List with fixes that could be in 2.90.2
- rB51c7a854fe2a: Fix T81057: PoseBone Constraints are displayed in Object Constraints tab
- T81112: Reloading Scripts causes SyntaxError (error only in 2.90.1, fix ready) (P1652 patch)
- rB8963671bcc1c: Fix T73858: Gizmo.use_draw_scale doesn't work as expected
- rB02a204fe67ee: Fix T68024: Crash from missing original-index mesh layer (requires rBea5c8c4e844f29772f9b4381ead04b0be68df30d)
- rBe6978f4d63d1: Fix T80885: Texture paint camera project crashes after undo/redo
- rBd037ac315b4d: Fix T80996: Weight Proximity modifier: crash going to editmode on a
- rBd1f906e874ea: Fix T80444: Triangle-Triangle intersection regression in 2.90
- rBba014586a0bb: Fix T81069: Can't lock axis with move anymore, using Shift+MMB together with rB738615cdfd98: Missed in last commit
- rB8febaae9e4f9: Fix T81155: Keyframe.select_control_point True when unselected
- rB9f12ea496a3f: Fix T80477: Crash when rendering with Embree but denoising with OptiX
- rB0295e14f5f26: Fix T81168: 2.8x Crash when loading 2.79 file.
- rBaead4b3cab47: API Docs: Fix xref urls
- rB54f248fa87af: Transform: Use orientation of active object with Auto Constraint
- rB5b97e50976b0: Fix T81272: Crash on opening old files where nodetrees had no name.
List with fixes that could be in 2.90.1
- rB97c6c4e47883: Decimate Modifier: Restore vertex group factor property in UI Commit to 2.90 would use &ptr instead of ptr in the change
- rB19fff96ef5dc: Fix T80289: GPencil Opacity modifier not working
- rBf2d26409e83b: Fix T80233: Extrude manifold can generate invalid geometry
- rBa440060142ca: Fix T79973: Re-ordering face maps messes up the names of other face maps
- rBe43d482cc93c: Fix T80426: Crash when deleting custom orientation
- rB907a718ebe3e: Fix T80224: Crash after duplicating and hiding vertices while using X Axis…
- rBf0c376a52a53: Fix T80332: principle volume shader not working for world in Eevee
- rBe7d3d0219b39: Fix T79718: Eevee OpenVDB render error when frames miss part of the grids
- rB09ef19996509: PY API doc: fix doc for new override option of properties.
- rB9681708c1cf1: Fix T80561: Crash when multi-mesh editing UVs with proportional editing
- rBc2419cdc5e58: Fix T80238: Crash adding properties to material node-trees
- rB1f75be8a4004: Fix T80604: BLI_polyfill_calc exceeds stack size allocating points
- rB9dcae4eb17d7: Refactor getting constraints (Seems to be related to other changes. During backport the get_constraints function was added back)
- rB0721fbb6e1e2: Fix for failing constraints test
- rB6dc7266cf1f4: Fix T80464: Crash deleting bone constraints when the armature layer is (depends on previous 2 commits)
- rB976b07056d3e: Fix T71012: Cycles baking crash with locked-UI & background-mode
- rBa0f41ba8a241: Fix T80516: Hook modifier crashes without vertex group data
- rB60b2bb3a1cc2: Fix T79626: 2.91 Mantaflow crash when adaptive domain + noise are enabled
- rBe347b6b86bfc: Fix T80372: Mantaflow Noise Not working with Smoke/Smoke and Fire
- rB0c4b732ef2cd: Fix T78225: Vertex Colors not showing in edit mode
- rBe22e30283714: Fix T80623: Correct Face Attributes affecting modes not listed
- rB1e186cea7c2b: Fix T77584: Edit Mode crash with shape keys created on blank mesh
- rBca3932582626: Fix T62504: Crash accessing depsgraph from evaluated view layer
- rB9d674708ea7e: Fix T80589: Translations in python scripts are missing.
- rB14b0f2037440: Fix T80694: Crash reloading scripts from the Python console
- rBec42daf63020: Fix T80457: Library Override - Custom Property to Drive Child Particles results…
- rBec6d32b238da: Fix T78392: [2.83.5, 2.90, 2.91] Crash on undo/ redo after changing modes.
- rBd9e2adaaf98c: Fix T80728: UV edge select splits UV's for lasso/box/circle select
- rB7177a580ccd4: Fix T80630: potential crash in volume grids in Eevee shaders
- rB3dbb231ed2f8: Fix OpenCL render error in large scenes
- rB3a92a2df4519: Add versioning for 2.90 files that may have invalid mesh
- rBa985b8bd9efd: Fix T80437: Auto IK Double Generates IK constraints
- rB009971ba7adc: Cycles: Separate Embree device for each CPU Device.
- rB007e90e8c0a9: Fix T78793, T79707: Cycles crash on macOS with older CPUs
- rBe0f13f41c681: Fix invert vertex group weight miscalculation for modifiers
- rB56748dbbcdb2: Fix T61985: NLA Bake exception baking pose with non-pose selection
- rBf5b6b825980f: Fix T80520: Tris to Quads ignores UV delimit option
- rBcacd57b67a15: Fix T80771: Avoid changing the visibility of loose geometry when entering…
- rBA8e1b4dd71b37: Archipack: support for bmesh bevel arguments changes in 2.90
- rBe5a572157d8c: Fix T80899: Crash on editing multiple UVs of multiple different objects at the…
- rBAf510c2165096: Fix T81073: PDT fillet tool not working
