Crashing/unexpected results while rendering custom Node-defined volumetric materials #79682
Reference: blender/blender#79682
Operating system: Linux-5.6.0-2-amd64-x86_64-with-glibc2.29 64 Bits
Graphics card: AMD Radeon (TM) RX 470 Graphics (POLARIS10, DRM 3.36.0, 5.6.0-2-amd64, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.7
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-11 14:14, hash:
a3af59f8e3
Worked: Never
When rendering the attached .blend file, Blender frequently crashes or at the very least fails to render properly. It seems to be something to do with the materials I've defined for Evee to use.
#79682.blend
Added subscriber: @ethereal.visage
Added subscriber: @EAW
Thank you for the report. I don't experience any crashes when rendering your file using 2.83.4 or 2.91. I tried 4 times using each version.
My results do look different than yours. There isn't any volumetric material in the file as far as I can tell. How are you making the custom materials?
v2.83.4_0001-0024.mp4
In my experience, a string of
Unknown
appears in the version only when using custom builds. Are you able to reproduce the issue with official builds from Blender.org?The current LTS version is 2.83.4. Please download it from the link below and see if it fixes your issue.
https://www.blender.org/download/
Also please try the latest nightly builds from here:
https://builder.blender.org/download/
Tested using
Graphics card: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
2.83.4 and 2.91.0 Alpha, branch: master, commit date: 2020-08-09 00:04, hash:
b522e834ec
My apologies, I attached the wrong .blend file... here's the one I meant to upload: athena-animated-2.blend
that's what I get for trying to get in the bug report before I go to sleep :-)
I just tried with the latest Beta blender build (
version: 2.90.0 Beta, branch: master, commit date: 2020-08-09 12:07, hash: 00162e6b7b0f, type: Release
) and the latest Blender Alpha build (version: 2.91.0 Alpha, branch: master, commit date: 2020-08-09 00:04, hash: b522e834ec30, type: Release
). The Beta build has the same results as the 2.83.1 from the Debian repositories, but progress with the Alpha build! It simply never renders the volumetric effects around the eyes, and also appears to not crash despite repeated runs.I'll play around with the alpha build to see if I can figure out what I need to tweak to get it working there, and then try those changes in the earlier builds to see if that also fixes things.
Changing to not use both surface and volumetric rendering for the same NURBS sphere (which ... makes a lot of sense, I'm now unsure how it was working before?) and to instead put a second 'shell' around the eyes that has the volumetric part of the shader and keeping the surface part of the shader on the original sphere. Everything seems stable / as expected in the alpha version of Blender, but it's still crashing in 2.83.1 and has even worse results in the beta version --- whereas before about one frame in fifty had the rendering difference, now about one frame in five does. I've attached the new .blend I've been using to test this.
nightly_test.blend
Added subscriber: @iss
Please create one report per issue.
Can not reproduce crash either.
I am unsure what the issue with shading is. Please describe what the issue is in short sentence, make example file as simple as possible by removing unrelated objects and provide exact steps how to perform a test.
Simpler version of the .blend attached. There are two spheres, one strictly inside the other. The outer one is using transparent volumetric shading to produce a "glow" effect, while the inner sphere is rendered using a simple surface shader. The volumetric shading "glow" effect does not always render, leaving only the inner sphere being directly visible. This result is nondeterministic and seems to appear more frequently in earlier versions of Blender, and (let's say unrelatedly for the purposes of this bug report) appears to be highly correlated with a Blender crash. Contrary to what I stated above, I have been able to reproduce this in the Alpha.
I have tested this with three Blender versions so far.
00162e6b7b
, type: Releaseversion: 2.91.0 Alpha, branch: master, commit date: 2020-08-09 00:04, hash:
b522e834ec
, type: ReleaseAll three produce frames without the volumetric effect, looking like the sphere on the right side of the below image, while the left is what 90-odd percent of the frames look like (and is the intended / expected look). There does not appear to be any noticeable distribution on which frames the discrepancy appears, from a casual analysis; as far as I can the unexpected results are uniformly distributed across frames.
And here is the .blend:
difference_example.blend
The issue only appears with the Eevee renderer, Cycles is fine. This leads me to suspect my OpenGL implementation, but trying with the Blender 2.91.0 Alpha on Windows x64 with the same .blend file on the same machine gives the same inconsistent results (and crashes). Trying back on Linux with
blender-softwaregl
also produces the same results.In case it's relevant, I have an AMD CPU (first-gen Ryzen 1600) and an AMD GPU (Polaris 10 RX 470) in this machine. I'll see if I can get access to a machine with an Intel CPU / Intel or NVidia GPU to see if it might be an AMD-specific problem.
Also, I'm trying to get a debug build of Blender working on Linux to see if I can get a proper backtrace with a recent version of Blender in case something in the crash might be helpful for isolating any problems, will update if/once I get that working.
I simplified file a bit more, I was able to reproduce shading error, but I wasn't able to reproduce crash.
