Compositor: 'invert' option of the 'Stabilize 2D' node does not work correctly #79563
5 Participants
Reference: blender/blender#79563
Operating system: Win10 64
Graphics card: 3070
Broken: 2.83
Worked: N/A
As indicated in the tip and in the manual, the
invert
option of theStabilize2D
node kind of undoes the stabilization effect and "reintroduces montion to the frame".But in practice, when undoing the stabilization, while the rotation and scale appear to be correct, the image position is incorrect.
Stabilize 2D
node that has theinvert
option enabledThe Transform node can help you see what's going on.
Stabilize2DBug.blend
Added subscriber: @supereggbert
Added subscriber: @iss
It would definitely help if you can provide example file. I would recommend to rendering very simple and short video so that files provided would illustrate the issue clearly. Then simply upload video same way as you upload .blend file.
Here you go hopefully it helps Stabilize2D.zip
Stabilize2d Comp Node Invertto Compositor: 'invert' option of the 'Stabilize 2D' node does not work correctlyChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @mano-wii
Thanks for the file.
It really helps to identify the bug.
File definitely helped.
Looking at code, this doesn't look like bug. Invert property does exactly what it says in manual https://docs.blender.org/manual/en/dev/compositing/types/distort/stabilize_2d.html
Issue here is, that image is scaled, translated and rotated with reference to center of the image. This operation is performed again with inverse values, but reference point is still in the center of image. I think reversing order doesn't apply here really.
This could be resolved by passing reference to new center of image, but I am not aware how this would be useful in real life application.
Thanks for the clarification.
Just as an example of a real life application, I was trying to overlay some cartoon sun glasses on a face and wanted them to track the eyes of a person (position/scale/rotation), something you can typically do with reverse stabilisation.
I think the manual does indicate a bug, it says if "no invert" move up by 5 units then "invert" moves down by 5 units. That isn't the case as in the example blend (previously submitted) you can see the number of units that where moved up with the stabalize doesn't equal the number of units moved down by the invert.
You really shouldn't need to add any additional reference to new center of image as it can be done with some maths and transform nodes (see attached blend with node setup). All that needs to happen is that the order of operation needs to be reversed, ie for stabilize then invert the list of operations are currently:
[Stabilize2d]( scale -> rotate -> translate ) -> [Stabilize2d Invert]( unscale -> unrotate -> untranslate )
but they should be:
[Stabilize2d]( scale -> rotate -> translate ) -> [Stabilize2d Invert]( untranslate -> unrotate -> unscale )
The change won't effect anything without scale and rotation but will make the invert actually useful for case where scale and rotation are used.
Hopefully, the attached blend is helpful in illustrating the problem.
Stabilize2Dfix.zip
Changed status from 'Archived' to: 'Needs Triage'
I closed this after @mano-wii confirmed without noticing that, so I should really reopen this.
Reversing order would work. I stand corrected. But my question was rather why wouldn't you just use original images. This is solely demonstration of bug not real world use case am I correct?
Added subscriber: @Sergey
I did this reverse stabilization trick and you are correct, it doesn't work as expected with stabilize 2D node. I am not sure whether this is intentional or not. I will need info from @sergey.
You can switch between stabilize 2D and desired behavior nodes in this file to see issue clearly:
Stabilize2DFix.zip
yep, the included files are just to show the bug in cleanest way I could. You're right it would be ridiculous to actually do what was in the example, so I can see the confusion.
I think there is even simpler possible demo case: 2D Stabilize -> Inevrted 2D Stabilize. That is supposed to give original image (I think even the black "padding" wouldn't be expected, but my memories are a bit rusty).
Since the Stabilize work, and manual inverted stabilize work, i think it's the wrong order of operations in the
Stabilize2dNode::convertToOperations
for theinvert
case.@iss, Just noticed the task is assigned to you. Are you looking into it? Otherwise i can do it next week.
This issue was referenced by
eca062b9cb
Thanks all :-)
