Animating modifier expandability no longer working #77502
Reference: blender/blender#77502
Operating system: Windows 7
GPU: Radeon Vega 64
GPU Software Version: 20.4.2 (2020.0515.1537.28108)
CPU: Intel Core i7-5960X
Blender Version(s)
(listed are versions tested)
Working:
2.79 (sub 00), branch: master, commit date: 2018-03-22 14:10, hash: f4dc9f9d68b, type: Release, build date: 2018-03-22, 09:59 AM
through
Working:
blender-2.90.0-2e52b3206cc6-windows64
Broken:
blender-2.90.0-b74cc23dc478-windows64
I assume is the culprit:
9b099c8612
Animating the expandability of modifiers doesn't work in the listed broken version(s) anymore.
It's useful to "group" them for different frame ranges, as not all of them are usually needed at one time, this helps keep a tidy UI when they're not actively in use.
Exact steps for others to reproduce the error from scratch
Open working version
Add modifiers
Key the
Expanded
toggleOpen in broken version
No animation
I didn't read any discussion in the Differentials about the intentional removal of this, so I assume this is a bug.
Added subscribers: @ChristopherAnderssarian, @HooglyBoogly
Well, I can't read
Added subscriber: @dr.sybren
This seems to be only partially related to animation, as this also doesn't work:
However, that also didn't work before
9b099c8612
. I can confirm that animating the property did work before that commit, and no longer after it, though.Animating expandability no longer workingto Animating modifier expandability no longer workingThis diff fixes the Python issue I described above, at least for Blender before
9b099c8612
. After that it still doesn't work, both for animation & setting directly in Python. @HooglyBoogly can you take a look?@dr.sybren Thanks for looking into this. I have a hunch why expansion animating isn't working after the patch. The UI's "get expansion" callback should happen before "set expansion." It's probably backwards now.
This is a downside of using the regular panel-expansion arrows for expanding the modifier layouts.
I have a fix for setting the expansion with python, but I'm not sure keyframing will work without larger work. Maybe a refactor tying panel expansion to an RNA property, or a hacky way to redirect "i" keyframing there to some property.
Neither option seems particularly good though, so I think I have to classify this as a known issue.
I talked with @JulianEisel about this too. The fact that this worked in the first place wasn't exactly intended. The modifier expansion is UI data, so animating it already brings us into gray area.
The fix I'll commit later should fix replaying existing modifier expansion "animations," but keyframing new ones won't be possible in the UI. A work-around for that is keyframing in python:
C.active_object.modifiers- [x].keyframe_insert(data_path="show_expanded")
Not sure there's any reason to keep this open anymore. Animating UI data is generally not expected to work.
For the record, I agree with this.
