Display bug in shading and overlays #77282
Reference: blender/blender#77282
Operating system: macOS 10.15.4
Graphics card: Radeon RX 580 8 GB
Broken:
2.82a 2020-03-20
2.80 2019-07-29
Worked: -
Display bug in shading when Clip Start value is too low:
Display bug in overlays when Clip End value is too high:
I can reproduce it with Blender 2.80 2019-07-29.
Someone on Blenderartists says he has the same thing on Windows 10:
Weird screen effects in Solid Viewport Shading
With the default startup file:
Added subscriber: @Loopkin
Added subscriber: @Jeroen-Bakker
Clip start and end is used to define the area where a 24 bit float value is used for depth precision. Setting these values to extreme values means that you decrease the depth precision and that gives artifacts. Decreasing the range will improve the depth precision.
This is a limitation of GPU rasterization we should improve the help text and manual as this is a common mistake.
Added subscriber: @deadpin
The manual already has a very visible orange warning box explaining the situation- [x]. Since that has existed for some time, and users still inadvertently run into issues quite frequently, I think it's time for a more direct UI indicator now.
Just an example below of what it could look like[2]:
OK thank's, so this not a bug.
Maybe a UI warning is actually a good idea !
Added subscriber: @iss
+1 for warning in UI. There are like 50 identical reports. @deadpin you should make patch for UI team to review.
Since this is not bug, report will be closed.
