The Optix denoiser is influencing Open Image Denoiser results even when it's disabled. #78692
Closed
opened 2020-07-07 01:27:44 +02:00 by Gilberto Rodrigues · 8 comments
Contributor
Operating system: Windows 10
Graphics card: GTX 1060m
Broken: 2.90 alpha (hash: baf124c753)
the Optix denoiser affects the Open Image Denoiser render results even when it's toggle is disabled. So it's only really disabled when the denoising option is set to NLM.
I rendered this scene with using low number of samples, so that the difference is more evident. Please watch the whole video.
2020-07-06 19-54-17.mp4
What strikes me is that for some reason the buggy falsely disabled Optix + OID renders 2X faster than the enabled Optix + OID despite both of the results being very similar. This bug might have an optimization to look on for. I tested with another scene and there is also that 2x render time difference, with the buggy render looking better.
Open or make a blender scene with lots of noise.
change render engine to cycles.
go to the compositing tab and add Open Image Denoise with the correct passes.
put very low number of samples.
Render to see how it should look with only Open Image Denoise.
Now to the render preferences denoising panel and change the render denoiser from NLM to Optix, without enabling it.
Render again. The render will have effect of both Open Image Denoise and OptiX denoising, even though OptiX's toggle is disabled. That's the bug.
Now enable the Optix toggle for render.
Render again, the render result will be the same as the last (OID + OptiX) but the render will be a lot slower than the previous render.
**System Information** Operating system: Windows 10 Graphics card: GTX 1060m **Blender Version** Broken: 2.90 alpha (hash: baf124c753d9) **Short description of error** the Optix denoiser affects the Open Image Denoiser render results even when it's toggle is disabled. So it's only really disabled when the denoising option is set to NLM. I rendered this scene with using low number of samples, so that the difference is more evident. Please watch the whole video. [2020-07-06 19-54-17.mp4](https://archive.blender.org/developer/F8671241/2020-07-06_19-54-17.mp4) What strikes me is that for some reason the buggy falsely disabled Optix + OID renders 2X faster than the enabled Optix + OID despite both of the results being very similar. This bug might have an optimization to look on for. I tested with another scene and there is also that 2x render time difference, with the buggy render looking better. **Exact steps for others to reproduce the error** Open or make a blender scene with lots of noise. change render engine to cycles. go to the compositing tab and add Open Image Denoise with the correct passes. put very low number of samples. Render to see how it should look with only Open Image Denoise. Now to the render preferences denoising panel and change the render denoiser from NLM to Optix, without enabling it. Render again. The render will have effect of both Open Image Denoise and OptiX denoising, even though OptiX's toggle is disabled. That's the bug. Now enable the Optix toggle for render. Render again, the render result will be the same as the last (OID + OptiX) but the render will be a lot slower than the previous render.
Author
Contributor
Added subscriber: @Gilberto.R
Author
Contributor
Added subscriber: @brecht
Author
Contributor
@brecht @pmoursnv
Author
Contributor
Added subscriber: @pmoursnv
What happens is that Cycles will generate different denoising passes depending on the denoiser. The NLM denoiser requires prefiltered passes, which take longer to compute.
We should find a way to communicate this more clearly.
What happens is that Cycles will generate different denoising passes depending on the denoiser. The NLM denoiser requires prefiltered passes, which take longer to compute. We should find a way to communicate this more clearly.
This issue was referenced by blender/cycles@06ccb29b81
This issue was referenced by blender/cycles@06ccb29b812b9857d64aea8cb19f81b3f77b7ed6
This issue was referenced by 95f0f31279
This issue was referenced by 95f0f312799e10e4a9f5c884f8f20ec76d0ff363
Brecht Van Lommel self-assigned this 2020-07-07 15:14:26 +02:00
Reference: blender/blender#78692
