Eevee: Specular Light: The sepecular light contribution should be limited to samples with a normal pointing toward the camera #81070
6 Participants
Reference: blender/blender#81070
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-22 18:36, hash:
358a8e00bd
Worked: Unknown
Eevee produces render artifacts on the specular light contribution when the normal vector points away from the camera (for example because of active smooth shading). This can be seen as bright (wrong) reflections near the visibility boundary of the geometry. Cycles does not produce these artifacts, there seems to be no specular light contribution on normals facing away from the camera.
Eevee (wrong specular reflection on the left):
Cycles (correct specular reflections):
Load the attached .blend file and render the image with Eeevee (and to compare) with Cycles. To better understand the problem a dark red color has been added (as Emission) to the parts of the geometry with normals pointing away from the camera, and dark green for parts with normals pointing towards the camera. The specular reflections are white. The .blend file also contains a node group "View Clamped Normal" that allows to "correct" the normals (by changing them so they are not pointing away from the camera). This can be connected to the "Normal" input of the BSDF to hide the problem, as a workaround.
eevee-specular.blend
Suggested fix
Attached is a patch file for a suggested fix in blender/draw/engines/eevee/shaders/lights_lib.glsl by adding the check if dot(N, V) > 0.0 before calculating the specular contribution and returning 0.0 otherwise.
0001-Correct-the-specular-light-contribution.patch
Eevee (with the attached patch applied)
Added subscriber: @mmoeller
#85393 was marked as duplicate of this issue
Added subscriber: @bent
The above image and .blend file is rather synthetic to make the problem visible. A more typical case is shown in the following image:
The bright pixels on the upper left limit of the sphere should not be there. The image can be reproduced with the attached .blend file:
specular-artifact.blend
The .blend file contains a (smooth shaded) icosphere with a principled BSDF shader. Also for this case, the issue is not visible when rendered with Cycles.
Added subscriber: @YAFU
This issue was referenced by
1c22b551d0
@fclem , Thanks for the fix, it solves most of the problem. Just to mention just in case, that even with the fix in certain circumstances (it may depend on the amount of geometry of the mesh and the angle of the view) small fireflies/artifacts may still appear at the edges. For example here (it is more noticeable in the final render image)
Eevee_Specular.blend
EDIT:
Now I'm not sure if this is the same problem or if I should open a new report. The fireflies problem occurs even without lamps and without World lighting, when the material has a Principled BSDF shader:
Eevee_Principled BSDF_fireflies.blend
EDIT 2:
Film > Filter Size value changes number of fireflies.
EDIT 3:
Fixed on master, thanks.
