Image of the viewport can no longer be obtained via glReadPixels in Python. Gives strange results since 2.83 #80471
9 Participants
Reference: blender/blender#80471
Operating system: Arch Linux 5.8.5-arch1-1
Graphics card: Intel i7-8665U
Broken: since 2.83
Worked: till 2.82
In Python, we get an image of the viewport from within an registered draw handler routine using:
viewport = bgl.Buffer(bgl.GL_INT, 4)
bgl.glGetIntegerv(bgl.GL_VIEWPORT, viewport)
width = int(viewport[2])
height = int(viewport[3])
image = np.zeros([height, width, 4],dtype=np.uint8)
buffer = bgl.Buffer(bgl.GL_BYTE, image.shape, image)
bgl.glReadPixels(0, 0, width, height, bgl.GL_RGBA, bgl.GL_UNSIGNED_BYTE, buffer)
It worked fine till 2.82, as shown here
However, it gives blackish colors of the objects in the viewport since 2.83:
Added subscriber: @mgrewe
Offloading of rendered viewport gives strange results since 2.83to Image of the viewport obtained via Python gives strange results since 2.83Added subscriber: @lichtwerk
Just checking if I understand this correctly:
I've put your code [not exactly the same, left numpy out of play here for the time being] into an operator which seems to give correct results here (no black/unshaded object afaict):
#80471.blend
Does this fail for you as well?
If not, please provide a .blend file with your code failing -- with the complete code to run from the Text Editor (including saving the image or dumping the data into a blender Image datablock)
Hi Philipp,
thanks for the reply. Please find an updated blend file attached which should give what I tried to describe above. You might need to toggle "Generated Image".
#80471.blend
2.82:
2.90:
Added subscriber: @fclem
This is expected. We separated the overlay drawing and the render in 2.83. So glReadPixels will return the overlays color only (because the callbacks are rendered on the overlay framebuffer).
We still have to figure how to give access to the render color buffer.
It is unpractical for us to give access to the final framebuffer as it is now the window framebuffer.
Thanks for investigation. I hope the access can be done fast as we use it as an option to stream the viewport in a time-critical application. Pl. let me know if I can be of any help, e.g. testing. Cheers, Martin
Image of the viewport obtained via Python gives strange results since 2.83to Image of the viewport can no longer be obtained via glReadPixels in Python. Gives strange results since 2.83Added subscriber: @chafouin
Added subscriber: @JoseConseco
Added subscriber: @unwave
Hi all, just wanted to push this since a way to get the viewport image is still needed.
Is there maybe another way to get access to the rendered image? I want to avoid offscreen rendering due to additional overhead.
Added subscriber: @p2or
Added subscriber: @Will-43
As far as I know, it is possible to access frambeuffer through the drawing callbacks and the gpu module.
Therefore I believe we can consider this report resolved.
