Add Cube scales immediately upon creation after changing Size attribute on prior Add Cube command. #77942
Closed
opened 2020-06-17 05:39:03 +02:00 by Ryan McGowan · 9 comments
Create a Cube object with the Add Cube button. After creation, change the Size attribute in the pop-up modal.
Create another Cube with the button. The new Cube scales immediately after creation in proportion to the Size attribute. The size attribute should be reset to the default value upon clicking the Add Cube button.
Workaround: Setting the Size field to 78.74 inches (imperial, 2.0 meters metric) appears to return the desired behavior.
Note, the Size attribute is somewhat vague and unintuitive here, particularly for this tool which is not strictly cubic shapes. There should be a field for Length, Width, and Height instead linked to the Transform values. Please consider the tool name "Add Box" instead.
Graphics card: GeForce 940MX/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.45
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-12 17:01, hash: fd8d245e6a
Create a Cube object with the Add Cube button. After creation, change the Size attribute in the pop-up modal. Create another Cube with the button. The new Cube scales immediately after creation in proportion to the Size attribute. The size attribute should be reset to the default value upon clicking the Add Cube button. Workaround: Setting the Size field to 78.74 inches (imperial, 2.0 meters metric) appears to return the desired behavior. Note, the Size attribute is somewhat vague and unintuitive here, particularly for this tool which is not strictly cubic shapes. There should be a field for Length, Width, and Height instead linked to the Transform values. Please consider the tool name "Add Box" instead. **System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce 940MX/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.45 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-12 17:01, hash: `fd8d245e6a` Worked: (newest version of Blender that worked as expected) **Short description of error** [Please fill out a short description of the error here] **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @RyanJMcGowan
This issue was referenced by 26e5718e29
This issue was referenced by 26e5718e29a708d8feb31f11c0fd8f59697dee70
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2020-06-17 13:07:31 +02:00
Member
Member
I agree it does not really make sense to use the size from the prior call here.
Member
Will classify as TODO though, since it is an enhancement and not really a bug per se.
Author
The aspect of it scaling uncontrollably, and not being apparent where or what is causing it smells like a bug and not so much a feature from the user's perspective. That aspect at a minimum I feel needs to fixed before a full release. Simply reset the Size parameter to 2 meters on the button click, and that problem goes away.
Member
[D8056: Fix #77942: Add Cube scales immediately upon creation after changing Size attribute on prior Add Cube command](https://archive.blender.org/developer/D8056) does that, yes, just needs review
Member
Reference: blender/blender#77942
