Crash in VR Session when opening the Material Tab #77830
Closed
opened 2020-06-13 12:25:02 +02:00 by Jens · 8 comments
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
OpenXR Runtime: SteamVR beta Version 1.13.2 (1591853506) Built 11. Jun 2020 um 07:31
HMD: Valve Index
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-12 17:01, hash: fd8d245e6a
Worked: unknown / none
Addon Information
Name: VR Scene Inspection (0, 2, 0)
Author: Julian Eisel (Severin)
Blender crashes when opening the Material Tab of the Properties Editor in a running VR Session (observerd with SteamVR).
Method 1:
  • Start with a default startup scene
  • Make sure the Material Tab of the Properties Editor is not yet opened
  • Start a VR Session using the VR Scene Inspection Addon
  • Select an object that has a material assigned (e.g. the default Cube)
  • Open the Material Tab of the Properties Editor
Method 2:
  • Open the Material Tab of the Properties Editor before starting the VR Session
  • Change the Base Color of the material in the Material Tab
Notes
Blender 2.90.0 Alpha as well as 2.83.0 are affected.
I was testing out the new OpenXR Developer Preview for SteamVR using the Valve Index:
https:store.steampowered.com/newshub/app/250820/view/2396425843528787269(So happy this is actually working at least on Windows now :D Can't wait for Linux support)//
Changing the Base Color of the material using nodes in the Shader Editor in a VR Session does not crash Blender.
The issue can be reproduced using just the default scene.
Never the less here is the blend file that I used to recreate the problem in case it might be of any use:
vr-crash-material-tab.blend
Crash log is here:
vr-crash-material-tab.crash.txt
Speculation:
In both methods to reproduce the problem as described above, it always takes about 3 seconds after the last step for Blender to crash.
This is also, as far as I can tell, exactly the time it takes until the Material preview icons are rendered without a VR Session
(also they never appear for me before the crash).
So my guess is that the rendering of the material preview / preview icons is causing the crash.
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14 OpenXR Runtime: SteamVR beta Version 1.13.2 (1591853506) Built 11. Jun 2020 um 07:31 HMD: Valve Index **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-12 17:01, hash: `fd8d245e6a` Worked: unknown / none **Addon Information** Name: VR Scene Inspection (0, 2, 0) Author: Julian Eisel (Severin) **Short description of error** Blender crashes when opening the Material Tab of the Properties Editor in a running VR Session (observerd with SteamVR). **Exact steps for others to reproduce the error** Method 1: - Start with a default startup scene - Make sure the Material Tab of the Properties Editor is not yet opened - Start a VR Session using the VR Scene Inspection Addon - Select an object that has a material assigned (e.g. the default Cube) - Open the Material Tab of the Properties Editor Method 2: - Start with a default startup scene - Select an object that has a material assigned (e.g. the default Cube) - Open the Material Tab of the Properties Editor before starting the VR Session - Start a VR Session using the VR Scene Inspection Addon - Change the Base Color of the material in the Material Tab **Notes** Blender 2.90.0 Alpha as well as 2.83.0 are affected. I was testing out the new OpenXR Developer Preview for SteamVR using the Valve Index: https:*store.steampowered.com/newshub/app/250820/view/2396425843528787269*(So happy this is actually working at least on Windows now :D Can't wait for Linux support)// Changing the Base Color of the material using nodes in the Shader Editor in a VR Session does **not** crash Blender. The issue can be reproduced using just the default scene. Never the less here is the blend file that I used to recreate the problem in case it might be of any use: [vr-crash-material-tab.blend](https://archive.blender.org/developer/F8614987/vr-crash-material-tab.blend) Crash log is here: [vr-crash-material-tab.crash.txt](https://archive.blender.org/developer/F8615002/vr-crash-material-tab.crash.txt) Speculation: In both methods to reproduce the problem as described above, it always takes about 3 seconds after the last step for Blender to crash. This is also, as far as I can tell, exactly the time it takes until the Material preview icons are rendered without a VR Session (also they never appear for me before the crash). So my guess is that the rendering of the material preview / preview icons is causing the crash.
Author
Added subscriber: @Jens.Ne
Member
Added subscribers: @JulianEisel, @dfelinto, @lichtwerk
Member
Member
@dfelinto, @JulianEisel: judging your actions, I assume this can be confirmed? [I cannot check myself...]
I believe I was just illustrating the use of the workboard columns and auto-tagging :)
This issue was referenced by 089ff4a1dd
This issue was referenced by 089ff4a1ddedae0974f8deec49dad436bb1523d9
This issue was referenced by 2dd60e6c2c
This issue was referenced by 2dd60e6c2cbdf3e39ed3451ee0f67a5b00a7a5bc
Member
Julian Eisel self-assigned this 2020-06-23 17:29:32 +02:00
Thomas Dinges added this to the 2.90 milestone 2023-02-08 16:27:13 +01:00
5 Participants
Reference: blender/blender#77830
