Extrude manifold on multiple non-adjacent faces gives wrong results #78635
5 Participants
Reference: blender/blender#78635
Operating system: Darwin-19.5.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.9.15
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-28 15:13, hash:
b21ba5e579
Worked: never
When using extrude manifold when multiple non-adjacent faces are selected, you sometimes get some weird and inconsistent results with missing edges.
Default cube -> edit mode
Add one loop cut
Select two opposing faces next to the loop cut
Transform orientation: normal, pivot individual origins
Extrude inwards
Result: ngons on both sides with missing edges where they should be. Also the result is different on both opposing sides.
Image: on the left extruding a single face; on the right extruding multiple faces at once:
Example blend file.
T78635_test.blend
Added subscriber: @blenderrocket
Added subscriber: @iss
I am not sure if I get this correctly. Is it 2 faces that were created from 1 face that has been split by loop cut?
These two faces:
(not specific to this situation, but just the simplest/easiest way I could find to reproduce the problem)
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Thanks for clarification,
I can not reproduce this issue though. I guess it may be only on Mac?
Added subscriber: @jenkm
I can confirm.
#78635.blend
{F8812174, size=full}
@blenderrocket I am looking at older reports, is this still an issue? Or have anything changed?
Results unchanged with 2.92.0 Alpha, branch: master, commit date: 2020-11-27 15:18, hash:
fbdf1af355
Thanks for update.
Added subscriber: @lichtwerk
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Might be the same as {#80440}?
Note #75913 (New tool to add and subtract prismatic volumes) is already there to subtract in a better way.
Will confirm this for now though since this is also an issue with extruding outwards [which was not the case with #80440]
Added subscribers: @mano-wii, @ideasman42
This looks close to #80440, with the difference that this particular case is supported when extruding a single face, and not when the same faces are being cut from two different directions.
@mano-wii CC'ing you incase you'd like to check on this case.
