Node wrangler is not working on blender 2.9 [SOLVED] #78260
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#78260
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-22 22:06, hash:
blender/blender@51bf04383a
Addon Information
Name: Node Wrangler (3, 37)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
The principled texture setup is not working on this version and the 2.83.
It's not possible to use the feature "Principled texture setup" because it does not work:
Added subscriber: @AugustoCezar
Added subscriber: @lichtwerk
Seems like you are having your .blend file on one drive and the textures on another.
If this is the case and in addition you have Node Wranglers
Relative Path
option setthis can then not be resolved to a relative path...
Does it work if
Relative Path
is unchecked?I turned off the relative path and it works!
Thank you! I was so simple... haha
Node wrangler is not working on blender 2.9to Node wrangler is not working on blender 2.9 [SOLVED]Changed status from 'Needs User Info' to: 'Resolved'
While this might be handled more gracefully in the future, will not consider this a bug atm. and close then, thx reporting anyways!
Added subscriber: @cg_petey
Where do you find the relative paths checkbox. There is no checkbox in my Nodewrangler addon. I cant tell what screen that is from because it is cropped.
Added subscriber: @SantoshSatish
I can't find it too!
Push that gear icon top right in the blender file browser or {key N}
I still can't find it :(
Added subscriber: @Metathavoc2090
Hey there,
For those who are using Blender verison 2.91 and can't find the " Node Wrangler" add-on. What you have to do is uncheck " Enable Add-ons Only" box then type "Node Wrangler" in the search bar . It will then pop up, and then you'll see a white box on the left hand side of "Node: Node Wrangler", click it. Then click " Enable Add-ons only" again. And you are good to go! Hope this helps!
Added subscriber: @bitter_stick0
this fix the problem, thanks
