Eevee Motion blur crash rendering animation with steps set to higher value #78321
14 Participants
Reference: blender/blender#78321
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-25 21:53, hash:
62aa103d48
Blender crashes while trying to render an animation with Motion Blur enabled and wildly spinning cube in it. Apparently Steps value playing a role in it, since crash happens when I set Steps to anything above 4 increasingly faster - if on 5 it will render ~40 frames, on 16 steps it's rarely passing father than 15th frame.
cube2.blend
Added subscriber: @ostapblender
#79093 was marked as duplicate of this issue
#79039 was marked as duplicate of this issue
#78739 was marked as duplicate of this issue
#78483 was marked as duplicate of this issue
#78528 was marked as duplicate of this issue
#78329 was marked as duplicate of this issue
#78372 was marked as duplicate of this issue
Added subscriber: @JoranKlaui
Added subscriber: @Big_Blend
Added subscribers: @Eary, @chafouin
Added subscriber: @iss
I got somewhat random stack trace, but always in
bpy_class_call
Added subscriber: @smramsay
#78528 and #78483 seem to be related to the same issue
Added subscriber: @sharaths21312
Added subscriber: @fclem
I'm pretty sure it's not the motion blur patch causing this as I experienced that before its development. @iss could you bisect to find when this started?
Also another trick to see if that's really linked to motion blur is to set Render In Keep Interface in the user preference temp window setting.
Will check this out.
Can not reproduce before
439b40e601
No change after setting this.
Added subscribers: @AmirShehata, @mano-wii
Added subscriber: @V-prime
I did some testing by running Blender from the command line with 'blender.exe -b blur.blend -a' after which it rendered a full 250 frame animation without any problems. The 'Keep Interface' option didn't change anything for me, but this does indeed confirm it is the fault of an underlying problem.
BlurRender.mp4
Added subscriber: @ZachHixson
I've been running into the same problem, and also found that rendering from the command line fixes crashing when using motion blur.
Also in certain scenes where I was testing motion blur, I found that raising motion blur steps seems to increase the chance of a crash, but raising the "Max Blur," lowers the chance of a crash if the steps have been increased. I don't know if this is just a coincidence, but it might be worth looking into.
This comment was removed by @fclem
Added subscribers: @Sergey, @brecht
After investigation it seems to be related to python & threading.
Removing the calls to
RE_engine_frame_set
fix the issue but obvisouly removes the motion blur.In cycles the
frame_set
calls are protected bypython_thread_state_restore(python_thread_state);
andpython_thread_state_save(python_thread_state);
.I tried using the
BPy_BEGIN_ALLOW_THREADS
&BPy_END_ALLOW_THREADS
pair to protect theRE_engine_frame_set
call ineevee_render_to_image
but it seems to have no effect.@Sergey @brecht I know little about python issues with threading. What is be the correct way to fix this?
Added subscriber: @EAW
You_Can_Act.crash.txt
You_Can_Act_v2.crash.txt
You_Can_Act.crash4.txt
You_Can_Act.crash3.txt
From the first 2 stack traces:
Added subscriber: @TheCrowdedOne
Note: I couldn't get it to crash using a debug build.
Added subscriber: @Ben100
@fclem, the
RE_engine_frame_set
already containsBPy_BEGIN_ALLOW_THREADS
andBPy_END_ALLOW_THREADS
. From from reading some code and doing a guess, did you try to add similarpython_thread_state_restore
/python_thread_state_save
in theeevee_render_to_image
?The Python stuff here is only really needed when calling frame set from the Python API. What it does is releases the Python GIL while the depsgraph is being updated, so that other Python code like redrawing the UI can still be done while that happens.
The simplest solution may be to ensure that Python stuff is only done when called through the RNA API, and not when Eevee calls it directly.
A general solution to this would to make add some flag to RNA functions to indicate if they need to save / restore the thread safe, and then heavy function calls like frame set can be marked that way. That way this Python stuff could be isolated to the
python/
module.This issue was referenced by
4432209849
Added subscriber: @aryabaguss
just turn off the motion blur and the render successfull, when i turned on the motion blur it gets crashed anytime.
Added subscriber: @davidmcsween
