Crash on making material local
Closed, ResolvedPublicBUG
Broken: 2.83, 2.90.0, Commit date: 2020-08-24 16:27, Hash 1bced5884c3d
Worked: 279
  • Open main.blend
  • On the selected Cube, make its material local
  • Crash
source/blender/blenkernel/intern/lib_id.c:117:69: runtime error: member access within null pointer of type 'struct Library'
Full backtrace: P1602
Issue goes away if
  • [1] you delete Plane in the main file [linked -- also uses ani_matGlass_v09], save and reopen, ani_matGlass_v09 is then single-user on Cube, make local then works.
  • or [2] in the src file you delete those two OSL shader nodes from ani_matGlass_v09:
Dalai Felinto (dfelinto) changed the task status from Needs Triage to Needs Information from User.Aug 25 2020, 3:50 PM
This report does not contain all the requested information, which is required for us to investigate the issue. Please let us know how to reproduce from scratch or attach a simplified file where the issue happens.
ok, sorry, see attachment.
Just open "mainFile.blend" and click chain icon (make local) for material ani_matGlass_v09
For me this gives instant crash
I get a crash when I run this in 2.83 as well, yet in the report you said it worked in 2.83. Do you have a sample file that works in 2.83 but not in 2.90?
No, i just recoll that is was ok before at least with this material. But library constantly changes, so seems i`m wrong regarding 2.83
Its not widely used feature (by me), so i really can`t recall when it started to happen //
It was perfectly fine in 2.79 though, i switched moth ago or so
Dalai Felinto (dfelinto) renamed this task from [2.90] Crash on making material local to Crash on making material local.Aug 25 2020, 4:58 PM
Dalai Felinto (dfelinto) changed the task status from Needs Information from User to Needs Triage.
Dalai Felinto (dfelinto) updated the task description. (Show Details)
Crash: //source/blender/blenkernel/intern/lib_id.c:117:69: runtime error: member access within null pointer of type 'struct Library'
@Bastien Montagne (mont29) this is a very interesting issue. If I start deleting things from the file the issue goes away. That said it is not really a "simple file". I will leave to you to make a call on whether this is an ok "minimal file" or not. You can still delete all but MAani_matGlass_v09 material from the library.blend and still get the crash, roughly:
for m in D.materials:
  if m.name != 'ani_matGlass_v09':
    m.user_clear()
# save, re-open, save
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Aug 27 2020, 1:54 PM
Here are some simplified files:
Issue goes away if
  • or [2] in the src file you delete those two OSL shader nodes:
Bastien Montagne (mont29) triaged this task as High priority.
Bastien Montagne (mont29) edited projects, added BF Blender (2.90); removed BF Blender.
