Blender needs restart to re-bake ocean modifier #80876
Open
opened 2020-09-17 11:39:31 +02:00 by Johannes Hernehult · 24 comments
Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: 0330d1af29
Baking the ocean modifier only works once, then I have to save, exit blender and then re-open the file before I can bake again.
  1. Open blender.
  2. Select the default cube.
  3. Go to modifiers tab
  4. Select the ocean modifier.
  5. Click the "Bake Ocean" button.
  6. Click the "Delete bake" button
  7. Click "Bake Ocean" again, but it won't work (for me at least).
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06 **Blender Version** Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: `0330d1af29` Worked: (newest version of Blender that worked as expected) **Short description of error** Baking the ocean modifier only works once, then I have to save, exit blender and then re-open the file before I can bake again. **Exact steps for others to reproduce the error** 1. Open blender. 2. Select the default cube. 3. Go to modifiers tab 4. Select the ocean modifier. 5. Click the "Bake Ocean" button. 6. Click the "Delete bake" button 7. Click "Bake Ocean" again, but it won't work (for me at least).
Added subscriber: @PolySpark
Johannes Hernehult changed title from Baking ocean modifier need restart to bake to Baking ocean modifier needs restart to re-bake ocean 2020-09-17 11:41:07 +02:00
Johannes Hernehult changed title from Baking ocean modifier needs restart to re-bake ocean to Ocean modifier needs restart to re-bake ocean 2020-09-17 11:41:23 +02:00
Johannes Hernehult changed title from Ocean modifier needs restart to re-bake ocean to Blender needs restart to re-bake ocean modifier 2020-09-17 11:41:37 +02:00
Added subscriber: @mano-wii
Added subscriber: @pipur
Added subscriber: @efimpetelin
System: Windows 10 Pro 10.0.18362 x64
Even more: "delete bake" does nothing at all. I even can't rebake ocean.
What have I done:
  1. Baked ocean, saved file and closed Blender;
  2. Launch Blender, open project file, try to delete cache - nothing happening.
System: Windows 10 Pro 10.0.18362 x64 Even more: "delete bake" does nothing at all. I even can't rebake ocean. What have I done: 1. Baked ocean, saved file and closed Blender; 3. Launch Blender, open project file, try to delete cache - nothing happening.
Added subscriber: @ida_pruitt
Windows 10 19041 64 bit
2060 Super
Having the same problem. I can't delete ocean bake either, even after restarting multiple times and changing cache file path. Ocean modifier will also randomly stop affecting the plane in the viewport (so that it looks like a flat plane again) and I need to restart to get it back.
Windows 10 19041 64 bit 2060 Super Having the same problem. I can't delete ocean bake either, even after restarting multiple times and changing cache file path. Ocean modifier will also randomly stop affecting the plane in the viewport (so that it looks like a flat plane again) and I need to restart to get it back.
Added subscriber: @ra-solutions
Blender 2.91.0
Having the same problem. Also when I duplicate the modifier, the new modifier is marked as baked.
After the first bake of the new modifier, without saving the blend file, I could delete the cache, but not rebake it. After saving and realoding the file I could bake and delete one time again.
If I bake, save the blend file and reopen, there is no way to delete the baked cache.
Recreating the modifier from scratch is too hard.
Is there a workaround?
Windows 10 19041 64 bit Blender 2.91.0 Having the same problem. Also when I duplicate the modifier, the new modifier is marked as baked. After the first bake of the new modifier, without saving the blend file, I could delete the cache, but not rebake it. After saving and realoding the file I could bake and delete one time again. If I bake, save the blend file and reopen, there is no way to delete the baked cache. Recreating the modifier from scratch is too hard. Is there a workaround?
I found sort of workaround: just change grid resolution, and Bake will be live again
Added subscriber: @Tylerrrrrr
Thanks for bringing this up, I had the same issue.
After much trial and error, I found that changing the "Spectrum" automatically deleted the previous bake, allowing for a new bake immediately.
Spectrum being the option above bake "see screenshot".
I switched to "Established Ocean" and then back to "Turbulent ocean".
EDIT I am not certain that this works all of the time.... It's a few hours later and I am experiencing mixed results.
Thanks for bringing this up, I had the same issue. After much trial and error, I found that changing the "Spectrum" automatically deleted the previous bake, allowing for a new bake immediately. Spectrum being the option above bake "see screenshot". I switched to "Established Ocean" and then back to "Turbulent ocean". ![screenshot.png](https://archive.blender.org/developer/F9933481/screenshot.png) **EDIT** I am not certain that this works all of the time.... It's a few hours later and I am experiencing mixed results.
Added subscriber: @semimetallic
Added subscriber: @Evgenii111
@Tylerrrrrr Thank you very much! )
Added subscriber: @LarryB
This still seems to be an issue! I would love seeing that being fixed!
Added subscriber: @JustRed
Still an issue... 3.2
Philipp Oeser removed the
label 2023-02-10 08:46:32 +01:00
Philipp Oeser added the
label 2023-02-10 11:18:23 +01:00
Still an issue in 3.6
Have this too with macOs (M1) 3.6.2 (3.6.2 2023-08-17).
Project created on WIndows 3.6, baked to directory, opened project on mac and tried to delete bake.
Changing the spectrum, as @Tylerrrrrr suggested, worked and re-enabled the bake button
Have this too with macOs (M1) 3.6.2 (3.6.2 2023-08-17). Project created on WIndows 3.6, baked to directory, opened project on mac and tried to delete bake. Changing the spectrum, as @Tylerrrrrr suggested, worked and re-enabled the bake button
Still present in 3.6.5 and potentially easy fix...
Still present in 4.1, confirmed.
15 Participants
Reference: blender/blender#80876
