makesrna crashes during the build with LTO on s390x architecture (Linux) #80639
Reference: blender/blender#80639
Operating system: Linux (Fedora)
Graphics card: N/A
Broken: 2.90 and master
Worked: without link time optimization (LTO)
makesrna crashes during the build with enabled LTO. See https://bugzilla.redhat.com/show_bug.cgi?id=1874398#c6
Linux distribution like Fedora have enabled LTO by default (https://fedoraproject.org/wiki/LTOByDefault) exposing the failure.
Yes, it does happen with blender 2.90 as well. I believe this is another case when enabled LTO reveals some real bug in the source code.
build output
running under gdb gives:
Added subscriber: @Luya-Tshimbalanga
Added subscriber: @LazyDodo
I'm seemingly unable to reproduce on
x86_64-redhat-linux
. Is this issue isolated tos390x-redhat-linux-gnu
or does it reproduce on other architectures as well?The issue is isolated on s390x since 2.83.5 as tested on scratch build. Other 64-bits architectures are unaffected.
s390x is not a supported platform for us, we don't have the hardware nor the development environment to do anything here, asan on x64 doesn't seem to turn up anything here either.
So i'm unsure how much help we can be here for an actual fix , I'm happy to sling some sh...uh things at the wall and see what sticks though
Given it is crashing during a free, more specifically in this bit of the code you could just try taking out the abort by either removing the line of code or by turning the cmake option
WITH_ASSERT_ABORT
tooff
, which will hopefully sidestep the crash (but the root cause will remain, pray an hope it's not going to rear its head elsewhere)I'd be real uncomfortable with his kind of compiler behavior and would highly recommend building/running our unit tests on this platform to rule out any further issues.
I will let the Fedora team specializing to S390x architecture know. One of team will hopefully take a look and provide suggestion.
Added subscriber: @sharkcz
with the
abort()
removed fromMEM_lockfree_freeN()
I see another crashAfter Fedora enabled LTO globally we have already seen various issues in the source codes, like relying on undefined behaviour, violating strict aliasing rules or similar, leading to runtime crashes. And platforms like s390x are good in uncovering that, the compiler has a different "view" on the source code. The only developer-visible difference should be that s390x is big endian (like ppc64 is). I can provide access to our public s390x machine if needed.
I'm not doubting that the s390x/LTO/big-endian are good at finding issues, the thing is like i mentioned the s390x is not a supported platform for blender and we cannot reproduce the issue on the ones that we do support, and while we do happily accept patches fixing issues for such unsupported platforms we do not have the resources to spend to go out and debug issues on such environments.
Now if the report was more specific going "hey over here at this specific spot, you're doing the stupid and relying on undefined behavior" it be a different story, but as of now this is not an actionable issue for us and i'll have to close your ticket.
Added subscriber: @ideasman42
@sharkcz I was curious if this issue pointed to bugs/bad assumptions.
If you can point to an actual error in the code I'd be interested to look into it.
OTOH, I tried building with LTO enabled and the generated warnings regarding string-size where false positives, there are some
lto-type-mismatch
warnings too, however those were inBLI_thrad_lock/unlock
threading code which isn't running in makesrns.Did you try building with/without
-fno-strict-aliasing
?makesrna crashes during the buildto makesrna crashes during the build with LTO on s390x architecture (Linux)@ideasman42 , I haven't looked into the details yet, it's on my to-do list. But my educated guess is there should an issue somewhere. It's based on the results we are getting after globally enabling LTO in Fedora.
It looks to me that blender already sets
andmakesrna
still crashes when I added that option explicitly.Changed status from 'Archived' to: 'Resolved'
