Gradients not working on Grease pencil masks #80351
2 Participants
Reference: blender/blender#80351
Operating system: windows 10
Graphics card: GEForce RTX 2080 super
Blender Version 2.9
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (newest version of Blender that worked as expected)
Gradient layers not working properly with Grease Pencil if you open the example file https://cloud.blender.org/p/gallery/5c30cf5f637c8d7750c8aa6c you will see that applying the mask to the gradient layer does not work as in the preview from the old version of blender, the layer is not "multiplying" to give a sense of shadow on the lower layers of Grease pencil it just looks like a dirty overlay, also radial gradients do not work or are not visible.
Added subscriber: @Robinson
Added subscribers: @mendio, @antoniov, @lichtwerk
First note before looking at the mask issue (maybe this report should be split in two):
These are working, to me it is just always awkward to place these (same for textures).
Have a look at this file:
T80351_gradient_texture_transform_fill.blend
Location
underFill
)@antoniov, @mendio: I think we had this before, see #76522 (GPencil: Transform fill and Adjust Last Operation panel do not work) and D7741: Fix #76522: Grease Pencil transform fill and Adjust Last Operation panel issue [proposal], maybe this could get another round of rethinking? Wouldnt it make sense to have the UV origin based in the object center? So that you get your gradient/texture show up there if Location X/Y is 0/0?
I assume you added
details
,stroke
, andcolor
to the Masks list?But yeah, I am unfamiliar with how greaspencil blending works, but I am unable to achieve the same result as in 2.82.
Note there have been ColorManagement changes, this also affects blending, so it possible that quite some colors would need adjustments in that example file.
Another note: seems like the values for the Rim Effect changed since?
In 2.90 they seem reversed.
Same for the gradient placement
In 2.90, this seems totally different (and also doesnt do base > secondary > base, just does base > secondary)
Tried to do some tweaks, but still not there:
(Still) Bean disenchantement by Lopo Isaac tweaks.blend
This might not be a bug, but will confirm for now, maybe @antoniov can comment on the blending.
