Constraint missing after save and reopen the blend file (fixed in 2.90 - request to backport to LTS) #80125
Reference: blender/blender#80125
Graphics card: GeForce GTX 965M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.83.5, branch: master, commit date: 2020-08-19 06:07, hash:
c2b144df39
Worked: I've tested on blender 2.82a it's working fine, and also blender 2.90 beta also working as expected
If we save the blend file and reopen, the constraint will be missing.
constraint-missing-after-save.zip
EP25_SC01_SH056_v4-using-save-as-in.2.83.5.blend
just [save] without [save as] -> reopen the blend file -> constraint will missing
Added subscriber: @AditiaA.Pratama
Added subscribers: @Jeroen-Bakker, @lichtwerk
Can confirm, will dig up the commit that might need to be backported here.
CC @Jeroen-Bakker
Constraint missing after save and reopen the blend fileto Constraint missing after save and reopen the blend file (fixed in 2.90 - request to backport to LTS)Changed status from 'Needs Triage' to: 'Confirmed'
Hi @AditiaA.Pratama
You mention that it is broken in 2.83.5, have you tested if it was also broken in other versions of 2.83? It narrows our search to know if it is a new regression or wasn't at all working in 2.83.
@Jeroen-Bakker We stumble this issue since we upgrade to 2.83 LTS, but I'll run a test on other 2.83 version as well and report here.
For me, this is already broken in 2.83.0
In 2.90 this was fixed somewhere between
9f5cc128d9
andf2b5f731d5
Looks like
fd8d245e6a
"fixed" the issue.Added subscriber: @mont29
Note: looks like (as a workaround), you can call
then save and everything seems fine here then in 2.83.0 and 2.83.5.
maybe @mont29 can comment here if
fd8d245e6a
is suitable to backport or if other commits would be necessary to make this work reliably? (or if it is safe to just setauto_generate
to True on everything in older versions?)ah noted @lichtwerk, let me check, maybe this is good as temporary solution
so this is script that I've come up with
This specific commit will certainly never make it to 2.83, it´s a behavioral/feature change commit, not a fix at all. It might have hidden the issue somehow, but certainly not fixed it.
Unless someone can chase the actual fix in recent codebase, and that fix is safe enough for LTS (but there is very little chance for that, afaik all safe-enough fixes have already been backported to LTS in data/IO area of code), this will never be fixed in 2.83.
Since it is not a problem in current master, will consider this as fixed, thanks for the report anyway.
