"Straighten" operator doesn't always work and isn't well documented in the manual. #78553
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
6 Participants
Reference: blender/blender-manual#78553
Broken: 2.7x, 2.8x
The "Straighten" operator from the UV editor doesn't always work and isn't well documented in the manual.
Open default file
go to the uv editor
press shift W
try to figure out what straighten does, sometimes it aligns vertices in a random direction, sometimes it does nothing.
open the manual
still have no clue.
Added subscriber: @Gilberto.R
Added subscribers: @mano-wii, @ronsn
That's right, thank you! The docs are a little bit fuzzy in this case. We have to be a bit more clear in the description what it does ( https://docs.blender.org/manual/en/dev/modeling/meshes/uv/editing.html#bpy-ops-uv-align )
@mano-wii do you think this is also a case for the documentation team?
It's description is: "Align UVs along the line defined by the endpoints".
Apparently you need to have a sequence of points selected in order to have endpoints.
I agree that this description needs to be improved.
yea, the description isn't true straighten.mp4
Added subscribers: @ideasman42, @Blendify
Not really sure this is an error with the documentation, I find the behavior of the operator a bit strange as pointed out in the video. I would expect the UVs to be scaled to 0 along the axis created between the first and last points, however it seems to be doing something different.
@ideasman42 @mano-wii is this what's expected and there is a bug here too?
Added subscriber: @Chris_Blackbourn
Bug confirmed in debugger
Note that the UV at 1oclock and the UV at 2oclock share XYZ (
bmvert
) in the cube case, but are distinct if the geometry is in the shape of a cross.Fix with some new functionality (Align Circle, Align Fit, pinned UV support) taking shape over at https://developer.blender.org/D15121
Caution: Code is very rough.
blender/blender@9dd27a2c87 & {rBM9392} have been committed. Closing.
