Complex Solidify TODO #81331
2 Participants
Reference: blender/blender#81331
This task keeps track of the current state of complex solidify.
Recently a couple bugs where found in complex solidify. Most of them are minor and this task is there to organise them.
But one of the bugs is critical and requires more work to fix properly (#80897) without raising computational complexity.
It would be possible to fix the bug in a good way, but it would need some of the code that already exists in the Weld Modifier.
The merge code in the Complex Solidify Modifier was added to make useful results possible when zero length edges exist.
It was very effective at getting rid of them, but a smart fallback value also seems to work decently fine.
So the better idea would be to remove the merge feature from Solidify completely and move it to the Weld Modifier. This way
the code of complex solidify will be cleaner and better to maintain. This was already briefly discussed with @campbellbarton.
It will also open the door to new things which could be added to complex solidify. Thats why this task also keeps track of the
progress towards moving the merge feature from the Complex Solidify Modifier to the Weld Modifier.
For the merge feature there is a design issue as well. Currently Complex Solidify merges edges in index order.
It always calculates the length of the edge that it currently processes and if it's shorter than the merge distance it
collapses the edge to the mean position of all the vertices that got merged there. This was fairly simple to implement,
but @mano-wii did mentioned, that it isn't a conventional method and should potentially be reworked.
Work plan
Original implementation:
Prior related changes:
Simple bugfixes:
Move merge feature:
Remove merge code from Complex Solidify ModifierNew Developments:
Move file location toGEO
Further Cleanup:
Cleanup the Solidify Modifier UIChanged status from 'Needs Triage' to: 'Confirmed'
Added subscribers: @mano-wii, @ideasman42, @HDMaster84, @mont29
Added subscriber: @Ghaspias
May I add #89691?
Cleanup Complex Solidify TODOto Complex Solidify TODO
