GPencil: When cancel a extrude point, the point is not removed and creates two points on same location #79256
2 Participants
Reference: blender/blender#79256
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-28 15:13, hash:
b21ba5e579
When a GPencil point at the end of a stroke is extruded, but the extrusion operation is cancelled before committing it, the Custom Curve of the thickness modifier seems to treat the stroke as though the cancelled point exists (the end of the stroke doesn't have the expected thickness applied by the modifier)
thicknessextrudebug.blend
Added subscriber: @info-27
Added subscriber: @antoniov
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
The thickness modifier is working as expected, but the stroke has 2 points on the same coordinates.
I need review when you escape the extrude to Undo the created point. It looks is undoing the posicion, but must remove the point.
GPencil. Thickness modifier gives incorrect result if point extrude operation is cancelledto GPencil: When cancel a extrude point, the point is not removed and creates two points on same locationChanged status from 'Needs Developer To Reproduce' to: 'Archived'
I have been looking at code and how works a mesh and it has the same issue. If you add a mesh plane, and extrude one vertex and cancel, the vertex is added (now the plane has 5 vertex) but it's in the same location.
The problem is when you extrude (a mesh or a gpencil), you are executing two operatos, first the add point (this cannot be canceled) and later the transform (this can be canceled). As you extruded, but canceled the transform, really you only executed the first operator (add point). In your example, as both points are on the same position in the extreme of the stroke, the thickness modifier cannot calculate propertly the result.
As this is by design and due the internal design of the transform operators (not only for GPencil), we can consider this report is not a bug, but a design limitation in general, so I'm going to close it.
Thanks for the explanation. that helps me find a workaround for my use case.
In the case of a cancelled extrude, could Blender delete the newly created point(s) vertex(es)? or is there some case where you'd want them to remain there?
