Cycles GPU render crashes when using Subsurface Scattering shader #80283
2 Participants
Reference: blender/blender#80283
Operating system: (Linux Mint 19.3) Linux-5.4.0-42-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: AMD Radeon RX 5700 XT (NAVI10, DRM 3.38.0, 5.4.0-42-generic, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.8
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-30 21:49, hash:
429afe0c62
Also confirmed not to work with 2.83.5
Rendering with Cycles GPU makes the computer "halt", i.e. the screen freezes (though mouse movement works) and I can't switch to a login terminal (CTRL+ALT+F[1,2,3,...]).
Seems to be caused by the Subsurface Scattering shader, see logs.
When rendering, it says "Loading render kernels" and after a while it switches to "Compiling render kernels". After a couple moments, the computer stops responding.
Works fine with Cycles CPU.
Delete the Cycles cache (~/.cache/cycles). (This may not be necessary, but I've always done this before testing)
Create a fresh project and select the cube.
Go to the Shader tab, delete the default Principled BSDF shader.
Add a Subsurface Scattering shader (and connect it to the Material Output).
Switch from Eevees to Cycles GPU.
Press F12 to render.
system-info.txt
These logs were generated by running
./blender > <file>.log 2>&1
The
default.log
is the output of rendering the default cube.bug.log
is produced by following the above steps.default.log
bug.log
Added subscriber: @weerox
Added subscriber: @gabe2252
I've been generating some more log files using
./blender -b <args> <file> -f 1 > <logfile> 2>&1
.<file>
is the path to either of these files, wherebug.blend
is generated by following the steps to reproduce the error as stated in the description.default.blend
is the default cube with rendering set to Cycles GPU.bug.blend
default.blend
<args>
can be 4 different things.--log "*" --log-level -1
--debug
--debug-all
Here are the log files that was generated.
bug.1.log
bug.2.log
bug.3.log
bug.4.log
default.1.log
default.2.log
default.3.log
default.4.log
I will compare these logs and see if I can find anything that seems relevant.
After looking through the log files the only thing that stands out is that rendering stops at tile 74/510 in all 4 logs.
To figure out which tile it was that caused the problem I changed the Tile Order to Left to Right and rendered
bug.blend
again. I expected it to crash on another tile this time, but it didn't, it froze on tile 74/510 again and the 74th tile (using Left to Right order) just contains the background.I did some more experiments and managed to get into a terminal (CTRL+ALT+F[1,2,3,...]) after Blender crashed but before the computer froze completely. When trying to log in, the kernel sent out messages about
amdgpu
page faults, so this is probably a driver problem and not a problem with Blender. Though I still think it is peculiar that it stops at tile 74 irregardless of tile order.Here is the
kern.log
output concerningamdgpu
, if anyone is interested.amdgpu.log
Yes, this was a driver problem, downgraded from
amdgpu-pro 20.30
toamdgpu-pro 20.10
and now it works great!Sweet! Can you test if this bug is present on that driver? https://developer.blender.org/T79724 It seems to be another 5700xt driver issue.
Woops, that freezes my computer too, using the older version of the driver...
