Negative numeric transforms are broken #77118
2 Participants
Reference: blender/blender#77118
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.83 (sub 17), branch: master, commit date: 2020-05-25 17:35, hash:
39aa122a0e
Worked: 2.82a
Transforms (move, rotate, scale) done through numeric input no longer work when adding a minus sign after inputting the value.
Select the default cube.
Press G, Z, -1
The cube will move down -1 on the Z axis.
Press G, Z 1, -. The cube will not move down -1 on the Z axis.
In 2.82a, this works, and is very handy because you don't have to worry about which scale, move or rotation axis (positive or negative) is correct.
For example, if you want to rotate an object on the X axis by 45 degrees, you can simply type R X 45. If you find that the rotation was in the wrong direction, you can type the "-" key afterward and it fixes the rotation.
The way it works now is that you get an error.
Here's the error in 2.83beta
Here's the correct output in 2.82a
Added subscriber: @stevewarner
Added subscriber: @Alaska
I am unable to reproduce the issue you're describing.
It looks to me like you're in "advanced numerical input mode". This is activated by pressing * while entering a value or can be enabled by default in the preferences.
To find the setting in the user preferences follow these steps:
Edit -> Preferences
.Input
tab.Default to Advanced Numeric Input
to the setting you prefer. Off should give you the results you want and it should be off by default.If that fails, try loading factory defaults to see if that helps. Select form the top of Blender
File -> Defaults -> Load Factory Settings
.If loading factory defaults fixes the issue, then open preferences
Edit -> Preferences
and click theSave preferences
button. Now when ever you open Blender, it should work as expected.Note: You will lose any previously set preferences (E.G. GPU to render with, themes, custom keymaps, etc).
Ah! Thank you! The "Advanced Numerical Input Mode" was the issue. I'm not sure how it got turned on but disabling it fixed the problem.
Cheers!
