Mix Shader Acts Differently in Cycles and Eevee #79756
2 Participants
Reference: blender/blender#79756
Graphics card: GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-12 17:26, hash:
ba2d1c8898
Worked: never
The mix shader's factor has been set to 1, however it does not output the second shader in Eevee, it works as expected in Cylces though.
In the Blender Manual, this is what it says: "Factor: Blend weight to use for mixing two shaders; at zero it uses the first shader entirely and at one the second shader." It does not mention anything about the difference in Eevee and Cycles, so I am assuming it to be a bug.
[Based on an attached .blend file]
Mix Shader Bug.blend
Cycles:
Eevee:
Added subscriber: @Eary
Added subscriber: @EAW
When using EEVEE, you have to back a reflection cube map to have the reflections approximately match Cycles.
See: https://docs.blender.org/manual/en/dev/render/eevee/light_probes/reflection_cubemaps.html
You cannot use a mix node to mix a BSSRDF with another shader when using EEVEE. Here is the relevant section of the manual.
https://docs.blender.org/manual/en/dev/render/eevee/limitations.html#subsurface-scattering
Closed as duplicate of #74454
This still does not make sense, for sss node, all you need to do is to swap the two slot, if that really is a limitation, why would swaping work? Also swaping does not work with Glossy, it only works with sss, it does not make sense.
I am trying to create a node group, where I had to mix a principled BSDF with a Glossy, and switch between them, the factor depended on another input value, when that value is 0 it use the principled BSDF completely, when the value is 1 it uses the Glossy completely. Any ideas on how to achieve that without using the mix shader?
