Viewport Optix Denoiser is available when Cycles Render Device is set to None/CUDA, leading to a crash #80477
9 Participants
Reference: blender/blender#80477
Hi there !
Operating system: Linux-5.4.0-7642-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.100
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-03 20:57, hash:
a96283ba51
The option to choose the Viewport Denoiser in the Render Properties shows Optix in the dropdown menu, even though the Cycles Render Device in the System Preferences in set to "None" or "CUDA". Choosing the Optix Viewport Denoiser and going to Rendered mode crashes Blender
Note that the crash occurs also when the Device in the Render Properties panel is set to GPU Compute.
Note that a Cycles Render Device to Optix and the Device to GPU Compute does not crash for me when choosing the Optix Denoiser in the Rendered Viewport Shading (as it should be hopefully).
system-info.txt
optix_denoise_crash.txt
Added subscriber: @marcuspollio
#81464 was marked as duplicate of this issue
#81418 was marked as duplicate of this issue
#81325 was marked as duplicate of this issue
#80543 was marked as duplicate of this issue
Added subscriber: @YAFU
Optix Denoiser being available when Cycles Render Device is set to None/CUDA is correct behavior. However, I can confirm the crash following the above steps in
a96283ba51
with CUDA/CPU and Optix denoiser. Linux, GTX 960 (450.66 driver)Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @rjg
I can confirm this issue. I'm not entirely sure which project and tag is correct for this ticket, since there's an overlap between viewport, optix and cycles.
Added subscribers: @pmoursnv, @lichtwerk
Can confirm that
cf0ba59e31
is crashing for me as well (whereas429afe0c62
was still fine)Cannot bisect this atm, due to https://devtalk.blender.org/t/cuda-not-compiling , using builds from builder.blender.org.
CC @pmoursnv
Just a clarification. Crash not only happens in viewport, it also happens in final render with Optix denoiser. Under some circumstances the crash even occurs with Optix selected in Device settings. Anyway I guess this will be easily reproducible by the developers.
Added subscriber: @diegoblender
Added subscriber: @dfelinto
Hi Patrick, assigning this to you since it is a high priority issue. If you won't have the time to look at that please unassign and we see how to handle it.
Added subscriber: @Stefan_Werner
This is caused by
009971ba7a
. Enabling OptiX denoising with CPU rendering creates an implicit multi-device in Cycles, which breaks Embree BVH building because the Embree device (BVHEmbree::rtc_device
) is not initialized.@Stefan_Werner I suppose the simplest solution would be to override
Device::bvh_device()
inMultiDevice
as well and have it return the one from the first CPU device (as there should only be one anyway)? We also may want to streamline the Embree/OptiX BVH building at some point and make it more similar, but that's out of scope for this particular issue.Added subscriber: @Jeroen-Bakker
Removing the EEVEE Viewport tag, as it doesn't seem to be related to the OpenGL/drawing side.
This issue was referenced by
9f12ea496a
@pmoursnv Thanks Patrick !
Added subscriber: @iDro040
Added subscriber: @xavi17vlc
Added subscriber: @JordanBlue-2
