Blender 2.90 crashes when I render through Cycles on Mac Pro 2010 (GTX 680)
Closed, DuplicatePublic
Hello..
Below is a crash report when I try to render out of Blender 2.90 using Cycles. Both viewport and final render produce a crash. Also, Blender does not 'see' recognise my graphics card even though this was not a problem in 2.83..
Process:               Blender [1048]
Path:                  /Applications/Blender 2.90/Blender.app/Contents/MacOS/Blender
Identifier:            Blender
Version:               2.90.0 (2.90.0 2020-08-31)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Blender [1048]
User ID:               501
Date/Time:             2020-09-03 22:05:40.757 +0200
OS Version:            Mac OS X 10.13.6 (17G14019)
Report Version:        12
Anonymous UUID:        157C6E8D-3A51-C6E1-727B-CACC36F2FC81
Time Awake Since Boot: 690 seconds
System Integrity Protection: enabled
Crashed Thread:        20
Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Illegal instruction: 4
Termination Reason:    Namespace SIGNAL, Code 0x4
Terminating Process:   exc handler [0]
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fff73804d82 __semwait_signal + 10
1   libsystem_c.dylib             	0x00007fff7377f724 nanosleep + 199
2   libsystem_c.dylib             	0x00007fff7377f618 usleep + 53
3   org.blenderfoundation.blender 	0x000000010ab2aa08 WM_main + 24
4   org.blenderfoundation.blender 	0x000000010a7ec4d2 main + 914
5   libdyld.dylib                 	0x00007fff736b4015 start + 1
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff737fb236 semaphore_wait_trap + 10
1   libdispatch.dylib             	0x00007fff7368a893 _dispatch_sema4_wait + 16
2   libdispatch.dylib             	0x00007fff73682979 _dispatch_semaphore_wait_slow + 101
3   org.blenderfoundation.blender 	0x000000011020ca12 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4   org.blenderfoundation.blender 	0x000000011020b57e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5   libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
6   libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
7   libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
0   libsystem_kernel.dylib        	0x00007fff7380528a __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fff739cc009 _pthread_wqthread + 1035
2   libsystem_pthread.dylib       	0x00007fff739cbbe9 start_wqthread + 13
Thread 10:
1   libsystem_pthread.dylib       	0x00007fff739cc20e _pthread_wqthread + 1552
Thread 11:
Thread 12:
Thread 13:
Thread 14:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	0x00007fff737fb1fa mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff737fa714 mach_msg + 60
2   com.apple.audio.CoreAudio     	0x00007fff4b10687a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 124
3   com.apple.audio.CoreAudio     	0x00007fff4b1067ed HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4   com.apple.audio.CoreAudio     	0x00007fff4b103859 HALC_ProxyIOContext::IOWorkLoop() + 977
5   com.apple.audio.CoreAudio     	0x00007fff4b1032bc HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6   com.apple.audio.CoreAudio     	0x00007fff4b102ffe HALB_IOThread::Entry(void*) + 72
7   libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
8   libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
9   libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 15:
0   org.blenderfoundation.blender 	0x000000010d16b319 void std::__1::__sort<std::__1::__less<embree::PrimRef, embree::PrimRef>&, embree::PrimRef*>(embree::PrimRef*, embree::PrimRef*, std::__1::__less<embree::PrimRef, embree::PrimRef>&) + 377
1   org.blenderfoundation.blender 	0x000000010cb35f84 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 772
2   org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
3   org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
4   org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
5   org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
6   org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
7   org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
8   org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
9   org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
10  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
11  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
12  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 16:
0   org.blenderfoundation.blender 	0x000000010d16b979 void std::__1::__sort<std::__1::__less<embree::PrimRef, embree::PrimRef>&, embree::PrimRef*>(embree::PrimRef*, embree::PrimRef*, std::__1::__less<embree::PrimRef, embree::PrimRef>&) + 2009
1   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
2   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
3   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
4   org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
5   org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
6   org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
7   org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
8   org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
9   org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
10  org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
11  org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
12  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
13  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
14  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 17:
4   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
5   org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
6   org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
7   org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
8   org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
9   org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
10  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
11  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
12  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
13  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
14  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
15  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
16  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
17  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
18  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
19  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
20  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
21  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
22  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
23  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
24  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
25  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
26  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
27  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
28  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
29  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
30  org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
31  org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
32  org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
33  org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
34  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
35  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
36  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 18:
0   org.blenderfoundation.blender 	0x000000010d16b1a0 void std::__1::__sort<std::__1::__less<embree::PrimRef, embree::PrimRef>&, embree::PrimRef*>(embree::PrimRef*, embree::PrimRef*, std::__1::__less<embree::PrimRef, embree::PrimRef>&) + 0
1   org.blenderfoundation.blender 	0x000000010cb35f84 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 772
2   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
3   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
5   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
10  org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
11  org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
12  org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
13  org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
14  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
15  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
16  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 19:
0   org.blenderfoundation.blender 	0x000000010d16b979 void std::__1::__sort<std::__1::__less<embree::PrimRef, embree::PrimRef>&, embree::PrimRef*>(embree::PrimRef*, embree::PrimRef*, std::__1::__less<embree::PrimRef, embree::PrimRef>&) + 2009
1   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
3   org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
4   org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
5   org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
6   org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
7   org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
8   org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
9   org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
10  org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
11  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
12  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
13  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 20 Crashed:
4   org.blenderfoundation.blender 	0x000000010cb372a9 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5673
5   org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
6   org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
7   org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
8   org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
9   org.blenderfoundation.blender 	0x000000010ab17495 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
10  org.blenderfoundation.blender 	0x000000010ab207db tbb::internal::market::process(rml::job&) + 43
11  org.blenderfoundation.blender 	0x000000010ab21628 tbb::internal::rml::private_worker::run() + 184
12  org.blenderfoundation.blender 	0x000000010ab21569 tbb::internal::rml::private_worker::thread_routine(void*) + 9
13  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
14  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
15  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 21:
Thread 22:: com.apple.NSEventThread
0   libsystem_kernel.dylib        	0x00007fff737fb1fa mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff737fa714 mach_msg + 60
2   com.apple.CoreFoundation      	0x00007fff4b6b8dc5 __CFRunLoopServiceMachPort + 341
3   com.apple.CoreFoundation      	0x00007fff4b6b8117 __CFRunLoopRun + 1783
4   com.apple.CoreFoundation      	0x00007fff4b6b7787 CFRunLoopRunSpecific + 487
5   com.apple.AppKit              	0x00007fff48d81fc4 _NSEventThread + 184
6   libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
7   libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
8   libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 23:
0   libsystem_kernel.dylib        	0x00007fff7380528a __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fff739cc20e _pthread_wqthread + 1552
2   libsystem_pthread.dylib       	0x00007fff739cbbe9 start_wqthread + 13
Thread 24:
Thread 25:
Thread 26:
0   libsystem_kernel.dylib        	0x00007fff73804d82 __semwait_signal + 10
1   libsystem_pthread.dylib       	0x00007fff739d0824 _pthread_join + 626
2   org.blenderfoundation.blender 	0x000000010f736593 ccl::thread::join() + 19
3   org.blenderfoundation.blender 	0x000000010c8c287b ccl::Session::wait() + 27
4   org.blenderfoundation.blender 	0x000000010bca6be9 ccl::BlenderSession::render(BL::Depsgraph&) + 3385
5   org.blenderfoundation.blender 	0x000000010bc9d12b ccl::render_func(_object*, _object*) + 203
6   org.blenderfoundation.blender 	0x000000011078b582 _PyMethodDef_RawFastCallKeywords + 226
7   org.blenderfoundation.blender 	0x000000011078aa49 _PyCFunction_FastCallKeywords + 41
8   org.blenderfoundation.blender 	0x0000000110860c10 call_function + 656
9   org.blenderfoundation.blender 	0x000000011085d6ee _PyEval_EvalFrameDefault + 27262
10  org.blenderfoundation.blender 	0x000000011078af2d function_code_fastcall + 237
11  org.blenderfoundation.blender 	0x0000000110860c8c call_function + 780
12  org.blenderfoundation.blender 	0x000000011085d6ee _PyEval_EvalFrameDefault + 27262
13  org.blenderfoundation.blender 	0x000000011078af2d function_code_fastcall + 237
14  org.blenderfoundation.blender 	0x000000010af1f5ae bpy_class_call + 878
15  org.blenderfoundation.blender 	0x000000010ae85c21 engine_render + 113
16  org.blenderfoundation.blender 	0x0000000110139d00 RE_engine_render + 1152
17  org.blenderfoundation.blender 	0x0000000110143b9e do_render_all_options + 350
18  org.blenderfoundation.blender 	0x0000000110143666 RE_RenderFrame + 406
19  org.blenderfoundation.blender 	0x000000010bc6daea render_startjob + 122
20  org.blenderfoundation.blender 	0x000000010ab41f47 do_job_thread + 39
21  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
22  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
23  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 27:
10  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
11  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
12  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
13  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
14  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
15  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
16  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
17  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
18  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
19  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
20  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
21  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
22  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
23  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
24  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
25  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
26  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
27  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
28  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
29  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
30  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
31  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
32  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
33  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
34  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
35  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
36  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
37  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
38  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
39  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
40  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
41  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
42  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
43  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
44  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
45  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
46  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
47  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
48  org.blenderfoundation.blender 	0x000000010cb3a79d void tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>, tbb::blocked_range<unsigned long> >(unsigned long&, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)&) + 1117
49  org.blenderfoundation.blender 	0x000000010cb3a1c9 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::execute() + 73
50  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
51  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
52  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
53  org.blenderfoundation.blender 	0x000000010cb3a0f2 tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&), tbb::auto_partitioner const>::run(tbb::blocked_range<unsigned long> const&, void embree::parallel_for<unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&)>(unsigned long, unsigned long, unsigned long, embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool)::'lambda'(embree::range<unsigned long> const&) const&)::'lambda'(tbb::blocked_range<unsigned long> const&) const&, tbb::auto_partitioner const&) + 210
54  org.blenderfoundation.blender 	0x000000010cb371b8 embree::sse2::GeneralBVHBuilder::BuilderT<embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::NodeRefPtr<4>, embree::FastAllocator::CachedAllocator, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::sse2::GeneralBVHBuilder::DefaultCanCreateLeafSplitFunc<embree::PrimRef, embree::sse2::PrimInfoRange>, embree::BuildProgressMonitor>::recurse(embree::sse2::GeneralBVHBuilder::BuildRecordT<embree::sse2::PrimInfoRange, embree::sse2::BinSplit<32ul> >&, embree::FastAllocator::CachedAllocator, bool) + 5432
55  org.blenderfoundation.blender 	0x000000010cb35c5f embree::NodeRefPtr<4> embree::sse2::GeneralBVHBuilder::build<embree::NodeRefPtr<4>, embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>, embree::sse2::PrimInfoRange, embree::PrimRef, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&), embree::BuildProgressMonitor>(embree::sse2::HeuristicArrayBinningSAH<embree::PrimRef, 32ul>&, embree::PrimRef*, embree::sse2::PrimInfoRange const&, embree::FastAllocator::Create, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Create2, embree::AABBNode_t<embree::NodeRefPtr<4>, 4>::Set3, embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings)::'lambda'(embree::PrimRef const*, embree::range<unsigned long> const&, embree::FastAllocator::CachedAllocator const&) const&, embree::BuildProgressMonitor const&, embree::sse2::GeneralBVHBuilder::Settings const&) + 223
56  org.blenderfoundation.blender 	0x000000010cb35a3f embree::sse2::BVHNBuilderVirtual<4>::BVHNBuilderV::build(embree::FastAllocator*, embree::BuildProgressMonitor&, embree::PrimRef*, embree::PrimInfoT<embree::BBox<embree::Vec3fa> > const&, embree::sse2::GeneralBVHBuilder::Settings) + 127
57  org.blenderfoundation.blender 	0x000000010cb99323 embree::sse2::BVHNBuilderSAH<4, embree::TriangleMi<4> >::build() + 2195
58  org.blenderfoundation.blender 	0x000000010cb1b61b embree::AccelInstance::build() + 27
59  org.blenderfoundation.blender 	0x000000010c9379ec tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, tbb::internal::parallel_for_body<void embree::parallel_for<unsigned long, embree::AccelN::accels_build()::$_0>(unsigned long, embree::AccelN::accels_build()::$_0 const&)::'lambda'(unsigned long), unsigned long>, tbb::auto_partitioner const>::execute() + 1420
60  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
61  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
62  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
63  org.blenderfoundation.blender 	0x000000010c936cdb embree::AccelN::accels_build() + 267
64  org.blenderfoundation.blender 	0x000000010c95ebc2 embree::Scene::commit_task() + 1842
65  org.blenderfoundation.blender 	0x000000010c962eec tbb::interface9::internal::start_for<tbb::blocked_range<unsigned long>, tbb::internal::parallel_for_body<embree::Scene::commit(bool)::$_5::operator()() const::'lambda'(unsigned long), unsigned long>, tbb::auto_partitioner const>::execute() + 1244
66  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
67  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
68  org.blenderfoundation.blender 	0x000000010ab2397e tbb::internal::generic_scheduler::local_spawn_root_and_wait(tbb::task*, tbb::task*&) + 222
69  org.blenderfoundation.blender 	0x000000010c9629c2 tbb::internal::function_task<embree::Scene::commit(bool)::$_5>::execute() + 146
70  org.blenderfoundation.blender 	0x000000010ab26949 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
71  org.blenderfoundation.blender 	0x000000010ab26031 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
72  org.blenderfoundation.blender 	0x000000010c9604f8 tbb::internal::task_group_base::wait() + 24
73  org.blenderfoundation.blender 	0x000000010c9604c2 tbb::internal::wait_delegate::operator()() const + 18
74  org.blenderfoundation.blender 	0x000000010ab1a31b tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 75
75  org.blenderfoundation.blender 	0x000000010c95f776 embree::Scene::commit(bool) + 662
76  org.blenderfoundation.blender 	0x000000010c94ecb3 rtcCommitScene + 35
77  org.blenderfoundation.blender 	0x000000010bcf5611 ccl::BVHEmbree::build(ccl::Progress&, ccl::Stats*) + 945
78  org.blenderfoundation.blender 	0x000000010c7d9b71 ccl::GeometryManager::device_update_bvh(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 641
79  org.blenderfoundation.blender 	0x000000010c7dbc2a ccl::GeometryManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 3242
80  org.blenderfoundation.blender 	0x000000010c8bf257 ccl::Scene::device_update(ccl::Device*, ccl::Progress&) + 1575
81  org.blenderfoundation.blender 	0x000000010c8c3da3 ccl::Session::update_scene() + 387
82  org.blenderfoundation.blender 	0x000000010c8c571f ccl::Session::run_cpu() + 943
83  org.blenderfoundation.blender 	0x000000010c8c2c2a ccl::Session::run() + 314
84  org.blenderfoundation.blender 	0x000000010f7364f5 ccl::thread::run(void*) + 37
85  libsystem_pthread.dylib       	0x00007fff739cc661 _pthread_body + 340
86  libsystem_pthread.dylib       	0x00007fff739cc50d _pthread_start + 377
87  libsystem_pthread.dylib       	0x00007fff739cbbf9 thread_start + 13
Thread 20 crashed with X86 Thread State (64-bit):
  rax: 0x000000010d16b953  rbx: 0x000070000eec39a8  rcx: 0x0000000142957fe0  rdx: 0x0000000142957fc0
  rdi: 0x0000000142957f80  rsi: 0x0000000142957fa0  rbp: 0x000070000e62daf0  rsp: 0x000070000e62d2b8
   r8: 0x000070000e62d440   r9: 0x0000000000000004  r10: 0xfffffffffffffffb  r11: 0x000000014278e000
  r12: 0x0000000142957f80  r13: 0x000070000e62d2e0  r14: 0x0000000142958000  r15: 0x000070000e62dc80
  rip: 0x000000010d16b979  rfl: 0x0000000000010206  cr2: 0x000000014d1cab16
Logical CPU:     1
Error Code:      0x00000000
Trap Number:     6
Binary Images:
       0x10a6ab000 -        0x114751f5f +org.blenderfoundation.blender (2.90.0 - 2.90.0 2020-08-31) <010B0AF9-7FEC-3ED1-B182-C6C878D2E54A> /Applications/Blender 2.90/Blender.app/Contents/MacOS/Blender
       0x11b069000 -        0x11b0d5ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender 2.90/Blender.app/Contents/Resources/lib/libomp.dylib
       0x11b26b000 -        0x11b413ff7  com.apple.audio.units.Components (1.14 - 1.14) <85C6E01E-2BF4-331D-ACA5-F528B6258318> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x11b4b5000 -        0x11b4b9ffb  com.apple.audio.AppleHDAHALPlugIn (281.52 - 281.52) <88340250-72ED-375D-8DC7-3341A6B8928A> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x11b50a000 -        0x11b50bff7 +com.3dconnexion.driver.client (10.0.3 - 10.0.3) <1B14FE8F-CEFE-981D-437B-55DE920B293E> /Library/Frameworks/3DconnexionClient.framework/3DconnexionClient
       0x11c818000 -        0x11c862adf  dyld (551.5) <CB9BFB56-4511-36F1-A546-891FF770C01C> /usr/lib/dyld
       0x11eaaa000 -        0x11eaaafff +libcuda.dylib (0) <F4F080B6-47B9-34B6-8439-A46878E60D91> /usr/local/cuda/lib/libcuda.dylib
       0x11f0bd000 -        0x11f544fff +com.nvidia.web.GeForceMTLDriverWeb (10.33.0 - 10.3.3) <402C7EA4-0797-33AB-9590-CA3F90B710A6> /Library/GPUBundles/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
       0x128892000 -        0x1292b7fff +com.nvidia.web.GeForceGLDriverWeb (10.33.0 - 10.3.3) <C1354D8C-014F-344C-8634-76C65C7523D0> /Library/GPUBundles/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
       0x12a977000 -        0x12a978ff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender 2.90/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
       0x12b047000 -        0x12b04cffb +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender 2.90/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
       0x13c29f000 -        0x13c2acfff +CUDA (0) <C686834B-462E-356B-8BCB-C36E399D19FA> /Library/Frameworks/CUDA.framework/Versions/A/CUDA
       0x13c2c9000 -        0x13c7efff3 +libcuda_387.10.10.10_mercury.dylib (0) <4F4C4D9A-6168-3233-B6A6-B6AB1D5F7CBB> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libcuda_387.10.10.10_mercury.dylib
       0x13c8f3000 -        0x13c931ffb +libfatbinaryLoader.dylib (0) <F961E02B-63E9-3DA6-9FF7-38D74BE23E0F> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libfatbinaryLoader.dylib
       0x13c940000 -        0x13cfdfff7 +libptxJitCompiler.dylib (0) <40B5BBC8-45BA-3422-9FFD-6D54A4828942> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libptxJitCompiler.dylib
    0x7fff43953000 -     0x7fff43ca1ff7  com.apple.RawCamera.bundle (8.05.0 - 1017.4.1) <937CBA8D-60C8-3739-8DFF-1C737D6339EF> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff47915000 -     0x7fff47915fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <2EF00EFE-06E8-3082-85C3-2988B422A19D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff47916000 -     0x7fff4792dff7  libCGInterfaces.dylib (417.2) <82F29CAE-C0AC-3E29-8312-09E6FED7E067> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff4792e000 -     0x7fff4807cffb  com.apple.vImage (8.1 - ???) <56C275C1-459F-37CD-BF29-2E6D81C29E53> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff4807d000 -     0x7fff4821dff3  libBLAS.dylib (1211.50.2) <93259222-2D94-333D-A1EB-09C6FC4A64B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff4821e000 -     0x7fff48258fef  libBNNS.dylib (38.1) <0AAE0109-71D5-3B26-8401-3E62DDF97624> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff48259000 -     0x7fff48632ff7  libLAPACK.dylib (1211.50.2) <70781D0B-AEAD-33EB-9900-10DC30F37D61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff48633000 -     0x7fff48649ff7  libLinearAlgebra.dylib (1211.50.2) <FB5A35EA-D636-3D69-AB53-B67E1EB8134C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff4864a000 -     0x7fff4864fff3  libQuadrature.dylib (3) <E936BDAF-8492-34D9-8C5C-AFBFCDAD8318> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff48650000 -     0x7fff486d0fff  libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff486d1000 -     0x7fff486e3ff7  libSparseBLAS.dylib (1211.50.2) <994A7D7E-FA3B-3943-A59C-8150B9AF86BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff486e4000 -     0x7fff48857fe7  libvDSP.dylib (622.50.5) <4BF310F4-31A3-3DA5-80E4-7F8014AD380B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff48858000 -     0x7fff4890efef  libvMisc.dylib (622.50.5) <88143A88-4FDE-35A1-85FE-54FF0C2A9E43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff4890f000 -     0x7fff4890ffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <880DEF40-389A-3F56-ACA1-B62A5BC57E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff48c03000 -     0x7fff49a61fff  com.apple.AppKit (6.9 - 1561.61.100) <B3CADDD5-C978-37C6-BC72-ADE2DCA97057> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff49ab3000 -     0x7fff49ab3fff  com.apple.ApplicationServices (48 - 50) <2B5B76E7-0AB2-31F9-BE58-B963BF1EC2E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff49ab4000 -     0x7fff49b1afff  com.apple.ApplicationServices.ATS (377 - 445.5) <60176327-F757-308E-B61A-D43394E87CC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff49bb3000 -     0x7fff49cd5ff7  libFontParser.dylib (222.1.9) <FFF2AC1A-D4D2-3AD3-BFF2-F3649ECB02AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff49cd6000 -     0x7fff49d21ff7  libFontRegistry.dylib (221.6) <30C6D1DE-C0E3-3447-A0EF-829443D95F0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff49dc6000 -     0x7fff49df9ff7  libTrueTypeScaler.dylib (222.1.9) <BF00CE2B-6BC5-3337-8350-A1BAB88A3CE0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff49e63000 -     0x7fff49e67ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <04764FB2-22D8-36F0-9647-2D21562E28D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff49f07000 -     0x7fff49f59ffb  com.apple.HIServices (1.22 - 625) <3C059A55-1409-373E-BF0B-C3299AFABDCF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff49f5a000 -     0x7fff49f68fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BB267F4-D5AA-3D35-8269-1A3CEA054ACD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff49f69000 -     0x7fff49fb5fff  com.apple.print.framework.PrintCore (13.4 - 503.2) <2EA98448-9D6A-3912-9933-F7703CB01B6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff49fb6000 -     0x7fff49ff0fff  com.apple.QD (3.12 - 404.2) <525E9518-DFF3-3D8D-BD48-E0D63EEDBD16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff49ff1000 -     0x7fff49ffdfff  com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) <CD09019C-569B-3A56-B84C-26F2A6223455> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff49ffe000 -     0x7fff4a28cff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <C7BE1645-BE23-3427-8650-1CEFDAF86710> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff4a28e000 -     0x7fff4a28efff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <294802B9-E24D-34EB-973F-6D2B8E2E86CB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff4a5b1000 -     0x7fff4a94efff  com.apple.CFNetwork (902.6 - 902.6) <46168F79-CCFA-349A-8508-B8CBCE27D440> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff4a963000 -     0x7fff4a963fff  com.apple.Carbon (158 - 158) <F8B370D9-2103-3276-821D-ACC756167F86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff4a964000 -     0x7fff4a967ffb  com.apple.CommonPanels (1.2.6 - 98) <075486A5-8E39-3F72-BED7-752517379C55> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff4a968000 -     0x7fff4ac6dfff  com.apple.HIToolbox (2.1.1 - 911.10) <8D2EBE85-9AF0-38BC-ACD3-1ED978643907> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff4ac6e000 -     0x7fff4ac71ffb  com.apple.help (1.3.8 - 66) <7F210C1C-D7D3-3C97-A2E4-D3CC35F91807> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff4ac72000 -     0x7fff4ac77fff  com.apple.ImageCapture (9.0 - 9.0) <3993E094-AB86-3B22-BC18-4550F23854FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff4ac78000 -     0x7fff4ad0dffb  com.apple.ink.framework (10.9 - 221) <83976BB8-A423-3AA5-8221-6EB04B3DEF0A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff4ad0e000 -     0x7fff4ad28ff7  com.apple.openscripting (1.7 - 174) <C282DFBB-4BF2-3222-87E0-0B560D5B4B2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff4ad49000 -     0x7fff4ad4afff  com.apple.print.framework.Print (12 - 267) <DFC4CE94-F6E6-3DFA-AB88-A13E4C5A7701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff4ad4b000 -     0x7fff4ad4dff7  com.apple.securityhi (9.0 - 55006) <1AB48F32-D1CB-3657-A30C-40A7E718A71D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff4ad4e000 -     0x7fff4ad54fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A07BB54-438B-34C9-8061-45403E197ACA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff4ae75000 -     0x7fff4ae75fff  com.apple.Cocoa (6.11 - 22) <3269BC26-0217-39FE-A600-D702656D838B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff4ae83000 -     0x7fff4af3cfff  com.apple.ColorSync (4.13.0 - 3325) <EAD2D314-E810-33FB-B105-BD30ABB912AD> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff4b0c9000 -     0x7fff4b15cff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF2B41CC-DD7A-34EB-A842-00DC3B8F2E9F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff4b1c3000 -     0x7fff4b1ecffb  com.apple.CoreBluetooth (1.0 - 1) <ED48840B-A80A-32C1-8E4B-DEB7A7CD3C1A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff4b1ed000 -     0x7fff4b551ff3  com.apple.CoreData (120 - 851) <283AF401-07BC-3D50-9B8C-7990E64F66BA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff4b552000 -     0x7fff4b635fff  com.apple.CoreDisplay (99.14 - 99.14) <9B2B211D-EC0A-3569-BB37-887768CD6105> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff4b636000 -     0x7fff4bad2fff  com.apple.CoreFoundation (6.9 - 1455.300) <D9D5D50D-5DA3-34B6-8077-DD24315A4B1E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff4bad4000 -     0x7fff4c103ff7  com.apple.CoreGraphics (2.0 - 1161.21.5) <C8BAA8C0-3DF0-37C3-8FB4-AB90BA8D4D56> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff4c105000 -     0x7fff4c3f4fff  com.apple.CoreImage (13.0.0 - 579.5) <B2B60A80-2E10-3EDF-920C-94288E55AE25> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff4c683000 -     0x7fff4c779ffb  com.apple.CoreMedia (1.0 - 2276.80.4) <67942D16-3658-37FC-B61C-8ED3D4BFBFB9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff4c7c9000 -     0x7fff4c7c9fff  com.apple.CoreServices (822.37 - 822.37) <CE816EF2-2B89-3F54-A5C6-D3080B1EFB00> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff4c7ca000 -     0x7fff4c83effb  com.apple.AE (735.2 - 735.2) <0938A72B-6A4A-36F1-95B3-5EF6B915CEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff4c83f000 -     0x7fff4cb16fff  com.apple.CoreServices.CarbonCore (1178.4.2 - 1178.4.2) <4692EE3A-11FE-31FD-AF5B-30F892E87A05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff4cb17000 -     0x7fff4cb4bfff  com.apple.DictionaryServices (1.2 - 284.2) <F1F3EFAE-2562-394D-8FB3-BE22F16CD75A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff4cb4c000 -     0x7fff4cb54ffb  com.apple.CoreServices.FSEvents (1239.50.2 - 1239.50.2) <FE465894-4235-3CE2-9A97-32D6C6C7D9AD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff4cb55000 -     0x7fff4cd13ff7  com.apple.LaunchServices (822.37 - 822.37) <0DB4679F-AE39-3BF3-B39B-549322E355AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff4cd14000 -     0x7fff4cdc4fff  com.apple.Metadata (10.7.0 - 1191.8) <F3BD3FD7-208A-31E9-85CD-6E607DDAFEF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff4cdc5000 -     0x7fff4ce25fff  com.apple.CoreServices.OSServices (822.37 - 822.37) <564DDE70-0250-346B-B5CC-4AFAC11A7373> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff4ce26000 -     0x7fff4ce94fff  com.apple.SearchKit (1.4.0 - 1.4.0) <97DD9E7D-3567-382B-ACF7-CE0E4FE78D36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff4ce95000 -     0x7fff4ceb9ffb  com.apple.coreservices.SharedFileList (71.21 - 71.21) <88991F51-0A75-34FF-8C91-ED0F3C270B7B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff4d15a000 -     0x7fff4d2aafff  com.apple.CoreText (352.0 - 578.23) <10DAF601-85A8-3F9C-8B0B-69DC16B95E47> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff4d2ab000 -     0x7fff4d2e5fff  com.apple.CoreVideo (1.8 - 0.0) <0DD4FFDF-E1F1-39D1-8246-5D0D9869F1EA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff4d2e6000 -     0x7fff4d371ff3  com.apple.framework.CoreWLAN (13.0 - 1350.2) <EC145FBD-F638-38B8-BE94-F892A2F02550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff4d5ec000 -     0x7fff4d5f1fff  com.apple.DiskArbitration (2.7 - 2.7) <51DC4AED-6F0C-321F-93E3-20EA4341B768> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff4d7af000 -     0x7fff4d7b1ff7  com.apple.ForceFeedback (1.0.6 - 1.0.6) <3BBF3660-5996-36D5-86C8-E439D37AEDBA> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
    0x7fff4d7b2000 -     0x7fff4db79ffb  com.apple.Foundation (6.9 - 1455.300) <0479E072-1DD0-3881-A9A2-EDAD3EE58C23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff4dbea000 -     0x7fff4dc1aff3  com.apple.GSS (4.0 - 2.0) <7E83A21E-4F90-38F3-9FD3-FAC0E0143243> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff4dd2c000 -     0x7fff4de30ffb  com.apple.Bluetooth (6.0.7 - 6.0.7f22) <08E33A6B-16A7-3E4E-82C9-E1E5A84300D0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff4de90000 -     0x7fff4df2bfff  com.apple.framework.IOKit (2.0.2 - 1445.71.6) <4B5C715C-6A49-366B-9080-ABADE6A3B3BD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff4df2d000 -     0x7fff4df34fff  com.apple.IOSurface (211.15 - 211.15) <08DA3232-805F-304B-80DD-C86B49CC4AAD> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff4df8b000 -     0x7fff4e109fff  com.apple.ImageIO.framework (3.3.0 - 1739.3.7) <5F5133CC-A33E-3B73-A853-9D9F287B9588> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff4e10a000 -     0x7fff4e10effb  libGIF.dylib (1739.3.7) <362B149F-0B71-3EAB-AB86-ECCB070461CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff4e10f000 -     0x7fff4e1f6ff7  libJP2.dylib (1739.3.7) <4866E322-62B9-3824-810A-3D470DD015B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff4e1f7000 -     0x7fff4e21afff  libJPEG.dylib (1739.3.7) <8FB432E4-2F14-3F08-BFA1-EA481EFBE38A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff4e50b000 -     0x7fff4e531ff3  libPng.dylib (1739.3.7) <133CDF23-39D9-3F1B-BAA1-99B2108E0624> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff4e532000 -     0x7fff4e534ff3  libRadiance.dylib (1739.3.7) <B6154159-17E7-328D-A066-1690589822DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff4e535000 -     0x7fff4e582ffb  libTIFF.dylib (1739.3.7) <3F7F074A-11B1-30CA-BBF7-399A30E289BA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff4f43c000 -     0x7fff4f455ff7  com.apple.Kerberos (3.0 - 1) <C7CDC1E0-011B-3220-847D-1AC3DA6D5522> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff4f714000 -     0x7fff4f71bfff  com.apple.MediaAccessibility (1.0 - 114) <00F21329-1163-3283-A882-A5DD7A12D353> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff4f7cb000 -     0x7fff4fe35ff7  com.apple.MediaToolbox (1.0 - 2276.80.4) <FA444376-E5AF-36AB-BE1D-76ECE4D72049> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff4fe37000 -     0x7fff4feb8fff  com.apple.Metal (125.30 - 125.30) <67EDA241-80B1-3C67-BB2B-FF83E49FEF8D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff4fed5000 -     0x7fff4fef0fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <8DED0F0C-4A10-36A3-A3E2-7D3CF429ACE1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff4fef1000 -     0x7fff4ff60fef  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <48F4A97F-143A-3918-AB92-6733E258E25A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff4ff61000 -     0x7fff4ff85fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <CD443ADC-07FE-3603-B0C9-60C2AF3616FF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff4ff86000 -     0x7fff5006dff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <40EB0BAE-6DDE-3334-A28C-529AE4C6716A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff5006e000 -     0x7fff5006eff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <A111E862-43E5-3247-9E98-0A40DC34AD9B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff5106d000 -     0x7fff51079ffb  com.apple.NetFS (6.0 - 4.0) <02E09301-324F-3542-875D-B87B144635C8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff5126d000 -     0x7fff51292fff  com.apple.audio.OpenAL (1.8 - 1.8) <EA6EC887-C876-3EE9-8A9F-D2EC9B54A0A0> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
    0x7fff53e62000 -     0x7fff53e6afef  libcldcpuengine.dylib (2.8.7) <78747075-B07A-39B3-A065-013FB54332F6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff53e6b000 -     0x7fff53ec5ff7  com.apple.opencl (2.8.24 - 2.8.24) <429B5283-276D-372D-BB0E-EEBE1408C393> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff53ec6000 -     0x7fff53ee2ffb  com.apple.CFOpenDirectory (10.13 - 207.50.1) <E9AD4934-5DE3-3DD0-9D7B-9D288D829F15> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff53ee3000 -     0x7fff53eeefff  com.apple.OpenDirectory (10.13 - 207.50.1) <8B54C486-14C9-3FEF-97B8-F4D6F59F75CF> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff5506d000 -     0x7fff5506ffff  libCVMSPluginSupport.dylib (16.7.4) <3E26CF2B-5074-3321-AD9E-6A667D61AA35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff55070000 -     0x7fff55075ffb  libCoreFSCache.dylib (162.12) <D12E1D0E-C0E5-329E-99B4-AB152C9ABBE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff55076000 -     0x7fff5507afff  libCoreVMClient.dylib (162.12) <39951906-8566-3F9D-9EA8-EBD6084DCF73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff5507b000 -     0x7fff55084ff3  libGFXShared.dylib (16.7.4) <81A7875B-103D-3C82-B25C-DE24E57E5C8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff55085000 -     0x7fff55090fff  libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff55091000 -     0x7fff550ccfe7  libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff550cd000 -     0x7fff5523aff3  libGLProgrammability.dylib (16.7.4) <1F7FE846-FDAF-3B3E-85AE-2FD0D0C46803> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff5523b000 -     0x7fff55279ffb  libGLU.dylib (16.7.4) <BCB09CD8-EB0E-38FA-8B5A-9E29532EE364> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff55bf1000 -     0x7fff55c00ff3  com.apple.opengl (16.7.4 - 16.7.4) <77A788F3-8F0C-305C-AEB9-FF258676C599> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff55c01000 -     0x7fff55d98ff3  GLEngine (16.7.4) <D803B49C-2CE6-3282-B15E-D7859C58DBC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff55d99000 -     0x7fff55dc1ffb  GLRendererFloat (16.7.4) <A474BF54-6B9C-3C76-BCB9-8FAD533E2B2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff56a54000 -     0x7fff56ca0ff7  com.apple.QuartzCore (1.11 - 584.64.2) <FD9A3180-479E-3DAC-9CF0-0D214C7E46A7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff574d8000 -     0x7fff57803fff  com.apple.security (7.0 - 58286.70.19) <E118FC23-2E20-3999-826B-58488049A277> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff57804000 -     0x7fff57890ff7  com.apple.securityfoundation (6.0 - 55185.50.5) <3D9AD4EF-439C-3AE1-9332-AD291CF96C64> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff578c2000 -     0x7fff578c6ffb  com.apple.xpc.ServiceManagement (1.0 - 1) <3FCAF325-40C8-3148-9E49-E555F95B2946> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff57c6b000 -     0x7fff57cdbff3  com.apple.SystemConfiguration (1.17 - 1.17) <41D509AB-AED3-30FF-BB00-615BB5A8AC00> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff57e90000 -     0x7fff5820bfff  com.apple.VideoToolbox (1.0 - 2276.80.4) <1C94A509-0372-3B58-94BC-4488C042BD79> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff5abd8000 -     0x7fff5ac6bff3  com.apple.APFS (1.0 - 1) <70034B32-9347-30FB-9DDE-95061F686613> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff5b898000 -     0x7fff5b8c0fff  com.apple.framework.Apple80211 (13.0 - 1370.4) <C296CDDB-0A79-3D6B-898A-0FBA1892F5AC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff5b8c2000 -     0x7fff5b8d1fef  com.apple.AppleFSCompression (96.60.1 - 1.0) <CBE1A092-CE90-36B9-AAA6-0BE2E7921504> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff5b9d0000 -     0x7fff5b9dbff7  com.apple.AppleIDAuthSupport (1.0 - 1) <924EA55F-1C87-347F-9212-F79EA2B2C84C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff5ba15000 -     0x7fff5ba5dff3  com.apple.AppleJPEG (1.0 - 1) <15558577-08E3-3087-86A9-8B6247978BCE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff5ba98000 -     0x7fff5bac0fff  com.apple.applesauce (1.0 - ???) <9CE4CAE2-30B9-3DF6-9BC0-33D532D7B937> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff5bb8d000 -     0x7fff5bbddff7  com.apple.AppleVAFramework (5.0.41 - 5.0.41) <C82921AA-1537-3736-BC16-5CABB3EF0100> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff5bf13000 -     0x7fff5c1acffb  com.apple.AuthKit (1.0 - 1) <C3087797-E472-300E-8B4A-448857ACE8E7> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff5c2e3000 -     0x7fff5c2eaff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <B2A1EEDF-490A-38E2-A896-41057C0417BF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff5c2eb000 -     0x7fff5c372ff7  com.apple.backup.framework (1.9.6 - 1.9.6) <0A54D219-E71B-3BC6-8DFC-11ED47E431BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff5dd2e000 -     0x7fff5dd37ff3  com.apple.CommonAuth (4.0 - 2.0) <21AF4AC2-E650-35F9-AB33-3EBA2769FBC0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff5e073000 -     0x7fff5e47bfff  com.apple.CoreAUC (259.0.0 - 259.0.0) <EF95ED0E-F4F1-3969-89BB-CE8CDD74C29F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff5e47c000 -     0x7fff5e4acff7  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <6AC79B1F-0A12-34A4-BC0D-5A6A65ABABE0> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff5e84b000 -     0x7fff5e85bff7  com.apple.CoreEmoji (1.0 - 69.3) <DCCF04BB-DA33-3DC0-B7C2-1D34870C0C0A> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff5efef000 -     0x7fff5eff7ff3  com.apple.CorePhoneNumbers (1.0 - 1) <3B388768-5CDB-341A-BCE2-4047EAD009EA> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff5f182000 -     0x7fff5f1b3ff3  com.apple.CoreServicesInternal (309.1 - 309.1) <9A9DE5A0-3912-3311-A351-2B7B5C35D1F0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff5f52d000 -     0x7fff5f5befff  com.apple.CoreSymbolication (9.3 - 64026.2) <30652FA5-C731-3A22-864D-DF6D9C77CD4C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff5f641000 -     0x7fff5f776fff  com.apple.coreui (2.1 - 494.1) <5B4F3E9C-A4EF-3908-A035-59B8631C3685> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff5f777000 -     0x7fff5f8a8fff  com.apple.CoreUtils (5.6 - 560.11) <2C5A0610-1F08-3603-8692-EE03E62EE622> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff5f8fd000 -     0x7fff5f961fff  com.apple.framework.CoreWiFi (13.0 - 1350.2) <500CC54F-A6CB-3D36-9BB1-C9C9F6A6E414> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff5f962000 -     0x7fff5f972ff7  com.apple.CrashReporterSupport (10.13 - 1) <1ADEC140-4838-3976-A14B-6268C5251481> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff5f9f1000 -     0x7fff5fa00ff7  com.apple.framework.DFRFoundation (1.0 - 191.7) <F7AB1B29-A4B0-3938-AFDC-DAA204929404> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff5fa03000 -     0x7fff5fa07ffb  com.apple.DSExternalDisplay (3.1 - 380) <13AA3B17-E649-3B7B-B09D-9AE7C4A60887> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff5fa89000 -     0x7fff5fafffff  com.apple.datadetectorscore (7.0 - 590.3) <E645FBF0-B47D-3394-84DF-792B85E94CB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff5fb4d000 -     0x7fff5fb8dff7  com.apple.DebugSymbols (181.0 - 181.0) <702DB951-F5A6-3155-9D84-BBA9A4B4E1BD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff5fb8e000 -     0x7fff5fcbdfff  com.apple.desktopservices (1.12.5 - 1.12.5) <96BB57E2-3359-3920-AA7C-BF03C2225485> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff60ad2000 -     0x7fff60f00fff  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <06065DA3-4091-3682-A308-BF3F2E3E4AF8> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff62b5c000 -     0x7fff62b5cfff  libmetal_timestamp.dylib (802.4.8) <7E1B5ECC-7504-3B86-B3D9-5D8CDF88FCFA> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
    0x7fff641bc000 -     0x7fff641c7ff7  libGPUSupportMercury.dylib (16.7.4) <7C01AE23-9849-3EE6-AEAC-84D4BC1788BE> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff641c8000 -     0x7fff641cdfff  com.apple.GPUWrangler (3.20.18 - 3.20.18) <B54A9063-01EC-3D2C-8924-86A1F315DEA2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff64f43000 -     0x7fff64f52fff  com.apple.GraphVisualizer (1.0 - 5) <EB42FFAD-2BCA-3DE2-B40E-AFDE6E7FAA4D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff64fd5000 -     0x7fff65049fff  com.apple.Heimdal (4.0 - 2.0) <FF7BC1AE-1BA6-3150-A7CC-B9E0AD5EBE7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff6595c000 -     0x7fff65963ff7  com.apple.IOAccelerator (378.28 - 378.28) <F109E4CB-49D9-37FB-974A-8A3E9E8A61DA> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff65967000 -     0x7fff6597efff  com.apple.IOPresentment (1.0 - 35.1) <AC89202B-8433-3B62-A7BE-467D1905F6FB> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff65d49000 -     0x7fff65d6fffb  com.apple.IconServices (97.6 - 97.6) <7913A453-8D29-31DC-ADDB-7CEC068C9B86> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff65ff4000 -     0x7fff66007ff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <B999BEF6-F3E7-30EE-9177-FBC8E826659D> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff66008000 -     0x7fff660fdff7  com.apple.LanguageModeling (1.0 - 159.5.3) <FAA236D6-CFB8-37D2-B635-B324E0719E32> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff660fe000 -     0x7fff66140fff  com.apple.Lexicon-framework (1.0 - 33.5) <F8DD2D09-5CEE-3741-93CF-223FC61FCCA4> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff66144000 -     0x7fff6614bff7  com.apple.LinguisticData (1.0 - 238.3) <6F2ED02A-2120-3ABA-8EC1-314E4FFE77F3> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff6694c000 -     0x7fff6694ffff  com.apple.Mangrove (1.0 - 1) <471F4581-5235-3381-B16B-CE92ED6CF086> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff66e5f000 -     0x7fff66ec8ff7  com.apple.gpusw.MetalTools (1.0 - 1) <F2A47319-0430-3BB5-943E-651A40C127A9> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff66ed1000 -     0x7fff66ee8ff7  com.apple.MobileAssets (1.0 - 437.60.1) <94912D67-E290-3205-B919-C70C0A8D7FCF> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff67058000 -     0x7fff67071fff  com.apple.MobileKeyBag (2.0 - 1.0) <9EA31672-3B83-3ABF-B2D5-8584E159051E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff670fd000 -     0x7fff67127ffb  com.apple.MultitouchSupport.framework (1614.1 - 1614.1) <A376F2FB-64AE-3B35-88B0-7D2BB4D1CB7C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff6738e000 -     0x7fff67399fff  com.apple.NetAuth (6.2 - 6.2) <85C5D94D-C67E-36DC-B0EA-02F53AC4FCD3> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff68c35000 -     0x7fff68c45ffb  com.apple.PerformanceAnalysis (1.194 - 194) <B6934994-BD69-36F9-914E-6BBDCD797612> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff6aa04000 -     0x7fff6aa22fff  com.apple.ProtocolBuffer (1 - 260) <195906B1-1DB1-3AD2-B2F7-87B867C27F40> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff6abfd000 -     0x7fff6ac20ffb  com.apple.RemoteViewServices (2.0 - 125) <695CBF89-C15C-3E4C-8045-B46DCA64E3FB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff6c546000 -     0x7fff6c65bff7  com.apple.Sharing (1050.22.9 - 1050.22.9) <CAB71093-B187-363E-BBAA-B0D23D7642AA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff6c686000 -     0x7fff6c687ff7  com.apple.performance.SignpostNotification (1.2.6 - 2.6) <E77879A4-B040-3BE0-86F5-98173A4100AD> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
    0x7fff6d3e5000 -     0x7fff6d682fff  com.apple.SkyLight (1.600.0 - 312.103.12) <A65B547C-B7CA-3E33-A0C5-58AB436A8467> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff6de4b000 -     0x7fff6de58fff  com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <90CDCEAD-5A65-3C35-9370-2B306895E97C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff6e305000 -     0x7fff6e32cfff  com.apple.StreamingZip (1.0 - 1) <B5C3D9D6-B1DC-33E5-B7D2-ADAF3E0CA30E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff6e9fe000 -     0x7fff6ea87fc7  com.apple.Symbolication (9.3 - 64033) <F576D527-4CB1-34A5-B15E-1130833EEDAB> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff6eff8000 -     0x7fff6f000ff7  com.apple.TCC (1.0 - 1) <9D5466C6-A8B6-3C24-A791-6506B81D9998> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff6f20d000 -     0x7fff6f2caff7  com.apple.TextureIO (3.7 - 3.7) <32C460CD-E93D-3FA5-A4AE-CA648722F5FE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff6f374000 -     0x7fff6f375fff  com.apple.TrustEvaluationAgent (2.0 - 31) <D88126F5-BF35-30FB-BAC2-B804D7EB65B0> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff6f37b000 -     0x7fff6f52bfff  com.apple.UIFoundation (1.0 - 547.9) <D0994333-5EB4-3415-8D18-2A0487AE91E0> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff70200000 -     0x7fff702cfff7  com.apple.ViewBridge (343.2 - 343.2) <0A295791-B763-3E58-A9DD-8E4F40E815C9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff70ca7000 -     0x7fff70ca9ffb  com.apple.loginsupport (1.0 - 1) <E273A65A-6379-3787-B119-BC6ED94D4A81> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff70e10000 -     0x7fff70e43ff7  libclosured.dylib (551.5) <112BC241-6626-3848-8DD8-B34B5B6F7ABC> /usr/lib/closure/libclosured.dylib
    0x7fff70efd000 -     0x7fff70f36ff7  libCRFSuite.dylib (41) <14B00FCF-4C67-3736-95B5-76FEA6E4972C> /usr/lib/libCRFSuite.dylib
    0x7fff70f37000 -     0x7fff70f42fff  libChineseTokenizer.dylib (28) <2237A259-0E59-3DD0-BADC-281C361FAB70> /usr/lib/libChineseTokenizer.dylib
    0x7fff70fd4000 -     0x7fff70fd5ff3  libDiagnosticMessagesClient.dylib (104) <3F855622-352B-3EA8-B7C8-94D1DB48C080> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff7100c000 -     0x7fff711d6ff3  libFosl_dynamic.dylib (17.8) <1A2A9D53-129E-3F7D-AE23-1D6E6D9EA017> /usr/lib/libFosl_dynamic.dylib
    0x7fff7120e000 -     0x7fff7120efff  libOpenScriptingUtil.dylib (174) <AC38B2C3-5A37-30EB-A246-CEFABD3DD4E7> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff71345000 -     0x7fff71349ffb  libScreenReader.dylib (562.18.5) <FFB20E40-7669-30F6-8577-B74E18076376> /usr/lib/libScreenReader.dylib
    0x7fff7134a000 -     0x7fff7134bffb  libSystem.B.dylib (1252.50.4) <BEE5BC0A-E8F4-323E-AC95-837885EF64DB> /usr/lib/libSystem.B.dylib
    0x7fff713de000 -     0x7fff713defff  libapple_crypto.dylib (109.50.15) <A8DEA8E9-5769-3C78-824D-969A98B94086> /usr/lib/libapple_crypto.dylib
    0x7fff713df000 -     0x7fff713f5ff7  libapple_nghttp2.dylib (1.24) <24338D88-5D73-3165-9CFB-5A92734C9040> /usr/lib/libapple_nghttp2.dylib
    0x7fff713f6000 -     0x7fff71420ff3  libarchive.2.dylib (54) <D2B6AD30-18CB-3E3C-ABBF-A0745654350F> /usr/lib/libarchive.2.dylib
    0x7fff71421000 -     0x7fff71524fe7  libate.dylib (1.13.1) <D828353D-3D64-30E3-970F-8D295407610D> /usr/lib/libate.dylib
    0x7fff71528000 -     0x7fff71528ff3  libauto.dylib (187) <92E693DF-D74D-39A0-99AB-8A9F6FFEBA18> /usr/lib/libauto.dylib
    0x7fff71529000 -     0x7fff715e2ffb  libboringssl.dylib (109.50.15) <FC25FE02-6AA8-3F0B-9EF3-56A455C08C0F> /usr/lib/libboringssl.dylib
    0x7fff715e3000 -     0x7fff715f3ff3  libbsm.0.dylib (39) <18D57879-A717-3466-9637-1704EE59A32A> /usr/lib/libbsm.0.dylib
    0x7fff715f4000 -     0x7fff71601ffb  libbz2.1.0.dylib (38) <0B4321CD-3D6F-3095-A12E-27F66B4321AD> /usr/lib/libbz2.1.0.dylib
    0x7fff71602000 -     0x7fff71658fff  libc++.1.dylib (400.9) <142D6292-F30F-3949-9F37-3C97A579F540> /usr/lib/libc++.1.dylib
    0x7fff71659000 -     0x7fff7167dff7  libc++abi.dylib (400.8.2) <EF5E37D7-11D9-3530-BE45-B986612D13E2> /usr/lib/libc++abi.dylib
    0x7fff7167f000 -     0x7fff7168ffff  libcmph.dylib (6) <890DEC4C-4334-393C-8B56-7C8560BBED9D> /usr/lib/libcmph.dylib
    0x7fff71690000 -     0x7fff716a7fd3  libcompression.dylib (47.60.2) <CC7ACB0A-49CD-3564-978F-49F843186F27> /usr/lib/libcompression.dylib
    0x7fff71952000 -     0x7fff7196aff7  libcoretls.dylib (155.50.1) <087E9F90-21E5-376D-9956-C4E346409682> /usr/lib/libcoretls.dylib
    0x7fff7196b000 -     0x7fff7196cff3  libcoretls_cfhelpers.dylib (155.50.1) <78CCDD10-7D71-365E-A0A5-8524ED5F5BF9> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff71b05000 -     0x7fff71c96fff  libcrypto.35.dylib (22.50.3) <6E609F99-59BC-3AEA-9DB3-FD360A2C50CC> /usr/lib/libcrypto.35.dylib
    0x7fff71e3d000 -     0x7fff71e92ff3  libcups.2.dylib (462.2.10) <590D6ACC-68A0-371E-8646-FC59F814534B> /usr/lib/libcups.2.dylib
    0x7fff71fd2000 -     0x7fff71fd2fff  libenergytrace.dylib (16) <1F11D488-07C6-3D18-BEF2-0B28A992D761> /usr/lib/libenergytrace.dylib
    0x7fff72009000 -     0x7fff7200eff3  libheimdal-asn1.dylib (520.50.9) <EF65C17E-31CD-31DC-876C-BF3EF393099C> /usr/lib/libheimdal-asn1.dylib
    0x7fff7203a000 -     0x7fff7212bff7  libiconv.2.dylib (51.50.1) <7965B866-C75A-3450-9891-0500349F7090> /usr/lib/libiconv.2.dylib
    0x7fff7212c000 -     0x7fff72353ffb  libicucore.A.dylib (59181.0.1) <17767680-09DF-3954-AB6C-B13B41F92A2E> /usr/lib/libicucore.A.dylib
    0x7fff723a0000 -     0x7fff723a1fff  liblangid.dylib (128) <C54A2059-A4BE-364B-94C2-581C548459BC> /usr/lib/liblangid.dylib
    0x7fff723a2000 -     0x7fff723bbffb  liblzma.5.dylib (10) <60BEAB81-CE65-3479-90CC-03325AACEC95> /usr/lib/liblzma.5.dylib
    0x7fff723bc000 -     0x7fff723d2ff7  libmarisa.dylib (9) <47540053-02CF-35F8-A75E-074DB3D51812> /usr/lib/libmarisa.dylib
    0x7fff72483000 -     0x7fff726abff7  libmecabra.dylib (779.7.6) <B2ACB6A9-91AE-364B-9418-8EB938BF82B6> /usr/lib/libmecabra.dylib
    0x7fff72883000 -     0x7fff729fefff  libnetwork.dylib (1229.70.2) <0596A03E-C984-3FE6-B88E-63D5F96EC49A> /usr/lib/libnetwork.dylib
    0x7fff72a85000 -     0x7fff72e763b7  libobjc.A.dylib (723) <616AB826-9179-3924-AA61-AF760363A3F5> /usr/lib/libobjc.A.dylib
    0x7fff72e89000 -     0x7fff72e8dfff  libpam.2.dylib (22) <E5840D63-8506-301A-9182-5000031854E1> /usr/lib/libpam.2.dylib
    0x7fff72e90000 -     0x7fff72ec8ff7  libpcap.A.dylib (79.20.3) <6A9D27FA-2780-3E96-8B2E-645638AC13AC> /usr/lib/libpcap.A.dylib
    0x7fff72f47000 -     0x7fff72f63ffb  libresolv.9.dylib (65.1) <D9BB6307-71E4-3A94-A745-1FCA114C6894> /usr/lib/libresolv.9.dylib
    0x7fff72fb2000 -     0x7fff72fb3ff3  libspindump.dylib (252) <7BE3801C-F1F5-3F54-AB70-9842F8EF3F09> /usr/lib/libspindump.dylib
    0x7fff72fb4000 -     0x7fff73141ff7  libsqlite3.dylib (274.8.1) <B70A2908-E0F7-364E-952A-1D2D19787B89> /usr/lib/libsqlite3.dylib
    0x7fff73315000 -     0x7fff73375ff3  libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
    0x7fff73376000 -     0x7fff73379ffb  libutil.dylib (51.20.1) <A50E15F1-20A2-3EA7-A8CE-A43662E18587> /usr/lib/libutil.dylib
    0x7fff7337a000 -     0x7fff73387ff3  libxar.1.dylib (417.1) <351781D5-3CCF-320F-BB5A-4DFCC1CCD31D> /usr/lib/libxar.1.dylib
    0x7fff7338b000 -     0x7fff73472fff  libxml2.2.dylib (31.19) <3314D6A0-7489-3A3D-90BC-5712926EBD9C> /usr/lib/libxml2.2.dylib
    0x7fff73473000 -     0x7fff7349bfff  libxslt.1.dylib (15.16) <57D56366-1E7B-356C-B2B8-F4688FF666E6> /usr/lib/libxslt.1.dylib
    0x7fff7349c000 -     0x7fff734aeffb  libz.1.dylib (70) <47278BDC-596E-3037-B8DA-05FE9D5DBEF6> /usr/lib/libz.1.dylib
    0x7fff7354a000 -     0x7fff7354eff7  libcache.dylib (80) <096D3699-58D2-3D23-9512-BC88DAE7B16C> /usr/lib/system/libcache.dylib
    0x7fff7354f000 -     0x7fff73559ff3  libcommonCrypto.dylib (60118.50.1) <B4E77BD4-A809-37E1-8A79-25955E0F5D9C> /usr/lib/system/libcommonCrypto.dylib
    0x7fff7355a000 -     0x7fff73561fff  libcompiler_rt.dylib (62) <4CEED002-D00B-35F8-B563-0546A5F71A43> /usr/lib/system/libcompiler_rt.dylib
    0x7fff73562000 -     0x7fff7356bffb  libcopyfile.dylib (146.50.5) <F7A7999F-9509-3C67-8EE9-95BEE6772676> /usr/lib/system/libcopyfile.dylib
    0x7fff7356c000 -     0x7fff735f1ffb  libcorecrypto.dylib (562.70.3) <9C6E5CC2-272B-3740-AEDB-9EBEC98EC7F9> /usr/lib/system/libcorecrypto.dylib
    0x7fff73679000 -     0x7fff736b2ff7  libdispatch.dylib (913.60.3) <285526B6-A2A6-316D-A1CC-37803B71E203> /usr/lib/system/libdispatch.dylib
    0x7fff736b3000 -     0x7fff736d0ff7  libdyld.dylib (551.5) <49ABA86D-DD48-3133-9B14-B9A564EEBC66> /usr/lib/system/libdyld.dylib
    0x7fff736d1000 -     0x7fff736d1ffb  libkeymgr.dylib (28) <7CC7B5E1-AB7F-3495-A26A-396461BCB66B> /usr/lib/system/libkeymgr.dylib
    0x7fff736d2000 -     0x7fff736deff3  libkxld.dylib (4570.71.82.5) <BEC5370B-5CCD-3885-AB48-F5EBA396F1DD> /usr/lib/system/libkxld.dylib
    0x7fff736df000 -     0x7fff736dfff7  liblaunch.dylib (1205.70.16) <265EE555-E988-3EE5-A39E-028FB3A5FE11> /usr/lib/system/liblaunch.dylib
    0x7fff736e0000 -     0x7fff736e4ffb  libmacho.dylib (906) <F5F16E2F-F961-3FF4-B02F-69BBDB57B8DC> /usr/lib/system/libmacho.dylib
    0x7fff736e5000 -     0x7fff736e7fff  libquarantine.dylib (86.70.1) <262CECFE-A493-3EC6-8608-CEA93757265E> /usr/lib/system/libquarantine.dylib
    0x7fff736e8000 -     0x7fff736e9ff3  libremovefile.dylib (45) <EA24BFB6-24B7-3841-8AAC-FAF400910706> /usr/lib/system/libremovefile.dylib
    0x7fff736ea000 -     0x7fff73701fff  libsystem_asl.dylib (356.70.1) <9481D82D-CFB7-3032-A07F-88F7F59CAC2C> /usr/lib/system/libsystem_asl.dylib
    0x7fff73702000 -     0x7fff73702fff  libsystem_blocks.dylib (67) <FA2C3663-9DBB-3AFB-80A3-E77BE0816AD0> /usr/lib/system/libsystem_blocks.dylib
    0x7fff73703000 -     0x7fff7378cff7  libsystem_c.dylib (1244.50.9) <25DD83D8-80CA-3DFF-8626-FE704911F19C> /usr/lib/system/libsystem_c.dylib
    0x7fff7378d000 -     0x7fff73790ffb  libsystem_configuration.dylib (963.50.9) <61B26E1D-FEFF-38C6-AE0E-A6DD90145EB2> /usr/lib/system/libsystem_configuration.dylib
    0x7fff73791000 -     0x7fff73794ffb  libsystem_coreservices.dylib (51) <E8FA663F-1B0F-3B12-8F97-31A46E6B4D68> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff73795000 -     0x7fff73796fff  libsystem_darwin.dylib (1244.50.9) <6195EEA1-83A7-35F0-8147-5AB031020CD0> /usr/lib/system/libsystem_darwin.dylib
    0x7fff73797000 -     0x7fff7379dffb  libsystem_dnssd.dylib (878.70.4) <0D2C9583-5D28-375B-AEB4-F66F18C78322> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff7379e000 -     0x7fff737e7ff7  libsystem_info.dylib (517.30.1) <9C2C96F3-638B-34E7-A2BD-24C643EAF957> /usr/lib/system/libsystem_info.dylib
    0x7fff737e8000 -     0x7fff7380eff7  libsystem_kernel.dylib (4570.71.82.5) <999FCB9D-CBCD-317D-A2ED-034B6D7FB23A> /usr/lib/system/libsystem_kernel.dylib
    0x7fff7380f000 -     0x7fff7385afcb  libsystem_m.dylib (3147.50.1) <B3172533-77D2-3416-8487-4A505198E9E1> /usr/lib/system/libsystem_m.dylib
    0x7fff7385b000 -     0x7fff7387aff7  libsystem_malloc.dylib (140.50.7) <821E16C8-7A7E-3269-9167-10F4F413BF93> /usr/lib/system/libsystem_malloc.dylib
    0x7fff7387b000 -     0x7fff739abff7  libsystem_network.dylib (1229.70.2) <07BFD80A-E7EB-3DEB-B765-5E1659453114> /usr/lib/system/libsystem_network.dylib
    0x7fff739ac000 -     0x7fff739b6ffb  libsystem_networkextension.dylib (767.70.2) <A90BAFFD-AC3D-3078-90B2-71463DBFD4A5> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff739b7000 -     0x7fff739c0ff3  libsystem_notify.dylib (172) <738B3BB0-4F20-3446-A3B6-095D796E5903> /usr/lib/system/libsystem_notify.dylib
    0x7fff739c1000 -     0x7fff739c8ff7  libsystem_platform.dylib (161.50.1) <90A2A62F-8690-3FA7-A4D0-9085BF2FA44A> /usr/lib/system/libsystem_platform.dylib
    0x7fff739c9000 -     0x7fff739d4fff  libsystem_pthread.dylib (301.50.1) <283E64A7-A2B2-3212-95BA-4D21F9AE36CF> /usr/lib/system/libsystem_pthread.dylib
    0x7fff739d5000 -     0x7fff739d8fff  libsystem_sandbox.dylib (765.70.1) <FCF1F844-544E-32D2-9406-FD8ED68F16E2> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff739d9000 -     0x7fff739daff3  libsystem_secinit.dylib (30) <4E84DF62-57B5-36F9-819F-3C1E7FEDA856> /usr/lib/system/libsystem_secinit.dylib
    0x7fff739db000 -     0x7fff739e2ff7  libsystem_symptoms.dylib (820.60.3) <A45B4D84-2C69-3F19-83C2-2F1EEA73A7B5> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff739e3000 -     0x7fff739f7ff7  libsystem_trace.dylib (829.70.2) <4C4E5351-E370-3226-9B30-61E250DE3B2E> /usr/lib/system/libsystem_trace.dylib
    0x7fff739f9000 -     0x7fff739feff7  libunwind.dylib (35.3) <BAE12DA3-CF33-32AD-86B0-CCD6705ADFAA> /usr/lib/system/libunwind.dylib
    0x7fff739ff000 -     0x7fff73a2cfff  libxpc.dylib (1205.70.16) <26D99819-B813-320E-9E8F-9D57AD2DA63B> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 811
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=592.5M resident=0K(0%) swapped_out_or_unallocated=592.5M(100%)
Writable regions: Total=849.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=849.4M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        2
Activity Tracing                   256K        2
CG backing stores                  672K        4
CG image                           100K        7
CoreAnimation                       52K       10
CoreImage                            8K        3
CoreServices                        32K        2
CoreUI image data                  596K        9
CoreUI image file                  180K        3
Foundation                           4K        2
Image IO                            64K        2
Kernel Alloc Once                    8K        2
MALLOC                           638.8M       94
MALLOC guard page                   48K       12
MALLOC_LARGE (reserved)            416K        3         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
Memory Tag 249                     264K        2
OpenGL GLSL                        256K        4
STACK GUARD                        108K       28
Stack                             40.2M       29
VM_ALLOCATE                       26.3M       56
VM_ALLOCATE (reserved)           128.0M        3         reserved VM address space (unallocated)
__DATA                            95.7M      264
__FONT_DATA                          4K        2
__GLSLBUILTINS                    2588K        2
__LINKEDIT                       238.6M       18
__TEXT                           353.9M      264
__UNICODE                          560K        2
mapped file                       67.2M       20
shared memory                      692K       10
TOTAL                              1.6G      833
TOTAL, minus reserved VM space     1.4G      833
Model: MacPro5,1, BootROM MP51.0084.B00, 4 processors, Quad-Core Intel Xeon, 2.8 GHz, 32 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 680, NVIDIA GeForce GTX 680, PCIe
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x4D33393342314B37304348302D4348392020
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x4D33393342314B37304348302D4348392020
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x4D33393342314B37304348302D4348392020
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x4D33393342314B37304348302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.102.30)
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: pci10de,e0a, Audio Device, Slot-1
PCI Card: NVIDIA GeForce GTX 680, Display Controller, Slot-1
Serial ATA Device: HL-DT-ST DVD-RW GH61N
Serial ATA Device: WDC WD1001FALS-41Y6A0, 1 TB
Serial ATA Device: WDC WD10EZEX-08WN4A0, 1 TB
Serial ATA Device: WDC WD10EZEX-00UD2A0, 1 TB
Serial ATA Device: WDC WD40EZRZ-00GXCB0, 4 TB
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB 2.0 Bus
USB Device: Keyboard Hub
USB Device: Mice&MultiKB USB product
USB Device: Apple Keyboard
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
