Crash when typing negative numbers. #77289
Closed
opened 2020-06-03 01:42:15 +02:00 by Daniel Santana · 5 comments
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-02 22:21, hash: 2e52b3206c
Worked: 2.83 Beta
Open blender.
Select Cube.
Press N.
Type -2.3m on any of the location coordinates. = Crash
Call Stack:
blender.exe!user_string_to_number(bContext * C, const unsigned char * str, const UnitSettings * unit, int type, double * r_value) Line 305
	at D:\dev\blender\blender\source\blender\editors\util\numinput.c(305)
blender.exe!ui_set_but_string_eval_num_unit(bContext * C, uiBut * but, const unsigned char * str, double * r_value) Line 2818
	at D:\dev\blender\blender\source\blender\editors\interface\interface.c(2818)
blender.exe!ui_but_string_set_eval_num(bContext * C, uiBut * but, const unsigned char * str, double * r_value) Line 2880
	at D:\dev\blender\blender\source\blender\editors\interface\interface.c(2880)
blender.exe!ui_but_string_set(bContext * C, uiBut * but, const unsigned char * str) Line 3030
	at D:\dev\blender\blender\source\blender\editors\interface\interface.c(3030)
blender.exe!ui_apply_but_NUM(bContext * C, uiBut * but, uiHandleButtonData * data) Line 1063
	at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(1063)
blender.exe!ui_apply_but(bContext * C, uiBlock * block, uiBut * but, uiHandleButtonData * data, const bool interactive) Line 2111
	at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(2111)
blender.exe!button_activate_exit(bContext * C, uiBut * but, uiHandleButtonData * data, const bool mousemove, const bool onfree) Line 8093
	at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(8093)
blender.exe!ui_handle_button_event(bContext * C, const wmEvent * event, uiBut * but) Line 8873
	at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(8873)
blender.exe!ui_handler_region_menu(bContext * C, const wmEvent * event, void * UNUSED_userdata) Line 10729
	at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(10729)
blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Line 625
	at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(625)
blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2745
	at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(2745)
blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2857
	at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(2857)
blender.exe!wm_event_do_handlers(bContext * C) Line 3286
	at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(3286)
blender.exe!WM_main(bContext * C) Line 478
	at D:\dev\blender\blender\source\blender\windowmanager\intern\wm.c(478)
blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 530
	at D:\dev\blender\blender\source\creator\creator.c(530)
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-02 22:21, hash: `2e52b3206c` Worked: 2.83 Beta **Short description of error** Crash when typing negative numbers. **Exact steps for others to reproduce the error** Open blender. Select Cube. Press `N`. Type -2.3m on any of the location coordinates. = Crash Call Stack: ``` blender.exe!user_string_to_number(bContext * C, const unsigned char * str, const UnitSettings * unit, int type, double * r_value) Line 305 at D:\dev\blender\blender\source\blender\editors\util\numinput.c(305) blender.exe!ui_set_but_string_eval_num_unit(bContext * C, uiBut * but, const unsigned char * str, double * r_value) Line 2818 at D:\dev\blender\blender\source\blender\editors\interface\interface.c(2818) blender.exe!ui_but_string_set_eval_num(bContext * C, uiBut * but, const unsigned char * str, double * r_value) Line 2880 at D:\dev\blender\blender\source\blender\editors\interface\interface.c(2880) blender.exe!ui_but_string_set(bContext * C, uiBut * but, const unsigned char * str) Line 3030 at D:\dev\blender\blender\source\blender\editors\interface\interface.c(3030) blender.exe!ui_apply_but_NUM(bContext * C, uiBut * but, uiHandleButtonData * data) Line 1063 at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(1063) blender.exe!ui_apply_but(bContext * C, uiBlock * block, uiBut * but, uiHandleButtonData * data, const bool interactive) Line 2111 at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(2111) blender.exe!button_activate_exit(bContext * C, uiBut * but, uiHandleButtonData * data, const bool mousemove, const bool onfree) Line 8093 at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(8093) blender.exe!ui_handle_button_event(bContext * C, const wmEvent * event, uiBut * but) Line 8873 at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(8873) blender.exe!ui_handler_region_menu(bContext * C, const wmEvent * event, void * UNUSED_userdata) Line 10729 at D:\dev\blender\blender\source\blender\editors\interface\interface_handlers.c(10729) blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Line 625 at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(625) blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2745 at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(2745) blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2857 at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(2857) blender.exe!wm_event_do_handlers(bContext * C) Line 3286 at D:\dev\blender\blender\source\blender\windowmanager\intern\wm_event_system.c(3286) blender.exe!WM_main(bContext * C) Line 478 at D:\dev\blender\blender\source\blender\windowmanager\intern\wm.c(478) blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 530 at D:\dev\blender\blender\source\creator\creator.c(530) ```
Author
Added subscriber: @dgsantana
Hans Goudey self-assigned this 2020-06-03 02:33:38 +02:00
Member
Member
I can get this to crash on a debug build with ASAN. Not sure if it crashes in other configurations too.
This issue was referenced by a5e9f024f2
This issue was referenced by a5e9f024f21c76fd53c4734f287f043c3bc0beca
Member
Reference: blender/blender#77289
