If object is reference for 2 shrinkwraps, entering it`s edit mode crashes Blender. #78285
6 Participants
Reference: blender/blender#78285
Bisecting points to
0945a79ed1
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-24 21:51, hash:
ec776f18ff
Worked: blender-2.90.0-ab8a6914317f-windows64.zip
Create a file using the steps shown below or download the .blend file. Select the sphere and enter edit mode and Blender should crash. You may need to enter edit mode a few times for this bug to occur.
2020-06-26_05-29-42.mp4
untitled1.blend
Original steps:
There is two shrinkwraps on two fingers. And if both enabled in viewport, I have crash, when I try to enter edit mode for hand.
Yes, tested with factory settings too, the same.
untitled.blend
2020-06-26_05-12-19.mp4
Added subscriber: @Vyach
#78546 was marked as duplicate of this issue
Okay. I reproduced it with simple file.
untitled1.blend
Bugged file, Blender crashes: entering edit mode to object, that is reference for 2 shrinkwrapsto If object is reference for 2 shrinkwraps, entering it`s edit mode crashes Blender.Added subscriber: @Alaska
Can confirm.
Linux-5.4.0-7634-generic-x86_64-with-debian-bullseye
GTX 1050Ti
2.90.0
646ef49e197d
In some cases you'll have to enter edit mode multiple times for the crash to occur.
Will bisect now (
e079bf6996
still produces errors for me).Added subscriber: @ideasman42
Bisecting points to
0945a79ed1
CC @ideasman42
Added subscribers: @BassamKurdali, @iss
Added subscribers: @Sergey, @brecht, @mont29
reading a bit this code, it looks to me like a critically thread-unsafe one!
BKE_mesh_runtime_looptri_ensure
use a specific, global (!!!) RW mutex. AND it only uses it to generate the data, the return a pointer to said data, on which there is absolutely no way to guarantee it won't be freed by another thread while being used?BKE_bvhtree_from_mesh_get
& co get and partially use the runtime mutex of the mesh.BKE_mesh_wrapper_ensure_mdata
is not protected at all. While being called fro threads. Like...IMHO all those should use exclusively the mesh's runtime mutex (RW mutexes give very little benefit in general anyway). @brecht, @Sergey, what do you think?
Again one point where having re-entrant mutexes would have been nice, btw... keeping a proper sane usage of that runtime mutex is likely going to be challenging.
PS: note that
0945a79ed1
is not the only cause of the issue here, still get crash when it is reverted.It is preferable to use the per-mesh mutex when possible.
However if a thread is going to create looptri data and then free it, then the mesh should not have been modified at all? The data can be stored in an array separate from the mesh and each thread can make their own copy and free it aftwards.
If the intent is to do lazy creation and keep it afterwards, then you need a mutex.
I find re-entrant mutexes very hard to understand, I would not use them at all.
General rule is to not modify someone's else data. Without this you will either run into issues like this, or will reduce occupancy of threads during evaluation.
The idea was always to extend datamask reported by modifiers to also extend it to what they need from operands. This will allow the "target" mesh to make sure looptri, bvh and what not is evaluated in the thread local to the corresponding mesh, without having threads wait on data.
For the freeing part i am confused. If data is supposed to be temp, then it should not be stored in the object at all. This is what Brecht already pointed out i think.
Safest fix would be:
Longer term fix: communicate datamask to other objects via the dependency graph, prepare lazily initialzed data ahead of the time.
This issue was referenced by
e2e87efea2
ade7603379
4e6975ffd6
