Grease pencil opacity bug when dealing with line thickness relative to screen #80862
7 Participants
Reference: blender/blender#80862
Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 26.20.100.7925
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash:
0330d1af29
When a line is small enough relative to the viewport or camera, it seems to lower in opacity, and the interpolation between points can cause artifacts
attached is a .blend file showing an extreme case, where two grease pencil points are at different sizes, and depending on how zoomed in you are, the point on the right becomes transparent, and it causes a very visible gradient between the points. Note, both points are at a strength of 1, any opacity change isn't expected.
This artifact shows up in renders, as pictured below.
opacity thickness bug.blend
Added subscriber: @razzzmatazzz30297
#84909 was marked as duplicate of this issue
Added subscriber: @mano-wii
Perhaps when the size of a point is smaller than that of a pixel, its opacity is overwritten to represent that it is less visible.
But in fact, this opacity should not generate this gradient.
Added subscribers: @fclem, @JamellMoore
I have been reviewing the GPencil engine/shader code and can see this is not a bug but intended by design.
In gpencil_common_lib.glsl L:343 it states that line thickness is clamped and the opacity reduced when the thickness is small to avoid aliasing artifacts.
I have removed the opacity modulation and tested the in the viewport and cannot see any artifacts. @fclem do you think the opacity modulation is safe to remove? If not the bug status should be removed from this task.
Bug-#80862-GPencil-Opacity-Small-Stroke-Thickness-FIX-TEST.mp4
The opacity modulation is here to avoid strong aliasing of subpixel lines. A better way would be to make this opacity fade inside the pixel shader, so after interpolation.
@fclem I thought that was the case. Isn't the sub-pixel antialiasing defined in ScenePencil->smaa_threshold sufficient in preventing these artifacts?
Nope it isn't enough. SMAA is only working on lines that are at least 1 pixel large. But we don't want to clamp actual visual thickness to 1 so we fade based on the line size.
Added subscribers: @Jkecwlkr, @filedescriptor
This issue was referenced by
09f7c93858
