Blender 2.9 - Shadow Catcher - Alpha Threshold not appearing correctly #80496
Reference: blender/blender#80496
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash:
0330d1af29
I'm trying to render shadow of a car. Standard default shader for the ground-white diffuse. Only a Sunlight with 15 degree angle for the softness, Strength-1.
I'm making the Ground - as Shadow Catcher, however, I see specific threshold spreading across, the screen around where the object is located. In rendering settings I'm trying to cut it by increasing the number to 1... same result. Threshold not responding.
Create default sunlight pointing the ground -15 angle of softness - Strenght-1. Create Sphere on ground level surface, make the Ground - ShadowCatcher. Render, region exactly over the object. See the result.
Added subscriber: @IvayloGogov
Added subscriber: @mano-wii
According to the manual, "Alpha Threshold" affects Z, Index, normal, UV and vector passes.
https://docs.blender.org/manual/en/dev/render/layers/passes.html#data
The tooltip also says the same thing.
This does not appear to be a bug but I may have misunderstood the problem.
Hello mano-wii,
Thank you for providing this feedback. Actually, I'm not sure what is the function of this Alpha Threshold property, the fact is when I render any object as Shadow Catcher, there is no clearance of the alpha and threshold is been over the whole screen. May be this property cannot control the alpha at all, but my report is about the Shadow Catcher when rendering with Cycles itself.
Best Regards,
Ivaylo
Thanks for the info.
Alpha Threshold is used to define when a specific pass should be displayed or hidden behind a transparent object.
If I got it right, this report is about a misunderstanding and not a bug.
So closing.
For any questions regarding the usability of Blender, you can try on one of the community sites: https://www.blender.org/community/
Hello Germano,
Again the report is not about Alpha-Threshold but for Shadow Catcher. Why Shadow Catcher result on screen is not a bug?
Blender 2.9 - Shadow Catcher - Alpha Threshold not respondingto Blender 2.9 - Shadow CatcherBlender 2.9 - Shadow Catcherto Blender 2.9 - Shadow Catcher - Alpha Threshold not appearing correctlyChanged status from 'Archived' to: 'Needs Triage'
Added subscriber: @iss
Can you upload example .blend file?
Thanks for the report. If the problem persists please open a new report with the required information.
