Voxel size shortcut Shift + R causes blender to crash when Dyntopo is on constant detail #80410
Closed
opened 2020-09-03 03:38:04 +02:00 by adrian oyarce · 7 comments
Operating system: Windows 10 home x64
Graphics card: gtx 1080
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: 0330d1af29, type: Release
Voxel size shortcut Shift + R causes blender to close without warning when Dyntopo is on constant detail at slightly higher resolutions. May or may not work at a resolution of 16 but does not closes. always crashes at 32 after detail flood fill
Preparing mesh:
  • On the START UP FILE go to SCULPT MODE on the CUBE.
  • Set DYNTOPO to CONSTANT DETAIL
  • set the dyntopo RESOLUTION to 32,
  • then press DETAIL FLOOD FILL.
Reproducing the crash:
  • With the mesh having the new topology. press SHIFT + R + (R + R + R ...) repeatedly until it crashes
**System Information** Operating system: Windows 10 home x64 Graphics card: gtx 1080 **Blender Version** Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: 0330d1af29c0, type: Release **Short description of error** Voxel size shortcut Shift + R causes blender to close without warning when Dyntopo is on constant detail at slightly higher resolutions. May or may not work at a resolution of 16 but does not closes. always crashes at 32 after detail flood fill **Exact steps for others to reproduce the error** Preparing mesh: - On the START UP FILE go to SCULPT MODE on the CUBE. - Set DYNTOPO to CONSTANT DETAIL - set the dyntopo RESOLUTION to 32, - then press DETAIL FLOOD FILL. Reproducing the crash: - With the mesh having the new topology. press SHIFT + R + (R + R + R ...) repeatedly until it crashes
Author
Added subscriber: @RubenAdrianOyarce
Added subscriber: @mano-wii
I can reproduce a crash here, but it is possibly not the same problem, because it doesn't happen after I press Shift + R. But when I press Shift and R several times in a row.
Germano Cavalcante changed title from Voxel size shortcut Shift + R causes blender to close without warning when Dyntopo is on constant detail to Voxel size shortcut Shift + R causes blender to crash when Dyntopo is on constant detail 2020-09-04 18:00:45 +02:00
Member
Added subscriber: @lichtwerk
Member
I assume this is the same as #85034 (Sculpt: Shift + R (voxel grid preview) exits Sculpt Mode if the object has a Multires modifier) / #76655 (Sculpt Mode: Edit Voxel Size hotkey conflict)
What happens is that you intend to do voxel size edit.
That operator is not working with dyntopo enabled (voxel_size_edit_poll uses object_remesh_poll which doesnt succeed)
If the operator poll fails, it will fallthrough to Repeat Last which is also mapped to {key Shift R}
So you end up repeating the last action which is Detail Flood fill many times in a row [and in a fast way].
That might crash [I havent been able to get it to crash though].
However, the underlying issue is that you are intending one thing, and blender actually does another thing under the hood [this needs fixing].
Will merge this into #76655, feel free to comment again if this is a misunderstanding (we can always reopen then)...
I assume this is the same as #85034 (Sculpt: Shift + R (voxel grid preview) exits Sculpt Mode if the object has a Multires modifier) / #76655 (Sculpt Mode: Edit Voxel Size hotkey conflict) What happens is that you intend to do voxel size edit. That operator is not working with dyntopo enabled (`voxel_size_edit_poll` uses `object_remesh_poll` which doesnt succeed) If the operator poll fails, it will fallthrough to `Repeat Last` which is also mapped to {key Shift R} So you end up repeating the last action which is `Detail Flood fill` many times in a row [and in a fast way]. That might crash [I havent been able to get it to crash though]. However, the underlying issue is that you are intending one thing, and blender actually does another thing under the hood [this needs fixing]. Will merge this into #76655, feel free to comment again if this is a misunderstanding (we can always reopen then)...
Member
Closed as duplicate of #76655
Reference: blender/blender#80410
