, because I'm not able to drag by holding the left mouse button.
Log file: P1738
@ChristophWerner I [updated the build ]] with additional logging, could you recreate the bug and [ https:*developer.blender.org/paste/edit/form/default/ | upload the console log again?
Cosole log is empty for any reason. No data is written. So here are my observations with the latest version:
Note for preferences:
Both "Automatic" mode and "Wintab" mode doesn't work by using a Wacom tablet. Nothing happen by using a pen.
Only "Windows Ink" mode works and have to be set in the prefs by the user (Is not detected automatically).
I fixed the issue with the system console not working, [download build here ]] and [ https:*developer.blender.org/paste/edit/form/default/ | paste console here .
Here is the log file from today morning: P1779
I think #83120 might be a duplicate of this bug. Could you confirm whether right click cancel previously worked for this hardware, or was it new hardware and you found this was an issue? If not new hardware, could you check if the driver was updated around the same time?
~~Also, can you try run Blender from console with
--debug-events
?https://docs.blender.org/manual/en/latest/advanced/command_line/launch/windows.html ~~
Optionally you can put this file in the same directory asblender.exe
and run it (blender_debug_events.cmd
).blender_debug_events.cmd
After that, try to replicate the problem with a few steps and then close the blender.After Blender closes, the logs will be in a text file which can be attached here.
@ChristophWerner disregard the above, could you repeat the bug in this build, copy the system console to this link, and link the paste in a reply to this report?
Hi Nicholas. First a Happy new year to you! :)
I've tested your link for the recent build and it worked directly like expected. Great!
Do you still need the system console output?
Changed status from 'Needs User Info' to: 'Resolved'
Nope, if the issue is gone there wouldn't be anything interesting in the log. Thanks for confirming. :)
