Mirror threshold too high, values less than 0.00002 are snapped to center #79211
Reference: blender/blender#79211
Graphics card: GeForce GTX TITAN X/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.60
Broken: version: 2.83.3, branch: master, commit date: 2020-07-22 06:01, hash:
353e5bd749
Worked: 2.79b
Blender 2.8x has a bug that forces it to snap to the YZ plane with a value less than 0.00002.
The above is occurring with the snap off.
The bug occurs even if the vertex's X coordinate is moved to more than 0.00002.
Duplicating the object does not eliminate the bug.
3D Viewport / Edit Mode.
Create an object with the following vertices:
3D Viewport / Edit Mode / Tool / Options / Mirror X [enable].
3D Viewport / Edit Mode / Snap [disable].
Select Vertex-A and Vertex-B.
Move Vertex-A and Vertex-B.
3D Viewport / Object Mode.
Duplicate the Object-1 to obtain the Object-2.
Mirror the vertices of object 2 as if they were object 1. This causes the same problem.
Enlarge the Object-2 sideways.
Mirror the vertices of Object-2. The same problem still occurs. The problem occurs even if the Vertex-B x-coordinate is greater than 0.00002 after magnification.
X-Mirror_bug.blend
The objects in the X-Mirror_bug.blend file are very small, so zoom in on the view to the maximum size.
This is a 2.79b file with the X-Mirror working correctly:
X-Mirror_2.79b.blend
The difference in x-mirror behavior between 2.8x and 2.79b is shown in the following video:
Blender 2.8x BUG_X-Mirror.mp4
Blender 2.79b X-Mirror.mp4
If it is unintentionally aligned to the YZ plane like 2.8x, it will not be possible to edit it (if this behavior is a specification, it will be useful if you can implement it as a function separate from the mirror, align it to the YZ plane, and set a threshold to align).
When importing model data from the outside and editing a mirror, all vertices with an X coordinate of less than 0.00002 are already implicitly aligned to the YZ plane, so editing with an X mirror is no longer possible at all. Hence, until this bug is fixed, edits involving X mirrors should use 2.79b.
Added subscriber: @p-tone
This comment was removed by @p-tone
2.79b seems to be forced to snap to the YZ plane at less than 0.00001.
It is still desirable to make selective snapping or not, and to make the snapping threshold optional.
If you want to do X-mirror processing and handle model data that includes vertices that should not be snapped to the YZ plane, if the original data to be imported is already in the snap range, the vertices will fall into a state where they cannot be edited arbitrarily.
Maybe it was originally intended to be placed at zero and is a specification to zero alignment when manipulating vertices, but it may be a factor that it's not designed for cases where you don't want to be placed at zero.
Added subscriber: @mano-wii
To detect the mirror elements, each mirror vertex must be within a threshold of 0.0002 considering the center of the mirrored vertex.
In 2.79 the threshold for mirror verts was different from the threshold for vertices that are close to the "mirror". If I'm not mistaken, this other threshold was 0.0001.
0.00002 is now used in both cases.
I'm not sure what this report proposes:
Blender 2.8x has a bug that forces it to snap to the YZ plane with a value less than 0.00002.to Mirror threshold too high, values less than 0.00002 are snapped to center
