Invisible loose edges on objects used in bone visualization #77496
Closed
opened 2020-06-06 11:30:46 +02:00 by Erick Tukuniata · 11 comments
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-05 12:32, hash: a6cd77bad1
Worked: 02.06.2020 build hash: cecda64e2e
In the latest versions, one of the bones in the attached file has disappeared.
This is because the object used to view it has become invisible.
File where the bug was identified:
girl_bug.blend
Open the bone_w_loose_edge_obj_bug.blend file in the latest master notice that FK_forearm.L is missing in pose mode and object mode.
Open the same file in the 02.06.2020 build and the bone should be there.
Simplified file revealing the bug:
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-05 12:32, hash: `a6cd77bad1` Worked: 02.06.2020 build hash: cecda64e2ead **Short description of error** In the latest versions, one of the bones in the attached file has disappeared. This is because the object used to view it has become invisible. File where the bug was identified: [girl_bug.blend](https://archive.blender.org/developer/F8586307/girl_bug.blend) **Exact steps for others to reproduce the error** Open the `bone_w_loose_edge_obj_bug.blend` file in the latest master notice that FK_forearm.L is missing in pose mode and object mode. Open the same file in the 02.06.2020 build and the bone should be there. Simplified file revealing the bug: [bone_w_loose_edge_obj_bug.blend](https://archive.blender.org/developer/F8602355/bone_w_loose_edge_obj_bug.blend)
Added subscriber: @ErickNyanduKabongo
Added subscriber: @mano-wii
The bone is invisible because the object related to it is invisible. And it looks like a bug.
I will update the description.
The bone is invisible because the object related to it is invisible. And it looks like a bug. I will update the description.
Germano Cavalcante changed title from Bone had disappeared in pose mode and object mode to Lose edges of objects used for bone visualization are sometimes invisible 2020-06-08 19:34:49 +02:00
@mano-wii Thanks for simplifying the file. Now with your posted file i can crash Blender if i click the TAB-key, about less then 4 times. It seems like you have exposed more problems
Member
Added subscriber: @Jeroen-Bakker
Member
Issue introduced by {bf34b0c8f4b8c64bcc4ec0f3371d343e9c2fe029}
Jeroen Bakker self-assigned this 2020-06-09 09:56:22 +02:00
Member
[D7962: Fix #77342: Fail to draw loose edges](https://archive.blender.org/developer/D7962) seems to fix it partly.
Germano Cavalcante changed title from Lose edges of objects used for bone visualization are sometimes invisible to Invisible loose edges on objects used in bone visualization 2020-06-09 14:06:53 +02:00
Member
I have a possible area to look at. Overlay_armature calls drw_batch_cache_generate_requested directly. this creates a second instance of batch extraction tasks and it won't be completed as it used to be.
/* TODO(fclem) needs to be moved elsewhere. */
  drw_batch_cache_generate_requested(custom);
might get in our way and we should move it somewhere else. Removing these fixes the issue for small files. larger files crash as the batches aren't up to date.
diff --git a/source/blender/draw/engines/overlay/overlay_armature.c b/source/blender/draw/engines/overlay/overlay_armature.c
index 95fd918f8c1..9e52d8ece4e 100644
--- a/source/blender/draw/engines/overlay/overlay_armature.c
+++ b/source/blender/draw/engines/overlay/overlay_armature.c
@@ -567,7 +567,7 @@ static void drw_shgroup_bone_custom_solid(ArmatureDrawContext *ctx,
-  drw_batch_cache_generate_requested(custom);
+  // drw_batch_cache_generate_requested(custom);
 static void drw_shgroup_bone_custom_wire(ArmatureDrawContext *ctx,
@@ -591,7 +591,7 @@ static void drw_shgroup_bone_custom_wire(ArmatureDrawContext *ctx,
 static void drw_shgroup_bone_custom_empty(ArmatureDrawContext *ctx,
I have a possible area to look at. Overlay_armature calls drw_batch_cache_generate_requested directly. this creates a second instance of batch extraction tasks and it won't be completed as it used to be. ``` /* TODO(fclem) needs to be moved elsewhere. */ drw_batch_cache_generate_requested(custom); ``` might get in our way and we should move it somewhere else. Removing these fixes the issue for small files. larger files crash as the batches aren't up to date. ``` diff --git a/source/blender/draw/engines/overlay/overlay_armature.c b/source/blender/draw/engines/overlay/overlay_armature.c index 95fd918f8c1..9e52d8ece4e 100644 --- a/source/blender/draw/engines/overlay/overlay_armature.c +++ b/source/blender/draw/engines/overlay/overlay_armature.c @@ -567,7 +567,7 @@ static void drw_shgroup_bone_custom_solid(ArmatureDrawContext *ctx, } /* TODO(fclem) needs to be moved elsewhere. */ - drw_batch_cache_generate_requested(custom); + // drw_batch_cache_generate_requested(custom); } static void drw_shgroup_bone_custom_wire(ArmatureDrawContext *ctx, @@ -591,7 +591,7 @@ static void drw_shgroup_bone_custom_wire(ArmatureDrawContext *ctx, } /* TODO(fclem) needs to be moved elsewhere. */ - drw_batch_cache_generate_requested(custom); + // drw_batch_cache_generate_requested(custom); } static void drw_shgroup_bone_custom_empty(ArmatureDrawContext *ctx, ```
This issue was referenced by 624994caa2
This issue was referenced by 624994caa2544823a1c89a868e9bf6760f525269
Member
Reference: blender/blender#77496
