Crash when opening bunny.blend file #77192
Closed
opened 2020-05-30 09:16:10 +02:00 by Ghost · 20 comments
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-05-29 18:08, hash: 2ee94c954d Notice: it is crashing in Blender 2.83 as well
Worked: Blender 2.82
Open the Blend file, Blender should crash if it doesn't crash my blender_debug_output.txt is below.
Bunny.blend
blender_system_info.txt
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-05-29 18:08, hash: `2ee94c954d` Notice: it is crashing in Blender 2.83 as well Worked: Blender 2.82 **Short description of error** Crash when opening bunny.blend file **Exact steps for others to reproduce the error** Open the Blend file, Blender should crash if it doesn't crash my blender_debug_output.txt is below. [Bunny.blend](https://archive.blender.org/developer/F8564798/Bunny.blend) [blender_debug_output.txt](https://archive.blender.org/developer/F8564818/blender_debug_output.txt) [blender_system_info.txt](https://archive.blender.org/developer/F8564819/blender_system_info.txt)
Author
Added subscriber: @ErickNyanduKabongo
Member
Added subscriber: @Alaska
Member
Member
Can confirm. Also affects 2.83.0 2020-05-29 17:42 691a1e3357.
GTX 1050Ti 445.87
And
Linux-5.4.0-7634-generic-x86_64-with-debian-bullseye
GTX 1050Ti 440.82
Can confirm. Also affects 2.83.0 2020-05-29 17:42 `691a1e3357`. Windows-10-10.0.18362 GTX 1050Ti 445.87 And Linux-5.4.0-7634-generic-x86_64-with-debian-bullseye GTX 1050Ti 440.82
Member
Added subscriber: @ankitm
Member
Please upload this file too.
C:\blend_temp\Bunny.crash.txt
Please upload this file too. `C:\blend_temp\Bunny.crash.txt`
Member
Bunny.crash.txt
On Linux with 2.83.0.
[Bunny.crash.txt](https://archive.blender.org/developer/F8564898/Bunny.crash.txt) On Linux with 2.83.0.
Added subscriber: @Smjert
I think it's worth noting that on Blender 2.82a it doesn't crash but it logs the following:
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
Read blend: /home/smjert/Documents/Modeling/Bugs/Bunny.blend
scripts disabled for "/home/smjert/Documents/Modeling/Bugs/Bunny.blend", skipping 'Rabbit_rig_UI.py'
Dependency cycle detected:
  OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() depends on
  OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.R"].location) via 'Driver -> Driven Property'
  OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() via 'RNA Target -> Driver'
  OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.R"].location) via 'Driver Order'
  OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() depends on
  OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.L"].location) via 'Driver -> Driven Property'
  OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() via 'RNA Target -> Driver'
  OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.L"].location) via 'Driver Order'
Detected 4 dependency cycles
ERROR (bke.anim_sys): ../source/blender/blenkernel/intern/anim_sys.c:4160 BKE_animsys_eval_driver: invalid driver - (null)[0]
I think it's worth noting that on Blender 2.82a it doesn't crash but it logs the following: ``` Warning: property 'release_confirm' not found in keymap item 'OperatorProperties' Read blend: /home/smjert/Documents/Modeling/Bugs/Bunny.blend scripts disabled for "/home/smjert/Documents/Modeling/Bugs/Bunny.blend", skipping 'Rabbit_rig_UI.py' Dependency cycle detected: OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() depends on OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.R"].location) via 'Driver -> Driven Property' OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() via 'RNA Target -> Driver' Dependency cycle detected: OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() depends on OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.R"].location) via 'Driver -> Driven Property' OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.R"].location) via 'Driver Order' OBRIG-Rabbit/FootRoll.R/BONE_LOCAL() via 'RNA Target -> Driver' Dependency cycle detected: OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() depends on OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.L"].location) via 'Driver -> Driven Property' OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() via 'RNA Target -> Driver' Dependency cycle detected: OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() depends on OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.L"].location) via 'Driver -> Driven Property' OBRIG-Rabbit/Parameters Component/DRIVER(pose.bones["FootRoll.L"].location) via 'Driver Order' OBRIG-Rabbit/FootRoll.L/BONE_LOCAL() via 'RNA Target -> Driver' Detected 4 dependency cycles ERROR (bke.anim_sys): ../source/blender/blenkernel/intern/anim_sys.c:4160 BKE_animsys_eval_driver: invalid driver - (null)[0] ERROR (bke.anim_sys): ../source/blender/blenkernel/intern/anim_sys.c:4160 BKE_animsys_eval_driver: invalid driver - (null)[0] ```
Added subscriber: @dfelinto
Changed status from 'Confirmed' to: 'Needs User Info'
@ErickNyanduKabongo (cc @Alaska) this file is too complex (52MB). It is up to the reporter (or the community) to simplify it before it can be considered confirmed.
Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly. The file should be as small as possible.
@ErickNyanduKabongo (cc @Alaska) this file is too complex (52MB). It is up to the reporter (or the community) to simplify it before it can be considered confirmed. Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly. The file should be as small as possible.
Author
This is a .blend file from Blendercloud, did you ask the Blendercloud people to confirm the crash? Can they simplify the file? This report is me indirectly pointing a problem that they have in the Blendercloud.
> In #77192#942529, @dfelinto wrote: > @ErickNyanduKabongo (cc @Alaska) this file is too complex (52MB). It is up to the reporter (or the community) to simplify it before it can be considered confirmed. > > Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly. The file should be as small as possible. This is a .blend file from Blendercloud, did you ask the Blendercloud people to confirm the crash? Can they simplify the file? This report is me indirectly pointing a problem that they have in the Blendercloud.
Added subscriber: @Sergey
I didn't know this file was from the blendercloud.
Still, it would have helped if someone could simplify it, but I will do it myself.
#1 0x0000000002bd9444 in DEG::DepsgraphRelationBuilder::build_driver_relations(DEG::IDNode*) (this=0x7fffffffcec0, id_node=0x7fffc948e288)
Full backtrace: P1441
I didn't know this file was from the blendercloud. Still, it would have helped if someone could simplify it, but I will do it myself. `#1 0x0000000002bd9444 in DEG::DepsgraphRelationBuilder::build_driver_relations(DEG::IDNode*) (this=0x7fffffffcec0, id_node=0x7fffc948e288)` Full backtrace: [P1441](https://archive.blender.org/developer/P1441.txt)
Added subscriber: @mont29
This is trivial fix, just missing check for NULL rna path in driver (which is done everywhere else in code)... Fix incoming.
Bastien Montagne self-assigned this 2020-06-02 10:19:06 +02:00
This issue was referenced by 428c0f9ad5
This issue was referenced by 428c0f9ad57315cb23a9b50ada547654f34b9b5d
Thomas Dinges added this to the 2.83 LTS milestone 2023-02-08 16:35:43 +01:00
7 Participants
Reference: blender/blender#77192
