Drivers don't update while rendering an animation #78893
2 Participants
Reference: blender/blender#78893
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-11 18:41, hash:
ee5c2f6ead
Tried: 2.83 releases, 2.82, 2.81, 2.80
Worked: 2.79 (had to recreate the file, but loading that one into 2.8 shows the same behaviour)
When using drivers to for example keep the scaling of an object proportional, the value change will be updated during
However when rendering an animation the drivers will not update and the object will appear stretched.
Frame 17 of an animation render (it happens on all, 17 is just as an example)
Frame 17 rendered by rendering a single frame when the playhead is on frame 17
Render the animation (CRTL+F+12)
Only the x-axis will change, the others will have the value they had in the viewport at the time you've started the render.
driver bug.blend
Added subscriber: @bent
I got a friend to try this out and he faced the same issue.
[[ https://streamable.com/4noar7 | (video link)
His system configuration:
Added subscriber: @iss
This is probably due to dependency cycles. You can see this error in console:
Alright, I wasn't aware that these even exitst. I found the option to use single channels now.
These dependency cycles should put a warning inside the info editor & the status bar and
bpy.ops.ui.copy_as_driver_button()
should use the corresponding transform channel instead of "single property", if available.Blender makes it too easy to make this mistake and pretty much hides it from the user until they try to render.
Is there a design task for drivers?
It's more complicated. Even transform channels only works in render when set to "transform" space. "local" and "world" space will not work.
driver_bug_redux.blend
The manual doesn't mention any of this and it's not happening in 2.79. Is this desired behaviour?
And the console isn't showing anything on dependency cycles when using any of the Transform Channel options, so it's either not detecting these as self references or the issue of the render looking different than the viewport is not directly related to dependency cycles, I guess.
@iss Can you have a look again re the unreported (?) dependency cycles? See my comment above
@bent Sorry I have missed your comment. I don't have clear or deep knowledge what these spaces really mean. Googling for at least brief explanation resulted in #39393. So I guess you could make new report, I am not really sure if it's a bug or not.
