Bevel clamp overlap incorrect with percentage #79898
Reference: blender/blender#79898
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-05 22:29, hash:
675700d948
Worked: Never (2.8+)
edit mode bevel operation clamp overlap is basing overlap on offset rather than percentage, and therefore clamping even when there is no overlap.
#79898.blend
Increase the width to 100%.
Even though it’s set to percent, the clamp will still stop the edges that shouldn’t be clamped from fully bevelling.
Added subscriber: @3di
Added subscriber: @iss
Is this reported problem?
No, your bevelling vertices.
Create an object where one edge would cause a clamp to occur before other edges were fully bevelled
Select all edges
Bevel
Set bevel to percent
Turn on clamp overlap
Now increase the width.
edit mode bevel operation clamp overlap is basing overlap on offset rather than percentage.to Bevel clamp overlap incorrect with percentageChanged status from 'Needs User Info' to: 'Confirmed'
Added subscriber: @howardt
There is indeed a bug here. The clamp code works when the offset edges move parallel to the original edges, but that is not usually the case when Percentage mode is used. (The same bug will affect the new Absolute mode.) I will have to work out the different math for this case.
In working on adding clamping for Percent (which is hard!), I have discovered that the whole method of doing Percent is wrong. It is making constant width offset lines.
Well this was quite the rabbit-hole. The whole method of doing percent (and absolute) mode was wrong. It worked if the required offset lines were parallel to the original edge, and maybe in a few other cases accidentally, but really I needed to write whole new code to handle these modes.
After doing that, the clamping for percent was trivial to fix: you need to clamp to 50% if two beveled edges shared the same leg.
The clamping for absolute mode is significantly harder. It is improved, but I'm going to leave its still-somewhat-brokenness as a known issue.
I really hope to be able to do away with clamping all together with a major upgrade to Bevel that I hope to work on next.
Cool, perhaps bevel width could be done based on the visual representation of vertex weight falloff on the face. 0.5 would always be halfway towards the nearest vertex for example. Would probably need edge weight too though for that to work on long edges.
