Unregistering DATA_PT_modifiers doesn't remove modifier panels #77541
Closed
opened 2020-06-07 00:39:44 +02:00 by Antti Tikka · 5 comments
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-06 14:18, hash: aed11c673e
Worked: 2.90 before the new modifier panels
Unregistering DATA_PT_modifiers doesn't remove panels after the new modifier panels were introduced. I use that for the Modifier List addon.
Add some modifiers to the default cube and run the following code:
from bl_ui.properties_data_modifier import DATA_PT_modifiers
from bpy.utils import unregister_class
unregister_class(DATA_PT_modifiers)
Only the modifier menu disappears but the panels stay.
However, modifiers added after that don't appear. E.g.:
 bpy.context.object.modifiers.new("Array", 'ARRAY')
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-06 14:18, hash: `aed11c673e` Worked: 2.90 before the new modifier panels **Short description of error** Unregistering DATA_PT_modifiers doesn't remove panels after the new modifier panels were introduced. I use that for the Modifier List addon. **Exact steps for others to reproduce the error** Add some modifiers to the default cube and run the following code: ``` from bl_ui.properties_data_modifier import DATA_PT_modifiers from bpy.utils import unregister_class unregister_class(DATA_PT_modifiers) ``` Only the modifier menu disappears but the panels stay. However, modifiers added after that don't appear. E.g.: ``` bpy.context.object.modifiers.new("Array", 'ARRAY') ```
Author
Added subscriber: @Symstract
Hans Goudey was assigned by Antti Tikka 2020-06-07 00:40:50 +02:00
Member
Member
Thanks for the report, I'll deal with this as soon as possible. If there are any other problems you run into let me know. I will admit I didn't fully make sure what you're doing works yet, but I fully plan to.
This issue was referenced by ec25084f5a
This issue was referenced by ec25084f5a404cbca4ceffd659d46b21c758522a
Member
Reference: blender/blender#77541
